Old 04-15-2013, 08:15 PM   #1
1987 34.5' Airstream 345
'87 345 Door Hinges
My 87 345 main door has hinges with way too much play in the pins so I can't really adjust it. At least one of the screws on each hinge won't tighten all the way so the nut is just spinning on the inside of the coach body.
With the play in the pins and not being able to tighten both screws an adjustment just won't hold.
Any clever ideas to fix what I have or, if I have to replace the hinges, a way to get to the nuts inside the door and inside the coach body without too much of a facelift or cutouts on the wall panels?
Once that's done I guess there is enough play in the mounts so a person could adjust the door so it fits in the casing and seals?
gmag is offline   Reply With Quote
Old 04-15-2013, 11:25 PM   #2
1989 34.5' Airstream 345
Silverton , Colorado
gmag,
An interim step to doing it right is to get some nylon washers(I forget the size), cut a wedge out of them, and slip them on the pin like a C-ring. This will adjust your play a bit...you might have to use more than one, and might have to insert them on both pins. I had to put two in the bottom, and one on top, but it worked well till we got it done...it needs 'doing' again...you will have to lift on the door whilst inserting them, or get someone to help with that...you also might check with bkahler(on the forums), as I think he was parting out a 345...m
Michael & Tracy
1989 345 Motorhome
CHARTER MEMBERS: FOUR CORNERS UNIT, AND PROUD OF IT!!!
We live for the moment, 'cause when you get there, it's gone...
ScrapIrony-2 is offline   Reply With Quote
Old 04-16-2013, 06:56 AM   #3
raveson's Avatar
boca raton , Florida
The easiest way to stablize the door hinges is to retighten the bolts from the inside. It sound worse then it is to do. If you drill out the rivets holding the door frame and remove it, you then can carefully peel back the interior skin and using a deep socket retighten the hinge. Even if you get hing replacements, you still have to get the bolts tight.
raveson is offline   Reply With Quote
Old 04-17-2013, 08:22 PM   #4
1991 30' Airstream 30
Lake Luzerne , New York
Door hinges
gmag:
Finally I can help another Airforum member! I just fixed my 300 LE this winter after reading all the postings and it wasn't too bad a job. I have the "carpet' interior, so I pulled it back, drilled 1" diameter holes very carefully right behind where the screws are and then dug out the putty they had put around the nuts. With the holes 1" diameter you can put in a socket wrench and tighten the new nuts & bolts. I replaced them all with stainless steel and added washers and nylock nuts. I will tray and attach pictures I took of the whole process. Getting all the old putty out was the worst part. (A right angle needle nose pliers worked the best). Being careful to get the holes as close as possible to the edge of the door trim inside was key to be able to get the socket on with minimal effort. I then finished the job with metal caps that you can get at the hardware or big box stores to fill in the holes and put the carpet back in place. They also sell plastic caps, but the metal ones have little "feet" that you can bend to help hold them in place if the hole is not true. Did the trick!. Good luck. ADK Jim
Name:	Hole Drill.jpg
ID:	183623   Click image for larger version
Name:	Holes Drilled & New Bolts.jpg
ADK Jim is offline   Reply With Quote
Looking for parts for our 345 vonprum Classic Motorhomes 6 02-04-2012 09:07 PM
Rear airbags on '87 345 - any tips or tricks moeriv Classic Motorhomes 6 11-15-2011 08:31 AM
345 Motorhome overheating. Myrtle lynn General Motorhome Topics 30 07-02-2011 09:28 PM
345 hinge pin pjude General Motorhome Topics 4 06-03-2011 08:00 PM
Parts needed - 345 Spare Tire Cover on rear, et.al. audiv8q Exterior Restoration Forum 0 02-24-2011 02:33 PM
