Old 02-13-2008, 06:07 PM   #43
1988 34.5' Airstream 345
CUMMING , GA
check valve
Hey Andy,
Just ordered one from you. Now if someone can tell me where it is I can replace it when it comes in.
wpapke is offline   Reply With Quote
Old 02-16-2008, 08:58 AM   #44
buckwheat's Avatar
1987 34.5' Airstream 345
Hendersonville , North Carolina
Mine is screwed directly into an albow fitting at the top of the tank. The main supply tube from the compressor connects to it. I've seen pics of others that are at the compressor discharge tee.
BubbleHead Fred
"Underway is the only way!"
buckwheat is offline   Reply With Quote
Old 02-16-2008, 03:03 PM   #45
CUMMING , GA
check vavle on 345 airstream
thanks buckwheat. i will look under the mattress first. Any idea which way the free flow arrow should be pointed?
Old 02-16-2008, 04:23 PM   #46
The arrow points towards the direction of flow.
Where it's at, depends on the motorhome, but usually near the leveling valves, but noy always.
The original small brass check valve, is not longer available, so Airstream came up with a substitute, that may need an adapter.
Old 02-17-2008, 12:53 PM   #47
CUMMING , GA
re: check valve
Thanks Andy.
"The arrow points towards the direction of flow." Is that with the direction of flow or toward the direction of flow? i.e., toward the tank or toward the compressor? I received the valve in record time, 2 days.
w
Old 02-17-2008, 04:01 PM   #48
Thanks Andy.
w
The arrow should point in the direction the air is flowing. In other words point the arrow away from the pump and towards the tank.
You can test which way it works by blowing in one end of the check valve. In one direction you can blow air through in the other direction no air will pass.
Old 02-23-2008, 05:25 AM   #49
CUMMING , GA
check valve
thanks bk. haven't checked the valve location yet. will let the forum know the outcome.
Old 02-26-2008, 09:09 PM   #50
CUMMING , GA
another dumb question. i was thinking that i could install the new check valve in line at the compressor instead of having to crawl under the rig. seems ot me that if the old valve is bad then it is a free flow through and wouldn't interfere withe the operation of the old valve. any thoughts anyone? Andy? Bk?
Old 02-26-2008, 09:21 PM   #51
If I remember right the check valve on my 310 was just on the other side of the compartment wall. It actually screwed into the fitting that penetrated the compartment wall. If you try and splice it into the line by the pump you're going to have to buy various fittings to make it work.
If it was me I'd just grab a sheet of cardboard and lay on it while replacing the fitting. If you fitting is in a harder to reach place you might try your approach.
I've always felt if you install things the way they came from the factory its easier to trouble shoot the next time.
Good luck!
Old 02-27-2008, 04:01 PM   #52
CUMMING , GA
Cool check valve
Someone said it (the check valve) was on the top of the tank. A bear to get to. Which compartment wall? I have a 345 and it may be in a different place than on a 310. The compressor is curbside under the bed. Thinking of a prophylactic replacement of the compressor as well.
Old 02-27-2008, 04:05 PM   #53
CUMMING , GA
oh yeah, there is a schrader valve on the street side with a hose leading to the streetside of the air tank. I assume that it is a fill valve for the tank as well as the schrader on the bottom of the tank. Does anyone else have one on the side of the RV?
Old 03-01-2008, 07:49 AM   #54
Jamie
jking's Avatar
1984 31' Limited
Oriental , North Carolina
If that is the case some PO added it ... A/S never put such a hose in. Check both ends for leaks with bubble solution and if it's OK consider yourself lucky.
Jamie
jking is offline   Reply With Quote
Old 03-02-2008, 11:10 AM   #55
Someone has added the shrader valve on our 310 as well. I think that was a common fix years ago when the air compressors died. On mine they just attached a hose to the bottom drain valve on the tank and ran a line over to the side of the rv behind the electrical compartment.
Old 03-07-2008, 05:24 PM   #56
buckwheat's Avatar
The curbside Schrader valve is for external pressurization of the air tank (and air bags via the tank) in the event of onboard air compressor failure. The Schrader valve on the bottom of the tank is for routine purging of moisture that accumulates in the tank, particularly during the summer. The tanks are steel and prone to rust so purge often!
When you install the check valve, be sure that you do it downstream of the 'T' to the air relief solenoid valve. That valve is normally open to dump the air between the check valve and the compressor whenever the compressor is shut off (this allows "no-load" compressor startup).
BubbleHead Fred
Experiences with Carrier Air V installation? Sojourner Furnaces, Heaters, Fireplaces & Air Conditioning 10 04-29-2009 07:52 AM
Forced Air furnace Joan D'Andrea Furnaces, Heaters, Fireplaces & Air Conditioning 16 11-02-2002 09:41 PM
Duo Therm Brisk Air JAG Furnaces, Heaters, Fireplaces & Air Conditioning 6 06-06-2002 08:29 PM
Ram air Kit rdm Mechanics Corner - Engines, Transmission & More... 0 05-12-2002 09:04 AM
Charging System drmmlien Electrical - Systems, Generators, Batteries & Solar 3 05-09-2002 01:53 PM
