Old 07-18-2013, 06:36 AM   #15
la nomade's Avatar
2018 22' Sport
stanfordville , New York
thank you for this very constuctiv and creative solutions...i will look into it...fortunately the weather is back to normal nova scotia temp....the first thing i will have to do is remove all that silicone that the ac man put on,that will take some doing....will ask the local fisherman as to where to get the fiber glass material,maybe one of them can help me ,they fix their boats with it.....will keep you posted....this forum is the best!!!!!thanks
la nomade is offline   Reply With Quote
Old 07-18-2013, 06:44 AM   #16
Wetaskiwin , Alberta
I didn't notice you were in NS. Best place to find the fiberglass kits for you would be Canadian Tire or any Home Hardware.
Penmaenmawr is offline   Reply With Quote
Old 07-18-2013, 09:04 AM   #17
..... Walmart, NAPA, Bumper to Bumper.......
Old 07-18-2013, 11:28 AM   #18
la nomade's Avatar
2018 22' Sport
yes,i summer in nova scotia...would be happy to host any a.streamers...i am near liverpool on the south shore....off to canadian tire with my shopping list .....
Old 02-17-2014, 03:21 AM   #19
ASTailgate's Avatar
1981 28' Airstream 280
Hi, I had that problem on my rear Ac two years ago. I went to Home Depot(hardware store) and bought a putty like JB Weld putty that you have to kneed in your hand for about 20 seconds to activate it. It's is used on water pipes and is sometimes called aqua weld. After you kneed it, you just have to press form it into all the cracks. I had several cracks from tubing connections and the pan in several places. It only takes a few minutes to cure. I turned on the Ac and let it run for a long while without the bottom shroud. It has worked perfectly.
ASTailgate is offline   Reply With Quote
Old 02-17-2014, 03:23 AM   #20
ASTailgate's Avatar
Pls make sure you buy the stuff for water leaks.
Old 02-18-2014, 06:30 AM   #21
la nomade's Avatar
2018 22' Sport
my front a.c. was beyond fixing it with putty!right now la nomade is covered and surrounded by snow,after all those storms we do not know where to put it anymore...i have to wait for it all to melt,and a sunny day with a minn.of 54 degrees to install the pan which was lined with fiberglass.So i will not know if it works for a while.Eventually i have to take apart the rear A.C.which also leaks and if the cracks in the pan are not too bad i will try the putty first before i remove the unit to get to the pan to line it with fiberglass...will keep you posted....
Old 02-18-2014, 07:09 AM   #22
1981 31' Excella II
New Market , Alabama
I would just nix the pans and let the water leak on the roof. You would have to remove the units or at least flip them upside down so you can get all the old caulk off the roof. Most units use some thick foam rubber to make the roof seal. The newer Dometic units have a drain kit that sorta works. The pan was an Airstream part and I am not sure they make them anymore but you could call them. The pan would fit any AC unit and just funnel water from the top of the pan to the drain. I think the pan was caulked to the roof and then the standard foam gasket was used to seal the AC unit to the top of the pan. If you remove the pan and get a new foam gasket, most of your problems will go away. Water will leak down the sides of the trailer but so does mine with the Dometic Drain kit.
Perry
Old 02-19-2014, 06:53 AM   #23
la nomade's Avatar
2018 22' Sport
air stream does not make the pan anymore,that was the first thing i checked...comes spring ,i will take apart the rear a.c.and see if i can apply your idea of fixing the leak problem,if cracks in pan are not too bad i may just first try the putty....
and or try your solution.....thank you Perry....
Advice Needed: Duo Therm Air Conditioner & Heat Pump BKBroiler67 Furnaces, Heaters, Fireplaces & Air Conditioning 19 07-22-2015 05:40 AM
Removing privacy curtain so air conditioner can be removed saltrm1 Furnaces, Heaters, Fireplaces & Air Conditioning 5 04-11-2013 05:26 PM
Dash Air Conditioner Problems Santart Land Yacht/Legacy Motorhomes 4 09-05-2012 01:54 AM
Air conditioner cover havec1 Roof Vents, Skylights & Fans 4 08-12-2011 09:35 AM
Air conditioner shroud repair for 1974 Sovereign Shamock Furnaces, Heaters, Fireplaces & Air Conditioning 3 05-09-2011 06:30 PM
