Old 04-04-2008, 05:13 PM   #57
1988 34.5' Airstream 345
CUMMING , GA
check valve
thanks buckwheat. the check valve is definitely not on the tank. will follow your advice. Thanks to everyone. Now maybe I can finally get on the road!
wpapke is offline   Reply With Quote
Old 04-23-2008, 08:47 PM   #58
CUMMING , GA
Smile check valve
could not find one anywhere including on top of the tank. bought a a viair 450c compressor, 100% duty cycle at 100PSI. $264 vs. $1170 for the Gast replacement, and it came with its own check valve. Now the compressor cuts off at 98.5. before it ran almost constantly. Found a few leaks here and there. Still doesn't stay up for a week but it does stay up over night now.
Old 04-27-2008, 03:48 PM   #59
CUMMING , GA
check valve revisited
back to the drawing board. went out yesterday and the pressure was gone. Wouldn't refill past 60 according to the gauge but a physical check showed 95 or so. That went after a few hours. The bags now won't inflate past a couple of inches on level ground and the gauge just stopped working. am thinking I will strip all the auto stuff and fill the tank (and thus the bags) manually until I can replace all the system. Any thoughts out there?
Experiences with Carrier Air V installation? Sojourner Furnaces, Heaters, Fireplaces & Air Conditioning 10 04-29-2009 07:52 AM
Forced Air furnace Joan D'Andrea Furnaces, Heaters, Fireplaces & Air Conditioning 16 11-02-2002 09:41 PM
Duo Therm Brisk Air JAG Furnaces, Heaters, Fireplaces & Air Conditioning 6 06-06-2002 08:29 PM
Ram air Kit rdm Mechanics Corner - Engines, Transmission & More... 0 05-12-2002 09:04 AM
Charging System drmmlien Electrical - Systems, Generators, Batteries & Solar 3 05-09-2002 01:53 PM
