Old 08-10-2016, 09:52 PM   #71
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
A big +1 on the RainX; the next best thing to a blown air system. I even use the rainX windshield washer fluid and give it a squirt just as the rain hits.
Get a bumper sticker on the back bumper that reads "I'll take the second on those who cut in front of me".
Keep your distance and take your time.
Cheers
Tony
ďItís a recession when your neighbor loses his job; itís a depression when you lose your own.Ē "Harry S Truman"
Old 08-11-2016, 05:37 PM   #72
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
So day 2 is coming to a close....very nice here at Virginia Highland Haven Airstream Park. I cleaned and replaced all of the rear exterior running lights and back uo lights including the license plate light....the lenses were so dirty on the inside that it looked like the bulbs were almost not lite. I also skimmed through both the Airstream manual as well as the Gillig chassis manual as the Gillig is quite different than the P-30 or P-32. While Debbie and I were resting we heard a very loud bang ....seemed like something hit the motor home....went outside and found nothing.....AHHHH but later I noticed the 21 foot road side window awning was flapping around AH HA...I found out that the spring inside the awning tube broke....GREAT!!!! now I have to figure how to roll it up and fasten it so it won"t open while we are driving tomorrow. I sent an E-Mail to Zip-Dee so I can order the parts....but no help for me today, will have to repair at home. Also finished sanitizing the three tanks today, Will post pictures of the campground later tonight. Regards, Bob
bobmiller1 is offline   Reply With Quote
Old 08-11-2016, 06:47 PM   #73
bobmiller1's Avatar
Finally got the wife out of her beauty rest to help me fasten the broken awning to the side of the Airstream, I used two industrial tie straps one fore and one aft....should be good to go. Also some pictures, Regards, BobClick image for larger version
Name:	ImageUploadedByAirstream Forums1470959116.751543.jpg
ID:	268846Click image for larger version
Name:	ImageUploadedByAirstream Forums1470959133.816442.jpg
ID:	268847Click image for larger version
Name:	ImageUploadedByAirstream Forums1470959150.866168.jpg
ID:	268848Click image for larger version
Name:	ImageUploadedByAirstream Forums1470959166.484031.jpg
ID:	268849Click image for larger version
Name:	ImageUploadedByAirstream Forums1470959181.046276.jpg
ID:	268850Click image for larger version
Name:	ImageUploadedByAirstream Forums1470959192.149325.jpg
ID:	268851Click image for larger version
Name:	ImageUploadedByAirstream Forums1470959205.530833.jpg
ID:	268852Click image for larger version
Name:	ImageUploadedByAirstream Forums1470959217.665780.jpg
ID:	268853. I'm thinking here for 2017.....early June....anyone interested ???
Old 08-12-2016, 07:19 PM   #74
bobmiller1's Avatar
Day 3 has come to a nice close....we left Virginia Highland Haven and traveled to Winchester, VA. To pick up the kids. We are now in Gettysburg, PA at Artilery Ridge campground for the night. Hopefully onto Hawley, PA. For tomorrow night. The 370 was great today with temps in the mid 90's. A re-core of the radiator will happen during the winters 1st stage work. Again we took all secondary roads limiting the speed to a constant 55. We did a couple of 15-20 mile runs on the interstates at 65, but the RPM's at that speed are pushing 3200-3300. To much for me and I seem to be enjoying the state roads more and more. The interstates are great if you want to get there fast....but what's the rush. Regards, Bob
Old 08-13-2016, 06:54 PM   #75
bobmiller1's Avatar
Day 4 is a carbon copy of day 3, we made it to Hawley at 7:00 PM after leaving Gettysburg at 10:00 AM. 97 degrees at 3:00PM today, drove SR611 through the water gap (Delaware) and SR447 through the Pocono's. It's amazing to see all of the resorts like Alpine Meadows, Mount Airy Lodge, Buck Hill Falls, and Penn Hills Resort all closed up and vandalized. I remember them all open as a kid and teenager. Tomorrow's short hop should get us home....a beautiful drive through Honesdale PA then around the great Pepacton resevoir to home up SR30. The left rear on the 370 is definitely low by about 1 1/2". I suspect a bad bag, mid-adjusted leveling valve or something else. The shocks are definitely shot. Tag axle brakes aren't even hooked up. When I put new tag axle brakes on the 325 I could never get them to work with the factory black box controller under the dash. I am going to try a regular trailer brake controller on the 325 to see if they will work, I don't see why they wouldn't . Regards, Bob
Old 08-13-2016, 11:19 PM   #76
streamquest's Avatar
1936 20' Clipper
1947 22' Liner
Curtis Wright
1989 37' Airstream 370
marshfield , Massachusetts
Bob,
Your assessment of the brakes and the relationship of engine temp and RPMs is exactly what I've experienced. Have any other 370 drivers chimed in on this? Short of repowering with a diesel, do you think a Gear Vendors would help?
Glad you're almost home. I can almost hear the sigh of relief when you pull into the driveway!
Charly
streamquest is offline   Reply With Quote
Old 08-14-2016, 05:58 AM   #77
bobmiller1's Avatar
Charly, rear end gear ratio is ideal right now for up to 55 MPH. The C6 transmission is heavy duty but is more prone to overheat failures than a 475 which we have in our 325's. My 370 reads 10 MPH faster than I am going but the RPM's are right on the money. Probably just a gear swap on the end of the speedo cable. The gear vendor option appears to be the way to go especially for the downhill descents. I think may right leg is actually larger now after this trip !
Old 08-14-2016, 10:19 PM   #78
1936 20' Clipper
1947 22' Liner
Curtis Wright
Bob,
I've always felt that my speedo is a bit optimistic, but I like what it's telling me so I'll leave it as is. I hate to think that I'm going even that much slower than every other car and truck on the road.
As for the brakes..... shouldn't they really be called something else if they don't actually stop you??? I think I'll change the rear brake light lenses to amber just so the following traffic doesn't get the impression that my speed is decreasing when they light up.
Old 08-15-2016, 07:01 AM   #79
bobmiller1's Avatar
Day 5 and we're done, a nice drive from Hawley, PA to home. Really great trip. Lots to do on the 370LE over the next few winters. My shop is at capacity now so no more acquisitions !Click image for larger version
Name:	ImageUploadedByAirstream Forums1471262432.012344.jpg
ID:	269117Click image for larger version
Name:	ImageUploadedByAirstream Forums1471262449.861822.jpg
ID:	269118Click image for larger version
Name:	ImageUploadedByAirstream Forums1471262469.392127.jpg
ID:	269119Click image for larger version
Name:	ImageUploadedByAirstream Forums1471262487.875635.jpg
ID:	269120Click image for larger version
Name:	ImageUploadedByAirstream Forums1471262505.512676.jpg
Old 08-15-2016, 07:52 AM   #80
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Holy crap bob!!
mayco is offline   Reply With Quote
Old 08-15-2016, 04:35 PM   #81
1986 34.5' Airstream 345
Alliance , Ohio
Yea, what Mike said.
mehes is offline   Reply With Quote
Old 08-15-2016, 07:06 PM   #82
Louisville , Kentucky
I think someone has a problem. Maybe there is a 12 step program in order.
oliver00 is offline   Reply With Quote
Old 08-16-2016, 02:06 PM   #83
1936 20' Clipper
1947 22' Liner
Curtis Wright
Holy cow Bob, You are either absolutely committed, or absolutely ready to be committed. What a shop!!!! We're all jealous!
Towing with 370 noiva General Motorhome Topics 12 07-29-2004 06:20 PM
Value of '89 370 LE noiva General Motorhome Topics 4 07-28-2004 05:54 PM
1989 370 Ford 460 Overheating ViewRVs Mechanics Corner - Engines, Transmission & More... 14 07-05-2004 04:46 PM
370 classic chiropup Airstream Motorhome Forums 7 01-11-2004 08:12 PM
