Old 02-17-2010, 09:19 PM   #1
1989 29' Excella
1982 31' Airstream310
Monroe , Georgia
82 310 Diesel fuel filler hoses
I have been trying to find locally the fuel filler rubber hoses.I have taken out the tank for sending unit repair and tank cleaning.Can you get these hoses or can you use radiator hoses with built in flex wire to keep it from kinking?This 310 isuzu has 60 gallon tank.Would this be a p30 part or a special item being a diesel.
Turbo nut is offline   Reply With Quote
Old 02-17-2010, 09:26 PM   #2
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
The filler hose material should be available at any good auto parts house. The filler on my 280 uses two short lengths of rubber hose a piece of steel tubing in the middle. I think the tank is Airstream sourced rather than GM.
Cheers, Dan
Old 03-02-2010, 05:01 PM   #3
Jamie
jking's Avatar
1984 31' Limited
Oriental , North Carolina
AS originally put rubber hoses in, but changed to reinforced hoses when problems developed. You can get the reinforced hoses from any good diesel shop. Maybe they'll even cut them to length for you. Make sure of connections - there's a lot of vibration and movement there when driving.
Jamie
jking is offline   Reply With Quote
Radiator Hoses for 1983 310 Billy B General Motorhome Topics 7 06-06-2016 05:59 PM
how? moho fuel filler hose mamanda Argosy Motorhomes 11 01-13-2014 09:14 AM
Fuel leak in the gas filler hose mrgump Airstream Motorhome Forums 5 04-04-2007 02:51 PM
Leaky fuel filler neck Ray Pena Argosy Motorhomes 8 06-20-2005 10:11 AM
