Old 11-08-2018, 12:12 PM   #1
West Chester , Ohio
Air conditioner control relay location
I知 having a new generator installed in 1984 excella 270. We are trying to locate the control relay for AC so we can use the auto start feature. Any ideas where it is located?
The shop say it痴 the relay that low voltage signal turns on the high voltage for ac unit...
Kvsterling is offline   Reply With Quote
Old 11-13-2018, 05:07 AM   #2
Magnet18's Avatar
Churubusco , Indiana
By AC, do you mean air conditioning, or alternating current?
What's the function of "auto start"? Do you mean remote start from the control panel?
1983 Airstream 310 Class A Motorhome
-Rob
Magnet18 is offline   Reply With Quote
Old 11-13-2018, 05:57 AM   #3
1986 34.5' Airstream 345
Londonderry , New Hampshire
You don't say what AS you have.
In my 345 there are two transfer relays. These are the automatic
switches that transfer the AC circuits in the motorhome from shore
power to the generator. When the generator starts and comes up
to speed they delay a few seconds and then switch over.
In the 345 there are two such relays. One is under the forward bench
seat at the table. It controls AC power to the rear roof air conditioner.
It is mounted sideways on the generator box. It is hard to see into
without using a mirror.
The other one is under the bed in my unit with the sideways double
bed. Other bed arrangements are probably different. This relay
controls all other AC power in the motorhome.
My rear transfer relay failed. It would not change over. There is
a capacitor that controls the time delay. In my relay it had blown
apart. I got another one and it worked OK. A real simple and
cheap fix.
Pete.
Air345Fly is offline   Reply With Quote
Old 11-13-2018, 05:58 AM   #4
You did say what model you have, my bad!
Pete.
Old 11-16-2018, 09:19 PM   #5
West Chester , Ohio
Have a 1984 270 excella. I知 referring to the air con unit. I知 realizing this was a newer ac unit installed at the airstream shop so I may need to dig around during my demo this winter. The new generator p30 control panel has a feature that sense when the thermostat turns on the Air con , the gen runs. Then when ac is off, gen turns off. I知 looking for that air con control box. Control panel will also sense low battery voltage and automatically turn on generator to recharge. Will be nice when boondocking
Old 11-17-2018, 02:31 AM   #6
WayneG's Avatar
1984 27' Airstream 270
Scotia , New York
My 84 270 does not have a relay (or 2nd AC unit) I only have a toggle switch over the stove that either goes to the microwave or the roof AC. I found some manual pages that indicate there may be different methods of wiring for the AC unit.
Edit to add, in my 84 270 the relay box shown in page 275 is behind the lower door, to the left of the fridge, it may be on the back side of the panel holding the circuit breaker box
I modified mine for power protection
ID:	328035   Click image for larger version
Do not take life too seriously.
You will never get out of it alive.
WayneG is offline   Reply With Quote
Old 11-17-2018, 07:22 AM   #7
West Chester , Ohio
I have a mechanical switch on driver side for shore power and a separate switch for generator. I appreciate all this info! The module I知 trying to tap into is actually part of the roof air conditioner system, not the AC power for the RV. Believe I have a domestic penguin roof unit that apparently has a separate air con control unit that takes the thermostat signal and some relay in the unit that connects the 110v power to the compressor/blower. I can trace these wires but the disappear in the ceiling/wall and unable to trace. I heard some of these units are actually under the rooftop shroud on top of the condenser
Location of Horn Relay on 1985 P30 chassis Orland Dewey Electrical - Systems, Generators, Batteries & Solar 0 12-14-2011 07:09 AM
location location location goransons Airstreams on eBay 0 12-05-2009 09:29 AM
Location, Location, Location........... ROBERTSUNRUS Brakes & Brake Controllers 5 08-29-2009 06:13 PM
Location of Horn Relay? guy99 Mechanics Corner - Engines, Transmission & More... 11 08-12-2007 07:25 PM
Fuel pump relay location 1993 Classic custom Scrapile Classic Motorhomes 3 08-08-2006 08:42 PM
