Old 10-26-2016, 04:50 PM   #85
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
I purchased the 100 amp circuit breaker box that I will be using to finish out the 30 to 50 amp conversion. Having 100 amps of 110 AC volts makes it easy to isolate systems. I will be running one AC off of one bus bar and the other off the other bus bar. I can split the electric hot water heat, the microwave and the new 3 stage converter around so they can all be used at the same time without worry. This Sunday I plan to label out all the interior outlets....even the hidden ones behind the kitchen cabinets on the wall so I can label the new circuit breaker box correctly.
bobmiller1 is offline   Reply With Quote
Old 10-27-2016, 04:41 AM   #86
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Thats a great idea Bob. Ive never heard of anyone installing a 100amp panel. Sure gives you plenty of room to isolate circuits. Very cool
Mike
mayco is offline   Reply With Quote
Old 10-27-2016, 05:25 AM   #87
mayco's Avatar
So youre installing a 100amp panel but will the main be 100amp or 50amp? Youve got 50amp available to the coach correct? On your shore power cord? You can heat up both buss bars in the new panel but the main breaker will still be a 50amp? The new panel will be rated 100amp but youre still going to have only 50amp available?
Old 10-27-2016, 07:22 AM   #88
bobmiller1's Avatar
Mike, from what I understand at the campground when you plug into 50 amp service, it is 2 legs, 50 amps on each 110 leg, giving a total of 100 amps available, I never understood why the original 30 amp circuits were 10 gauge only and when you went to 50 amps the gauge became 6. Obviously 6 gauge can handle 50 amps. Using a 100 amp box gives me the flexibility to spread my circuit breakers out and isolate my systems.
Old 10-27-2016, 08:07 AM   #89
Vycan's Avatar
1994 36' Classic 36 Diesel
Manhattan , Kansas
Team,
Handy link for RV 50 Amp service specifics. http://www.myrv.us/electric/Pg/50amp_Service.htm
1994 36' Classic Diesel Pusher
Vycan is offline   Reply With Quote
Old 10-27-2016, 09:20 AM   #90
mayco's Avatar
Great link Vycan. I guess Im still fuzzy on what size main breaker youll have in your onboard panel, 50amp or 100amp. Either way you are protected at the service pole by a 50amp breaker which will trip if either of your hot legs calls for it. Didnt see reference to the main breaker in the link. It shows a 50amp double pull for your house sub panel outlet.
Grounding your onboard panel is another issue I dont think I get. In the old days, all ground and neutrals tied to the same bar in the panel. Not so anymore. Separate bars. Is your new panel ground tied to the ground bar in the panel or does it tie to the skin?
Old 10-27-2016, 11:34 AM   #91
2007 22' International CCD
For an RV, code requires safety earth (green ground wire tied to chassis) and power neutral (white wire) to be separate. They are tied at the pedestal or main panel outside the AS. It's a safety item and must be done that way for shock protection, especially on an aluminum bodied AS.
Old 10-29-2016, 07:27 PM   #92
bobmiller1's Avatar
Well.......it is official.....the nose is off the 370LE ! The 370LE is definitely going to be my last one..... did I say that before ??? She kicked my butt today....got about 7 nice cuts. On a scale of 1 to 10 I give this job an "11" for difficulty.... 12 hours today, removed the steering box, front brakes, rotors.....need seals, need rotors, oh and did I say remove the radiator ??? never again, never, never , never. 3 times more difficult than the 325 LE. I had to remove the entire wiring harness of the 370, not to mention the electric cooling fans, transmission cooler, oil cooler, AC condenser. The wiring is a mess.....glad I started on it now, I'm going to need three months to get this mess sorted out and re-installed correctly. Pictures to follow. Regards, Bob
Old 10-29-2016, 07:31 PM   #93
bobmiller1's Avatar
Name:	ImageUploadedByAirstream Forums1477790940.726425.jpg
ID:	274493Click image for larger version
Name:	ImageUploadedByAirstream Forums1477790959.092365.jpg
ID:	274494Click image for larger version
Name:	ImageUploadedByAirstream Forums1477790981.629505.jpg
ID:	274495Click image for larger version
Name:	ImageUploadedByAirstream Forums1477790995.094711.jpg
ID:	274496Click image for larger version
Name:	ImageUploadedByAirstream Forums1477791014.242296.jpg
ID:	274497Click image for larger version
Name:	ImageUploadedByAirstream Forums1477791029.675041.jpg
ID:	274498Click image for larger version
Name:	ImageUploadedByAirstream Forums1477791045.760462.jpg
ID:	274499Click image for larger version
Name:	ImageUploadedByAirstream Forums1477791061.523598.jpg
ID:	274500Click image for larger version
Name:	ImageUploadedByAirstream Forums1477791079.611709.jpg
ID:	274501Click image for larger version
Name:	ImageUploadedByAirstream Forums1477791095.642590.jpg
Old 10-29-2016, 11:59 PM   #94
streamquest's Avatar
1936 20' Clipper
1947 22' Liner
Curtis Wright
1989 37' Airstream 370
marshfield , Massachusetts
Yikes!!!
Bob, You have definitely traveled beyond the outer marker now. Are you sure that you will ever get Humpty Dumpty back together?
Just kidding, but if someone told me that the Hope Diamond was hidden behind my radiator, I swear that I would start at the rear bumper and work my way forward through the black tank, rather than go through all that stuff from the front..... because at least I understand what's in the black tank.
streamquest is offline   Reply With Quote
Old 10-30-2016, 12:07 AM   #95
1936 20' Clipper
1947 22' Liner
Curtis Wright
Bob, Just as a for instance.....
What's that black thing with the wheels and the blue plastic bag sitting on top of it??? I can't recall seeing anything like that in my engine bay, but I can imagine that it made for some odd noises going down the road!!
Charly
Old 10-30-2016, 06:22 AM   #96
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
Bob, wow.... You have my admiration, I think
Are you sure it was not possible to pull the radiator out from underneath, like in the late 70's, early 80's GM models?
According to your description, a shop would have to charge 3-4k for a radiator replacement.
1991 25' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 10-30-2016, 06:48 AM   #97
bobmiller1's Avatar
Alright...I'm much calmer now...had a good sleep. No way to get the radiator out from below, period. I would have done anything else if I could have. I can't even explain to you how they put this thing together. Now I know why when they changed the engine back in 2006, they pulled it out of the bottom. As they assembled the 370LE they welded tabs on to hold various items or brackets. The transmission cooling lines are almost impossible to get to. I am really going to have to re-engineer this thing to put it back together so that it is possible to service in the future. I cannot even explain the wiring.....I took lots of pictures and downloaded them to my computer and a jump stick in the event I had lost my phone or dropped it in the toilet or my computer crashed or something like that ! Previous events which all happened to me. Today I am just going to clean up things in the shop.....smoke alot of cigarettes and drink some more coffee.....maybe dream of driving the 370LE to the next "Get- Together". Regards, Bob
Old 10-30-2016, 09:59 AM   #98
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
I think I'd rather kick a Giant Asian hornets nest (https://en.wikipedia.org/wiki/Asian_giant_hornet) or take on a village of Taliban by myself than tackle what you've done...........
I understand the whole concept of trying to put right the way it should have been done in the first place, but then there are times to let sleeping dogs lie. Bob here just kicked a pack of rabid pit bulls.
Goodluck..........you may as well do the diesel conversion now, and wire for it.
Cheers
Tony
Its a recession when your neighbor loses his job; its a depression when you lose your own. "Harry S Truman"
1956 Bubble Restoration Start to Finish the544man 1955 - 1957 Bubble 361 04-13-2018 06:47 PM
Costalotta Start to Finish Happycampers All Argosy Trailers 153 07-14-2016 06:19 AM
Mirror Finish v. Satin Finish????? Eaglemate Cleaning, Stripping & Polishing 18 03-23-2014 10:49 AM
Streamalina's shell off Start to Finish! Streamalina Repairing/Replacing Floor &/or Frame 9 08-21-2010 05:13 AM
370 LE won't start Nick Danger Mechanics Corner - Engines, Transmission & More... 16 02-05-2005 08:32 PM
