Old 01-08-2015, 02:32 PM   #1
cincinnati , Ohio
89 310 diesel with a cummins?
I have been looking for a MH for a while. I have looked at a few310s, and recently learned of one for sale somewhat nearby. The body looks straight, but it has not been driven in sometime although the owner says the motor turns over. He did tell me that the brake calipers lock up when he last tried to move it. I wonder if the brakes are rusted shut. That's not my main concern (although it is a concern) and not a good sign.
The owner has told me that the engine is a Cummins diesel. I thought that the 310s were all Isuzu turbodiesels. Am I wrong? Or does the seller simply not know what he has?
With that said, what do you all think is a fair range for a 1989 310 diesel which should be classified as a straight body but barn find. I have no idea for instance if the generator works. Is 5 to 7k a fair range or is that too high considering all the work that will likely be needed for tires belts hoses fluids perhaps turbos not to mention the systems on the RV.
RhinoWW is offline   Reply With Quote
Old 01-08-2015, 03:20 PM   #2
RamblinManGa's Avatar
2016 28' Pendleton
Scottsdale , Arizona
Hi from AZ. . . aren't the Cummins diesels 6 cyl, & Isuzu 4 cyl ? just askin'. . . .Craig
WBCCI 2851,4CU
RamblinManGa is offline   Reply With Quote
Old 01-08-2015, 03:25 PM   #3
Vycan's Avatar
1994 36' Classic 36 Diesel
Manhattan , Kansas
If it were me... I would not bother. This is the engine matrix. The Cummins would be a conversion, and who knows what else is wrong. There are plenty of opportunities for those who wait. I would recommend identifying what combination you want, and what size you want based off of the engine chart, and target that.
1994 36' Classic Diesel Pusher
Vycan is offline   Reply With Quote
Old 01-08-2015, 04:19 PM   #4
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
That chart does not even list a 1983 motorhome. I believe that the Cummins was available in some models, but I could not tell you which.
Bill
Just my personal opinion
wkerfoot is online now   Reply With Quote
Old 01-08-2015, 06:36 PM   #5
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Rob
Are you messing around in the "Forrest" again? That's the only 310 Cummins I know of. He even sent me pics.
Cheers
Tony
Its a recession when your neighbor loses his job; its a depression when you lose your own. "Harry S Truman"
Old 01-08-2015, 06:41 PM   #6
Dazed and Confused
Isuzusweet's Avatar
Isuzu do make big 5.2L four cylinders in the W series GM medium trucks but the Isuzu in my 310 is the 6BD1A + Bae turbo, 5.8L 6 cylinder. Also used in excavators, generators on ships and hospitals and all sorts of other applications where durability is paramount.
Cheers
Tony
Old 01-08-2015, 07:06 PM   #7
cincinnati , Ohio
I asked for some pictures of the motor before I spend the time driving to see the mh.
Old 01-08-2015, 08:55 PM   #8
Waipio Rim's Avatar
1984 31' Airstream310
Honokaa , Hawaii
The 1989 model year for a 310 sounds wrong. The last year for 310's that I know of was 1984. Sounds like you will have to take a look to figure out what the guy has.
Waipio Rim is offline   Reply With Quote
Old 01-09-2015, 12:13 AM   #9
SebasSF's Avatar
1991 30' Airstream 30
San Francisco , California
Sounds cool, I would check it out for sure!
SebasSF is offline   Reply With Quote
Old 01-09-2015, 12:14 AM   #10
SebasSF's Avatar
Check to see if the generator is diesel as well.
Old 01-09-2015, 09:20 AM   #11
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
A Cummins diesel conversion that was done right is the ultimate Classic Moho. It will have good power and get better mileage than any other configuration.
It is certainly worth a look, they are rare birds.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 01-09-2015, 02:26 PM   #12
Dazed and Confused
Isuzusweet's Avatar
Yes and no....The Cummins especially the 12 valve is a lot noisier than my Isuzu turbo diesel. I would also take the Isuzu over the Cummins in build quality and durability (my local truck mechanics word, not mine) and filtration. That being said, it's easier to find parts for the Cummins and cheaper to make more power.
Cheers
Tony
Old 01-09-2015, 02:59 PM   #13
Vycan's Avatar
Manhattan , Kansas
Biggest issues with that particular find are:
1. Year and model do not seem to match.
2. Engine stated does not match the year.
3. Look at the page with all the pics, and pay close attention to the undercarriage pictures. That is some significant rust on something hauling significant weight.
Old 01-12-2015, 09:10 AM   #14
cincinnati , Ohio
With radio silence from the seller I may not get a chance for a look.
1982 turbo diesel 310 :: 2013 Airstream turbo diesel 310 mayco Airstream Registry Discussions 1 07-28-2015 11:58 AM
To Cummins or Not to Cummins?? Help!! On the brink! big_john Tow Vehicles 33 03-23-2010 08:20 PM
1984 Airstream 310 Motorhome Cummins Diesel NO RESERVE eBay Watch Airstreams on eBay 0 03-19-2010 09:10 PM
Cummins Diesel Upgrade to Classic MH Wayne Olson Classic Motorhomes 99 01-26-2008 05:59 PM
