Old 12-19-2009, 02:41 PM   #1
1986 34.5' Airstream 345
Tyler , Texas
86 345 electrical problem
On a recent trip I lost 12V power to my water pump. I do not find an in line fuse or any other breaker. I checked the rocker switch and am not getting 12V power to the switch...is there a breaker or fuse that I am missing. All other 12V systems are in good working order.Pete
pjude is offline   Reply With Quote
Old 12-19-2009, 04:54 PM   #2
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Not sure how your 345 is wried, but maybe the water pump is on it's own fuse? Check all the 12 v fuses - pull them out if necessary and check them with an ohm meter. A fuse that visually looks good still may be blown.
Chris
Old 12-19-2009, 06:04 PM   #3
3 Dog Nite's Avatar
1989 34.5' Airstream 345
Cleveland , Tennessee
Pjude, you mentioned checking the rocker switch. Our MH has 2 switches. 1 in galley on range hood & 1 in head on wall. You might have a bad switch if you only checked 1 of 2 switches. I don't know which switch gets the power 1st. Check all 3 wires on both switches for live power. If none of the wires have power it's a supply problem. If you find power at 1 wire only, flip 1 switch & check all wires again. Flip the other switch & check all wires again. The switches are like a 3-way switch in a house. You can check them with a continuity tester. 1 of the 3 terminals of a switch is a common. It's usually the 1 in the middle. There should be continuity between the common & 1 terminal. After flipping the switch there will be continuity between the common & the 3rd terminal.
Ricky
"Sometimes I wonder if the world is being run by smart people who are putting us on, or by imbeciles who really mean it." Mark Twain
AIR 22749 WBCCI 2349 NOVA TAC TN-6
1989 345 LE Classic Motorhome
3 Dog Nite is offline   Reply With Quote
AC Electrical problem frscott Lights - Interior & Exterior 6 10-19-2009 11:21 AM
Electrical problems on '89 airstream 345 mater4 General Motorhome Topics 7 09-25-2009 09:39 PM
Electrical problem - 1965 Dr JJ 1965 - 1969 Globetrotter 3 06-17-2008 12:13 PM
345 problem. swinginping Classic Motorhomes 7 05-05-2008 04:07 PM
Electrical problem 345 pjude Airstream Motorhome Forums 5 07-10-2007 05:47 PM
