Old 11-09-2016, 07:11 PM   #113
Roswelll , Georgia
Parts for 370
Bob:
I recently purchased the 370 LE that was for sale in Georgia. It is in very good running condition, but it is also missing the dash AC components. Let me know what you find to work on this motorhome. I will need to replace all of the system as well.
Also, have you found any wiper blade refills to replace the OEM wiper blades?
Steve Curlee
Roswell, Georgia
bora77 is offline   Reply With Quote
Old 11-10-2016, 06:33 AM   #114
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
Great to here from you Steve, let me know exactly what you need for your dash AC and I will help as much as I can, do you plan on using the original R-12 like me or doing a conversion to R-134. Are you missing any components ? The wiper blades are available from any Napa store, will get the part number and post it later.
bobmiller1 is online now   Reply With Quote
Old 11-11-2016, 10:10 AM   #115
Roswelll , Georgia
Bob:
I am missing the compressor, evaporator, condenser, hoses and freon. A new engine was installed in this coach about 10,000 miles ago due to overheating. It seems the prior owner did not want to risk that again, so left off the AC components. I am not sure what the original components were for this system, and I could go with either R12 or 134.
Steve Curlee
Old 11-11-2016, 04:08 PM   #116
bobmiller1's Avatar
OK Steve....I need to see some photos of your 370LE if I am to help. The compressors are still readily available as is the condenser and the receiver/dryer. Are you sure that the evaporator is missing??? It is located in the dashboard forward of the passenger seat. If you are serious about fixing the dash AC, you might want to inspect your radiator because you will have to remove sanity 70 percent of the crap anyway to install the condenser. Regards, Bob
Old 11-11-2016, 04:22 PM   #117
bobmiller1's Avatar
Very heavy work weekend planned starting tomorrow...a double day, I'm in such a great mood now that a business man will be running the country instead of a politician ! Tomorrow we finish stripping the roof, remove the generator, remove the shower, and remove and replace all the heater hoses. New hot water heater is in..so we will be installing the new heater hoses to both the hot water heater, and the aux heater. New hoses also to the dashboard heater core as well as 2 new heater control valves. Sunday I will be stripping out all of the electrical AC components.....circuit breaker panel, the 2 original 30 amp transfer switches and the uni-volt. All the new components are in. Radiator should be back from the shop next week along with the AC condenser. The new roof AC units and related parts should be here as well but we still have to refinish the roof, so probably a Jan. 17 install on the roof related components. Steering box on it's way to MO. for rebuilding. New front brake rotors ordered this week along with new grease seals. Unfortunately the first road test is not scheduled until April, so I will not be able to tell if I am successful at eliminating the downhill brake shimmy until then. More pictures to follow over the weekend. Regards, Bob
Old 11-12-2016, 02:58 PM   #118
1986 34.5' Airstream 345
Alliance , Ohio
Hey Bob, when you get around to the shower door how about some step by step pictures. I wanted to take a good look at your 325 at this year's get together but was mesmerized by everybody's updates/changes. Too much to take in all at once. Typically the shower door jams I have looked at are about as wide as the wall of our shower is thick. Normally these jams butt against a wider wall covered with tile or whatever and a bead of silicone does the trick of sealing. In the case of our motor homes I'm not sure what happens. This is a project I want to get done soon and have been putting off for this reason. Running out of excuses if you know what I mean.
mehes is offline   Reply With Quote
Old 11-13-2016, 06:35 AM   #119
bobmiller1's Avatar
OK Lance, I will document the shower door removal and installation on the 370LE. It's my second go around as I did one already on the 325LE. I am not skilled at all in wood working...wish Tony lived closer...between my mechanical skills and his wood working skills we could have an awesome shop. A solid 12 hours in yesterday, finished removing the AC units from the roof, removed the generator, removed the shower drain/trap, installed all but 2 of the new heater hoses/clamps, test fit the new hot water heater and mapped out the circuit breaker wiring while removing the circuit breaker original panel.
Old 11-13-2016, 08:19 AM   #120
bobmiller1's Avatar
RClick image for larger version
Name:	ImageUploadedByAirstream Forums1479050315.020838.jpg
ID:	275348Click image for larger version
Name:	ImageUploadedByAirstream Forums1479050331.671476.jpg
ID:	275349Click image for larger version
Name:	ImageUploadedByAirstream Forums1479050345.535849.jpg
Old 11-13-2016, 08:21 AM   #121
bobmiller1's Avatar
Name:	ImageUploadedByAirstream Forums1479050373.285926.jpg
ID:	275351Click image for larger version
Name:	ImageUploadedByAirstream Forums1479050384.220338.jpg
ID:	275352Click image for larger version
Name:	ImageUploadedByAirstream Forums1479050396.020891.jpg
ID:	275353Click image for larger version
Name:	ImageUploadedByAirstream Forums1479050413.702180.jpg
ID:	275354Click image for larger version
Name:	ImageUploadedByAirstream Forums1479050429.368013.jpg
ID:	275355Click image for larger version
Name:	ImageUploadedByAirstream Forums1479050441.735652.jpg
Old 11-13-2016, 06:43 PM   #122
bobmiller1's Avatar
I finished removing the old electrical components from the 370LE today along with re-routing some of the wiring....now I can see what the finished product will look like. Final test fit of the new hot water heater done as well. Regards, Bob
Old 11-13-2016, 06:45 PM   #123
bobmiller1's Avatar
Name:	ImageUploadedByAirstream Forums1479087871.855004.jpg
ID:	275399 ....oops !
Old 11-13-2016, 06:48 PM   #124
bobmiller1's Avatar
Name:	ImageUploadedByAirstream Forums1479087938.188278.jpg
ID:	275400Click image for larger version
Name:	ImageUploadedByAirstream Forums1479087959.888014.jpg
ID:	275401Click image for larger version
Name:	ImageUploadedByAirstream Forums1479087981.055300.jpg
ID:	275402Click image for larger version
Name:	ImageUploadedByAirstream Forums1479087997.654775.jpg
ID:	275403Click image for larger version
Name:	ImageUploadedByAirstream Forums1479088017.006553.jpg
ID:	275404Click image for larger version
Name:	ImageUploadedByAirstream Forums1479088051.370217.jpg
ID:	275405Click image for larger version
Name:	ImageUploadedByAirstream Forums1479088069.267850.jpg
ID:	275406Click image for larger version
Name:	ImageUploadedByAirstream Forums1479088083.885127.jpg
ID:	275407Click image for larger version
Name:	ImageUploadedByAirstream Forums1479088101.722657.jpg
ID:	275408Click image for larger version
Name:	ImageUploadedByAirstream Forums1479088124.972313.jpg
Old 11-14-2016, 08:04 PM   #125
Vycan's Avatar
1994 36' Classic 36 Diesel
Manhattan , Kansas
Bob, is that an in motion satellite on your other coach? Do you find you actually use it?
1994 36' Classic Diesel Pusher
Vycan is offline   Reply With Quote
Old 11-14-2016, 09:04 PM   #126
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Originally Posted by bobmiller1 View Post
See your oops and raise you.
Just curious Bob......what is your subfloor material in that 370? Please don't say OSB.
Cheers
Tony
Its a recession when your neighbor loses his job; its a depression when you lose your own. "Harry S Truman"
1956 Bubble Restoration Start to Finish the544man 1955 - 1957 Bubble 361 04-13-2018 06:47 PM
Costalotta Start to Finish Happycampers All Argosy Trailers 153 07-14-2016 06:19 AM
Mirror Finish v. Satin Finish????? Eaglemate Cleaning, Stripping & Polishing 18 03-23-2014 10:49 AM
Streamalina's shell off Start to Finish! Streamalina Repairing/Replacing Floor &/or Frame 9 08-21-2010 05:13 AM
370 LE won't start Nick Danger Mechanics Corner - Engines, Transmission & More... 16 02-05-2005 08:32 PM
