Old 08-04-2010, 12:27 AM   #1
1981 28' Airstream 280
emeryville , California
81 Excella 280 Turbo Diesel - windshield and drivers side mirror mount?
So my room mates go to park their motorhome next to mine and managed to clip the left front end. The drivers side mirror mount broke in half and the drivers side windshield is broken. I'm supposed to be leaving on a roadtrip in 8 days - any idea where I should start looking for replacement parts? I'm guessing the windshield rubber will need to be replaced in order to install the replacement glass.
Argh.....
-don cain
dlcain is offline   Reply With Quote
Old 08-04-2010, 10:17 AM   #2
Argh.....
-don cain
Don, I feel for you. 8 days doesn't leave a whole lot of time to find the parts let alone getting the work done.
Can you post a picture of your mirror mount? That might help in identifying something that will work.
As for the window rubber I would definitely replace it while the opportunity exists. You shouldn't have to worry about replacing it again for many years to come.
Good luck!
Old 08-05-2010, 09:25 AM   #3
1989 34.5' Airstream 345
Silverton , Colorado
The windshield should be a relatively easy replacement(divided windshield, right?)...once again, the mantra is CHASSIS..."AIRSTREAM" will cost you a couple of days and $...GM coach with 2 windows should facilitate, but there are threads on this in this forums...replace the window rubber...it should be a relatively universal replacement, but Andy will know. The mirror may have to be modified until a replacement can be found, if you want original...in the meantime, hope you can patch enough to get out there...m
Michael & Tracy
1989 345 Motorhome
CHARTER MEMBERS: FOUR CORNERS UNIT, AND PROUD OF IT!!!
We live for the moment, 'cause when you get there, it's gone...
ScrapIrony-2 is offline   Reply With Quote
Old 08-05-2010, 09:44 AM   #4
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
Here's your chance to replace those old mirrors with a more up to date set.
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
'81 Excella Turbo Diesel air bag pressures? dlcain Jacks, Stabilizers, Lifting and Leveling 9 08-05-2012 11:34 AM
Drivers side window fogged keenstreamer Windows & Screens 0 08-13-2009 05:32 PM
What is the relay on the drivers side valve cover? RichardT General Motorhome Topics 4 03-18-2008 06:58 PM
Drivers Side Window Replacement vasellers Classic Motorhomes 5 05-08-2007 03:23 PM
Replacement windshield in 345? Outside Mirror? Curtis-79MH Classic Motorhomes 2 05-17-2005 09:59 AM
