Old 11-29-2014, 03:27 PM   #15
1995 36' Classic 36
Ludington , Michigan
That's a dilemma! I need some sort of a prioritized load center. Something that would disconnect the hot water element if the load maxed.
Kota is offline   Reply With Quote
Old 11-29-2014, 03:47 PM   #16
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
My boat had an Atwood 6 gal with engine heat exchanger and electric..worked fine for the 16 years I had the boat. Makes sense that a MH would have a heat exchanger in it...free hot water.
Larry
lsbrodsky is offline   Reply With Quote
Old 11-29-2014, 06:59 PM   #17
3 Dog Nite's Avatar
1989 34.5' Airstream 345
Cleveland , Tennessee
I love mine. It's great to take a hot shower after a long drive. It also makes it easier to do dishes after stopping for lunch during the trip.
Gregsch: If you haven't done it yet, my MH uses copper line from engine to area of water heater. It looks a lot like the thinner walled rolled copper tubing. They are connected by flexible heater hose that is common for autos.
tevake: I plan on getting the electric also version should I have to replace my current water heater. For the power i was going to tap off the isolated circuit that runs the 2nd A/C unit off the generator. There would also be a switch box that would automatically disconnect the generator when plugged in at a campsite. This circuit would be plugged into the extra 20 amp. This way I don't overload the 30 amp main circuit and would be able to keep the water hot at all times. Unless it's so hot I need both A/C's. I imagine there would have to be a switch between A/C and heater, but haven't given that much thought yet. Still dreaming/ planning ahead for that day.
"Sometimes I wonder if the world is being run by smart people who are putting us on, or by imbeciles who really mean it." Mark Twain
AIR 22749 WBCCI 2349 NOVA TAC TN-6
1989 345 LE Classic Motorhome
3 Dog Nite is offline   Reply With Quote
Old 11-30-2014, 05:56 AM   #18
wxbuoy's Avatar
1991 35' Airstream 350
Carriere , Mississippi
Send a message via Skype™ to wxbuoy
Ricki, Sounds like your install was re-done post factory. My came with rubber radiator hose (1"?) going all the way back to the hot water heater and heat auxiliary exchanger under the aft bench seat. I disconnected mine where it splits of the engine. Basically ran a hose from the output to the return isolating the engine. I was afraid of leaks in the 23 year old hose!
Dave and Felicia
wxbuoy is offline   Reply With Quote
Old 11-30-2014, 11:36 AM   #19
Gregsch's Avatar
1979 24' Airstream Excella 24
Tipp City , Ohio
tevake, My project has stalled temporarily but, I have finished the electric connections and the hot and cold connections. I have not fired it up yet but I assume it will work fine this way. My electric panel had several open spaces in the panel so I just added a dedicated breaker. I did a search on e-bay for the breaker needed and sure enough there were several listings for old used breakers that fit my 1979 breaker panel. If you do not have a open space for an additional breaker try searching for a 1/2 size breaker. I have done this on other projects. You just remove one full size breaker and replace it with two 1/2 size breakers.
ID:	227751   Click image for larger version
ID:	227753   Click image for larger version
Gregsch is offline   Reply With Quote
Old 11-30-2014, 01:16 PM   #20
Gregsch's Avatar
Tipp City , Ohio
This is a picture of the breaker panel in my shop. Several times I have added circuits. See the small breakers on the left. They are 1/2 size breakers used to gain space when adding circuits. Be forewarned the manufacturer knows what you are doing with them, and how few other options you have, so they are priced accordingly. Expect to pay 5 times as much for the thin breakers.
Old 11-30-2014, 01:36 PM   #21
2007 22' International CCD
Some breaker panels also prevent you from using thin breakers with notches in the bussbar ends the
Breaker goes on. No notch, no doubles. Ran into that a few times. Make sure box will take them.
KE4GNK/AE
rmkrum is online now   Reply With Quote
Old 12-01-2014, 06:02 AM   #22
Ebro , Fla Panhandle
Great suggestions for solving the electric supply issue.
So far the original breaker box is doing the job for my unit and I would like to stay with it if possible. Will look into the thinner breakers to see if one will squeeze in there.
Gregsch, wondering about the hose that runs from your inlet to the out let , is that a bypass?
Thanks Richard
tevake is offline   Reply With Quote
Old 12-01-2014, 06:30 AM   #23
1995 36' Classic 36
Adding a breaker generally isn't the problem. 50 amps is my problem. I need to have a priority selector, either manual or automatic between a AC unit and the electric hot water. Both roof AC units push it close to the max for either shore power or the generator.
Old 12-02-2014, 04:25 PM   #24
Gregsch's Avatar
Tipp City , Ohio
Richard, Yes that is a bypass. Bought it on ebay. The manufacturer is Camco. It comes in set with everything you need to complete the installation.
Old 12-05-2014, 12:48 PM   #25
1999 35' XL 355 w/slide
Arlington , Tennessee
Kota: 50 amps supplies 50 amps to both sides of the system so you have about 100 amps total. 12-13 amps for the electric hot water and less than 16 amps for AC still leaves plenty of room on either side. Of course, you can't run both on the generator output which is usually 20 amps on one side and 30 amps on the other.
tebreuer is offline   Reply With Quote
Rear heat exchanger water hose bypass ducatist2 Land Yacht/Legacy Motorhomes 5 03-24-2011 08:35 AM
Heater exhaust heat exchanger david686 Furnaces, Heaters, Fireplaces & Air Conditioning 3 07-17-2010 07:58 AM
Heat exchanger for moisture control? SilvrSausage Roof Vents, Skylights & Fans 3 10-13-2007 01:00 PM
19 Gal Black Tank Upgrade to 39 gal? Old_Town Waste Systems, Tanks & Totes 6 07-17-2007 03:21 PM
10 gal in a 6 gal Hole aviontt Water Heaters, Filters & Pumps 18 12-19-2003 06:23 PM
