Old 05-15-2010, 09:14 AM   #1
1981 28' Airstream 280
Boise , Idaho
81 Motorhome storage compartment leaks
Has anyone had success stopping water from leaking into the road side storage compartments , I have installed a driprail above the opening seam and filled the holes left by the factory on the ends and replaced the seals, all in vain it appears , I am tempted to cut the bottoms loose give them a good rearward slope with drain holes so at least the water wont stand in the compartments
Dean Rawson is offline   Reply With Quote
Old 05-15-2010, 02:59 PM   #2
guy99's Avatar
1984 31' Airstream310
Dunsmuir , California
Images: 16
Can you post a picture? I managed to seal mine but I'm not sure if they are like yours.
1984 310 Limited Motorhome
guy99 is offline   Reply With Quote
Old 05-15-2010, 05:53 PM   #3
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
Where is it leaking, on the pull-out? You could have a leak in the copper lines up above. Mine leaked from a crack around the upper openings. Pic?
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 05-15-2010, 10:20 PM   #4
And mine was a split pipe behind the shower....
My floorsafe was full of water too!
Old 05-16-2010, 12:42 AM   #5
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
My 280 doesn't have pull outs or copper lines above. The doors are aluminum sheets formed into a curve to match the lower panel. No reinforcement or edge trearment of any kind. A simple "L" shaped rubber gasket and that's it. And yes they are not water tite.
I've thought of maybe an inner lip around the edge of the compartment and then drill some drain holes at the bottom of the door for the water to run out before entering the compartment.
Without a perfect fit and a reinforced edge or more clamps around the door edge I don't think a rubber gasket is going to do much.
Cheers, Dan
Old 05-16-2010, 08:18 AM   #6
Boise , Idaho
Sounds like Dan has been down this road , think I will just sand blast them and repaint and set them up for quick draining rather than picking a battle I can,t win
Thank's Dean
Old 05-16-2010, 09:01 AM   #7
The Hawk's Lair
cooperhawk's Avatar
1985 34.5' Airstream 345
BACK WOODS , Minnesota
I have battled with mine as well. I think most of my moisture is condensation and just can't be helped. Drain holes are probably a good idea.
AKA THE GUNNER
There is no "I" in the word "team," but there are four in "Platitude Quoting Idiot!"
AIRSTREAM 345 TURBO-DIESEL
VFW, LEGION, NRA
cooperhawk is offline   Reply With Quote
Old 05-16-2010, 09:56 AM   #8
Mike Leary's Avatar
Images: 11
Would someone post a pic? I'm confused (normal for me).
Old 05-16-2010, 10:00 AM   #9
Thank's Dean
It always amazes me how the lads at Airstream put so much effort into the design of some things and so little into others. I think the storage doors were designed too late on a Friday afternoon.
Cheers, Dan
Old 06-09-2010, 08:09 PM   #10
cmadmaxman's Avatar
1982 31' Airstream 310
Columbia , Tennessee
Images: 37
Fixed my leak on my right pull out!
I got tired of my tools rusting away, so took out the right side pull out and started to work it over. I welded up all the holes, used 1" wide x 1/8 thick metal and MIG welded up a leak free lip. I also sealed up all the corners and the screws that hold the lid hinge on. Sealed where the lock goes into the lid as well. A lot of work, but no more leaks
Here is a shot of the old plastic bad idea for a storage bin. Next up the Left side!
Chris & Brenda, Members of the Christian Motorcyclists Association
AIR Member 12654
1982 310 MoHo
Many Years ago, 1972 Argosy 24' trailer
Our Toad, 96 Saturn SW2 (263,000 and still going )
cmadmaxman is offline   Reply With Quote
Old 06-11-2010, 11:04 PM   #11
You guys with the 310's ans 345's have those fancy pull outs. Us guys with 280's aren't so lucky. We just have a sheet aluminum door with a hinge on the bottom. The door swings down to expose a wet little hole in the bottom edge of the coach.
Nice repair/modification madmaxman.
Cheers, Dan
Old 06-12-2010, 06:55 AM   #12
raveson's Avatar
1989 34.5' Airstream 345
boca raton , Florida
Thumbs up!
Mine don't leak yet, but nice to know there is a solution when they do. Fantastic job!!!!
raveson is offline   Reply With Quote
Old 06-14-2010, 02:49 PM   #13
Kmpro
kmpro's Avatar
Lubbock , Texas
Angry 81 Motorhome storage compartment leaks
I thought I had sealed mine on both sides, but the last big rainstorm we went through the Driver's side got wet again. Not to worry though, I will get after sealing it again. I had sprayed it with spray undercoat on the outside as well as all those listed previously in this thread. Still shipped water though.
Mike
A Man has got know his limitations-Dirty Harry
That's Some Bad Hat Harry-Jaws 1978
kmpro is offline   Reply With Quote
Old 06-19-2010, 07:43 PM   #14
cmadmaxman's Avatar
Images: 37
Here is another shot of the completed project. Just had a 2 to 3 inch down pour and the box is nice and dry. Have not drove in a rain storm yet, but think that it should stay dry. Will keep my fingers crossed!
ID:	105206   Click image for larger version
AIR Member 12654
1982 310 MoHo
Storage Compartment Locks - 1968 Jim Clark 1965 - 1969 Globetrotter 14 11-08-2017 08:05 AM
Bumper Storage Compartment LHall Bumpers & Bumper Storage 16 06-18-2015 02:26 PM
light in storage compartment janiemerle Lights - Interior & Exterior 3 03-15-2010 04:11 PM
Storage Compartment Leaks timmy67 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 08-17-2008 09:00 PM
Bumper storage compartment BillTex Bumpers & Bumper Storage 5 01-23-2007 03:27 PM
