Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Classic Motorhomes
Old 10-07-2009, 03:58 PM   #1
2006 19' Safari
Newark , Delaware
Air Conditioner - Repair or Replacement
The A/C's in my 350LE motorhome perform at about 30-40% of when I got it eleven years ago. What's the most cost efficient way to repair or replace? I understand that they can not be recharged [not sure why]. Any recommendations for replacement units [models and cost] would be appreciated. Thanks, Delaware
Delaware is offline   Reply With Quote
Old 10-07-2009, 04:04 PM   #2
Roof AC's or dash AC ?
The roof AC's are rechargeable, if a person knows how, and doesn't want to rip you off.
If it's the roof AC's, what brand? The originals were Coleman.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 10-07-2009, 04:40 PM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
When you say it is working at a reduced level. There are not many things that will cause an AC to work at a reduced level. The most common is dirty coils, either the evaporator or condenser coils. Fan speed will effect it. Filter clogged.
If an AC is low on charge it would freeze the evaporator coil and not supply any air at all. If it is out of charge it will supply air but without a temperature reduction.
First I would check the filter, fan speed, and then the coils for dirt. If there was a smoker in the MH that tar will collect dirt at a very fast rate. You can use a professional coil cleaning spray to remove the tar.
2004 Excursion 4x4
Old 10-07-2009, 05:46 PM   #4
2006 19' Safari
Newark , Delaware
I'm referring to the roof AC's [although the dash AC performs at about the same, poor level]. These are the original Coleman AC's. I've cleaned the coils, filter, etc. Fan spped apprears to be normal but I haven't actually measured it. Smoking is not involved.
What is involved in re-charging the AC's? I've been told by the Airsteam factory that they are not rechargable but I suspect where "there's a will there's a way". I was quoted $1400 per unit to replace........lots of money.
Old 10-07-2009, 05:59 PM   #5
HowieE's Avatar
Images: 12
Any AC can be recharged. But as I mentioned before as an AC looses it's charge it will go through a period of freezing the coil and cutting off the air flow. Then once the charge has dropped to a point that there is not enough refrigerant to produce any cooling the air flow will come back at near room temperature.
If you can remove the top cover feel the larger tube coming off the compressor. If there is any refrigerant the line will be cool to the touch and may warrant an attempt at recharging. If the line is warm or hot that may be an indication of a bad valve in the compressor. If that is the case replace the AC.
If the smaller line is HOT and the unit is still not producing cool air that may indicate a clogged cap tube. Again replace the AC.
Shop around you should be able to beat that price.
2004 Excursion 4x4
Old 10-07-2009, 06:36 PM   #6
2006 19' Safari
Newark , Delaware
Thanks Howie I'll check those areas. I'm feel comfortable replacing the units myself. I replaced a leaky AC pan on the roof after having one done in Jackson Center. They sold me the parts and told me how. I can't imagine that replacing the whole unit can be much more difficult.
Thanks again,
Delaware
Old 10-07-2009, 06:40 PM   #7
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Thanks again,
Delaware
It isn't tough, but you need an easy way to get on the roof and some help. I had two helpers to install the A/C on our Liner, one ladder and some scaffolding. The A/C unit is heavy.
Bill
Just my personal opinion
https://billbethsblog.blogspot.com/
Old 10-07-2009, 08:39 PM   #8
JimGolden's Avatar
1977 31' Excella 500
Carrier AiRV 15,000
Junk them both and get two new Carrier AiRV 15,000 BTU units with heat strips. I bought mine from Palomino Parts and it cost me under $500. One of them cools my 34 footer nicely (with a white painted roof and five awnings up). My old Coleman Delta T had seen her day. I hotwired the switches as the control boards were fried. I had ON or OFF. There was no thermostat anymore. Finally, that expired.
Got me the new 15,000 BTU and MAN WHAT A DIFFERENCE! They really have gotten better in the last twenty years. The Carrier is quieter, really throws the cold, and the thermostat actually works.
You can always cut back a 15,000 BTU. You can't get 14,000 BTU out of a 13,000. No use to even consider anything other than the 15,000.
You could maybe fix your old ones. You can do a line tap to put more refridgerant in it. But why bother? Since they're that old, I'd just replace them. The Carrier is a good unit.
I can't comment on the Dometic a/c. They may be just as nice. All I know is that I read nothing but good on here about the Carrier, I got one, installed it myself, and have been super happy with it. The only thing I'd ding the Carrier on is that I wish it has more than two fan speeds. But if that's the only beef I have, then that's pretty minor.
Anyway, I'd recommend you get you a couple of those guys and then buy yourself a nice heavy coat....you'll need it with two of those bad boys runnng!
See ya on the road,
- Jim
JimGolden is offline   Reply With Quote
Old 10-10-2009, 04:00 PM   #9
GlenCoombe's Avatar
1984 28' Funeral Coach
Belleview , Florida
Images: 27
Jim is right on the Carrier units. I've got a 15K ducted unit in Airstream One and the unit does a great job.
The remote control thermostat works great too.
Glen Coombe AIR #8416
Former Rolling Showroom & PuttLab (now party bus)
"I'm not an expert. But I did sleep in an Airstream last night."
GlenCoombe is offline   Reply With Quote
Old 10-11-2009, 08:55 AM   #10
JimGolden's Avatar
I should add....I wasn't trying to say that Palomino is the only or the best place to buy them from. That's just where I got mine from and they treated me right. Andy might sell them too. So I hope I didn't sound like I was pushing the other guys.
They're not that hard to install. In fact, once you've done one and see what you have to do, the second one would be a piece of cake. I probably took three hours on the first one, just because I'd never done it before. Most of the time was spent standing back looking at it trying to figure it out. I think I could do a second one in under an hour now.
The hardest part is getting it up on the roof. They are heavy buggers. I tried to carry it up a little giant ladder by myself. I'm a strong guy, but couldn't do it...the ladder was going to tip over with me. So you'll need some help there.
Anyway, best of luck!
- Jim
Old 10-11-2009, 09:10 AM   #11
1989 34.5' Airstream 345
Silverton , Colorado
condenser cost us about $250 to be installed at CW, on our previous AS('68 Overlander)...solved our ice-over and cooling problem...our problem with ac now in the moho is that the circuit breaker throws when the temp exceeds 95...in the current economy(read, we're on a tight budget), $3.5K is too much of a stretch...I'd rather have 2 more batteries for the 2 Kyocera 130 solar panels and a sine inverter and drive to a cooler spot...seriously, have someone check the condenser...m
Michael & Tracy
1989 345 Motorhome
CHARTER MEMBERS: FOUR CORNERS UNIT, AND PROUD OF IT!!!
We live for the moment, 'cause when you get there, it's gone...
ScrapIrony-2 is offline   Reply With Quote
Old 10-11-2009, 10:29 AM   #12
3 Dog Nite's Avatar
Cleveland , Tennessee
We had our 2 Coleman Mach V A/C's rechargered. They use r22 refridgerant which is readily available. Our A/C guy had to add new schrader valves as this was their 1st recharge. The rear also needed a new squirrel cage as the old one was out of round. It made a small thumping noise while running. Total cost was $250. A lot cheaper than replacement. The older units were designed to be repaired. A lot of newer ones are cheaper to replace than repair.
Ricky
"Sometimes I wonder if the world is being run by smart people who are putting us on, or by imbeciles who really mean it." Mark Twain
AIR 22749 WBCCI 2349 NOVA TAC TN-6
1989 345 LE Classic Motorhome
3 Dog Nite is offline   Reply With Quote
Old 02-03-2010, 04:31 PM   #13
Spacepod Ps's Avatar
2003 22' International CCD
Beaverton , Oregon
I have a quick question regarding AC units, and thought someone might be able to help me out on this one. I bought my rig back in October and since I have found my way south have started to use the AC on occasions.
Has anyone heard of or know why an AC unit would create moisture and make the air in the rig damp?
I've got a 2003 22ft CCD. It was stored for a number of years before I got it so I don't know if that's part of the problem or what. But, if I have it running and leave for a while and come back to it it does feel/ smell moist and damp. Kind of like a cave feels and smells when you go into it after being in the dry sun. I hope that analogy gives you an idea of what I'm dealing with. Or, another way to describe it would be it feels kind of like a swamp cooler.
Any ideas as to what could be the problem if there is one?
Spacepod Ps is offline   Reply With Quote
Old 02-03-2010, 04:38 PM   #14
All AC's remove water from the interior atmosphere, be it your home, office or RV.
But, if the drain line was plugged, water could get into the trailer, but it would be from a very obvious drip, from the AC interior shroud.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 02-03-2010, 05:29 PM   #15
HowieE's Avatar
Images: 12
The first thing I would do is get a means of measuring the actual humility in the trailer. Once measured I would turn the AC on for some time and recheck. Two things should have happened. The humility should have gone down and there should be water dripping from the drain tube. If these are present the AC is working.
If the humidity is not going down the problem may be the trailer has a leak. If this is the case the AC while attempting to pulling down moisture may also be pulling the smell from the insulation into the cabin area.
2004 Excursion 4x4
Old 02-03-2010, 06:12 PM   #16
Beaverton , Oregon
Thanks HowieE. That might be the problem. I'll see if I can't measure the humidity levels. Also, since you brought up the possibility of a leak let me throw this at you. During rain storms(It does have to be a pretty good downpour for this to happen) water will start dripping from the AC unit. The AC is not on when this has happened. Again, normal and nothing to worry about or possible leak? Just trying to get a handle on the situation.
Air Conditioner Replacement John Sims Furnaces, Heaters, Fireplaces & Air Conditioning 27 12-29-2021 12:25 PM
Air Conditioner replacement for 78 Safari bacevedo Furnaces, Heaters, Fireplaces & Air Conditioning 4 06-24-2008 11:52 PM
Replacement Air Conditioner for 71 Tradewind Lumatic Furnaces, Heaters, Fireplaces & Air Conditioning 9 06-01-2007 06:32 AM
air conditioner air flow problem strawberryjo Furnaces, Heaters, Fireplaces & Air Conditioning 0 06-05-2006 10:43 AM
air conditioner replacement '76 Ambassador camphost Furnaces, Heaters, Fireplaces & Air Conditioning 2 11-07-2003 12:38 PM
