Old 03-23-2013, 04:31 PM   #1
Registered User
1979 28' Airstream Excella 28
Boerne , Texas
79' motorhome gauge issue
Hello,
The Teleflex fuel and elect. charging gauges on our 79' motorhome are pegged to the right.
Any ideas?
DeanoT is offline   Reply With Quote
Old 03-23-2013, 05:15 PM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Originally Posted by DeanoT View Post
Hello,
Any ideas?
Not sure about the electrical charging gauge, but the fuel gauge is probably a short-circuit in the sending unit inside the fuel tank.
But it's a lot easier to remove the gauge from the dashboard and check it than to remove the sending unit from the tank to check that. So, start by checking for a short-circuit in the gauge itself, THEN tackle the sending unit in the tank if the gauge isn't the culprit.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 03-23-2013, 06:26 PM   #3
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
Hello,
Any ideas?
try to connect a fresh ground wire and see if it fixes the problem
1996 Airstream B190
1987 29' Sovereign Trailer
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 03-24-2013, 04:58 PM   #4
Registered User
Boerne , Texas
The gauge appears to be the issue. Any suggestions where to find a replacement? There are no markings or part numbers to match to.
Old 03-24-2013, 06:04 PM   #5
Forget part numbers. Just take the old one to the auto parts store of your choice, and get one of the same diameter that will fit the hole in the dash.
WBCCI #1105
TAC LA-4
Old 03-24-2013, 08:15 PM   #6
DeanoT,
Can you post a picture of the gauge? As near as I can tell Airstream used at least two different styles of Teleflex gauges. The later coaches (i.e. somewhere around 84 and up) used the XL line of gauges and the earlier coaches used the Eclipse line of gauges.
Eclipse series
Exclipse series
Fuel and voltage - Eclipse series
I couldn't find a current listing for an XL fuel gauge but they do show up from time to time.
Good luck!
Old 03-24-2013, 08:59 PM   #7
Blue Eye , Missouri
Fuel gauge is the same one's used in boats. Check with local boat dealers for a replacement. Collaw RV salvage has some also.
stfennema is offline   Reply With Quote
Old 03-25-2013, 10:22 AM   #8
Registered User
Boerne , Texas
Hi Brad,
Attached is a pic of the gauge.
Old 03-25-2013, 10:54 AM   #9
Hi Brad,
Wow, that ones different than any of the others that I've seen. I quickly went through all of the Teleflex fuel gauges currently on ebay and this is the closest that I found to yours.
Teleflex Sterling gauge
I would suggest contacting Veethree instruments below:
Technical Service:
Marcin Maleszka
941-538-7775 ext 350
marcin.maleszka@veethree.com
I'm not sure what else to suggest other than possibly buying a different Teleflex fuel gauge to see if it works with your system.
Good luck!
Old 03-25-2013, 11:33 AM   #10
Registered User
Boerne , Texas
Thanks Brad,
