Old 11-27-2010, 04:05 PM   #15
Awsome Job Chris!
Did that stop the leaks, or any other mods?
I have leaks in all mine.
For starters i need to replace the seals between the lid and body,, but did you find it was the joints that were the leak culprets?
If so, and welding it did the trick, I will go for that too!
On mine the lids hinge from the back edge, but I think the basic principle is the same.
I was thinking about doing Herculiner for the inside ansd underside... Do you think that will work?
Also, I have not looked close, but how do you get the drawers off/out of the M/H?
Old 11-28-2010, 09:04 AM   #16
cmadmaxman's Avatar
1982 31' Airstream 310
Columbia , Tennessee
Images: 37
Welding drawers
Thanks Keyair.
The original plastic, can I say just worked OK. After the years and they started to crack and break, water was allowed to leak into the top through all the joints not fully welded up. Welding up the joints worked best for me. I have a small MIG welder that keeps the heat to a minimum. Stitch welding helps as well, but there is still some warping of the metal. The full weld of the lip is the most important part of this.
I also used Polyurethane caulk on the inside joints and the top joint where the top and sided meet the front cover.
I think the Herculiner would be a great idea. Wish I would have thought about that. I will use that on the left side big drawer when I do that.
Seal all screws when you but the hing back on.
You have to unbolt the slides from the drawer, then if you want to take them off completely, you can clean them up from years of road junk, and re-lube them.
Good luck dude! Let us know how it goes.
Chris & Brenda, Members of the Christian Motorcyclists Association
AIR Member 12654
1982 310 MoHo
Many Years ago, 1972 Argosy 24' trailer
Our Toad, 96 Saturn SW2 (263,000 and still going )
cmadmaxman is offline   Reply With Quote
Old 11-28-2010, 10:00 AM   #17
Will do.
I have two levels going on... stuff I can only do at or on the Airstream in storage, and stuff I can pull off and do at home... this is the latter, and I like these, cos I can work on them for 10 mins or 2 hours, whatever I have time for.
I did the bed on my old Chevy Pickup about 2 years ago with the Herculiner kit, and was pretty impressed with how easy it was.
Ready:
Coat 1:
C
I still think it was a bit "thin" and would have liked to add another coat, but it has really stood up to a lot of abuse, and has only broken thru when I dragged/pushed my cherry picker in and out, and even then only slightly.
It should handle this "light duty" job with ease, and the textured finish with help stuff grip and not slide too much.
I recently picked up a barely used 110V Snap-On 140A Mig welder, and I also have the Mig Spool Gun for Mig welding Aluminum, and the DC Tig for steel(DC can't do Aluminum) attachment as well. To buy this setup new would have been $5k plus, and I got it for a song! It is HUGE, because it has a big fan and heat sinks(100% duty cycle).
Sounds like a great "Practice Project" for the Mig and Tig!
Here she is:
Old 11-29-2010, 12:07 PM   #18
cmadmaxman's Avatar
Images: 37
Sweet
Sounds like a great project to get some practice on the new welder. I have the small 110 Lincoln that is a 110v and have a 175 Lincoln inverter AC, DC and reverse DC that runs on 220v. It has the air cooled torch w/peddle control. Would like to have the liquid cooled line, but I don't push it that high. It's smooooth to weld with! I use straight Argon gas so swapping from Aluminum to Steel is no problem.
Keep us posted on your progress.
AIR Member 12654
1982 310 MoHo
Old 11-29-2010, 12:16 PM   #19
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
My slides on the roadside compartment pull-out have lost the bearings, has anyone replaced the slides, is it a bearcat?
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 11-29-2010, 10:45 PM   #20
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
Basement leak
Originally Posted by Dean Rawson View Post
Has anyone had success stopping water from leaking into the road side storage compartments , I have installed a driprail above the opening seam and filled the holes left by the factory on the ends and replaced the seals, all in vain it appears , I am tempted to cut the bottoms loose give them a good rearward slope with drain holes so at least the water wont stand in the compartments
Not sure what you guys have for hinges but I found silicone spray solved my problem on Clipper.
http://www.airforums.com/forums/f313...eak-70444.html
Dave
Storage Compartment Locks - 1968 Jim Clark 1965 - 1969 Globetrotter 14 11-08-2017 08:05 AM
Bumper Storage Compartment LHall Bumpers & Bumper Storage 16 06-18-2015 02:26 PM
light in storage compartment janiemerle Lights - Interior & Exterior 3 03-15-2010 04:11 PM
Storage Compartment Leaks timmy67 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 08-17-2008 09:00 PM
Bumper storage compartment BillTex Bumpers & Bumper Storage 5 01-23-2007 03:27 PM
