Old 07-27-2014, 02:27 PM   #1
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
AC drip pan broken and leaking
On our 1991 350 LE, the pervious owner installed a new Dometic low profile AC, but the drip pan is cracked and leaking.
I have seen the new catchment system, and I am able to get the unit on and off the roof.
What I need a little info about is this:
As I understand it, the current drain system is actually a "catch pan" installed as an extra part under the AC, that should be sealed to the roof sheets?
And, the new catch system comes with a new gasket to double the original for added height. So, since this AC has been installed and clamped down, should I replace the old gasket to re-install the unit with the new catch pans or with the supplied gasket be ok?
Thanks in advance for any input.
Regards,
JD
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 07-27-2014, 02:40 PM   #2
lewster's Avatar
Naples, FL , Hood River, OR
If you intend to use Dometic's auxiliary drain kit, you should also replace the existing A/C gasket, as it will be very difficult to perform the installation with a gasket that is already compressed.
PM me if you need some detailed explanations.
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
Old 07-27-2014, 03:27 PM   #3
airdreamers's Avatar
2008 28' International
Venice , Florida
Images: 14
If you also want to fix the crack in the drain pan, use JB Weld epoxy, it is a miracle product! Worked for me, Grwat!
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
airdreamers is offline   Reply With Quote
Drip, drip, drip Skamper1 Fresh Water Systems 8 06-12-2010 06:33 PM
drip- drip-drip-drip-drip.... AIR-Quarius Furnaces, Heaters, Fireplaces & Air Conditioning 3 08-09-2009 07:32 AM
Arrggggg! Drip, Drip, Drip—Warning, plumbing questions Jim & Susan Sinks, Showers & Toilets 16 06-10-2009 08:04 PM
Drip, Drip, Drip kamadeca Fresh Water Systems 4 05-20-2008 08:22 PM
AC drip,drip,drip,drip,drip Canuks Furnaces, Heaters, Fireplaces & Air Conditioning 6 06-02-2006 02:05 PM
