Old 03-21-2015, 11:43 AM   #1
bigbidule's Avatar
1981 28' Airstream 280
Lisle sur Tarn , France
access to fuel gauge from inside moho ?
Hello. My fuel gauge ( excella 28 / 1981 ) is blocked ... Is it possible to make a trapdoor through the floor just above the fuel tank ? ( bad idea ? ) Thank you.
bigbidule is offline   Reply With Quote
Old 03-21-2015, 12:10 PM   #2
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
I did a trap floor in my subfloor but elected not to cut the engineered hardwood flooring above as I can unclick it to can access to the door.
ID:	234708   Click image for larger version
Its a recession when your neighbor loses his job; its a depression when you lose your own. "Harry S Truman"
Old 03-22-2015, 09:49 AM   #3
bigbidule's Avatar
Thank you Isuzusweet....It's done ! A little trap floor less of 1 x 1 foot just between the frame above the gauge. It was bad positioned ( !!!! ) and blocked by the side of the tank and I rotate the gauge of 45 deg. I have checked and the ohm meter give me a range from 5 ohm to 98 ohm. I suppose it's right...
fuel gauge sending unit hgarage Classic Motorhomes 4 08-01-2010 09:34 PM
Fuel Gauge Quit Working PowerItUp Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 2 11-05-2009 02:14 PM
fuel gauge showing full when it is not full Normin storm Mechanics Corner - Engines, Transmission & More... 2 08-25-2009 09:31 AM
GAS GAUGE / FUEL TANK QUESTION - P-30 Chassis N2XBW Classic Motorhomes 8 12-18-2007 08:38 AM
Conflict between OPD Valve & "Fuel Gauge" ? femuse LP Gas, Piping, Tanks & Regulators 0 04-22-2003 11:15 AM
