Old 03-17-2019, 05:09 PM   #897
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
We spent 10 hours yesterday and ran about 140 of new steel line under the 370LE, all of the brake lines, fuel lines, and EVAPORATED lines have been replaced, the fuel tank is almost ready to be re-installed. The transmission shift linkage is now installed. I am starting on the computer install for the transmission. I hope to finish the fuel tank and reinstall the fresh water tank next weekend. We should be ready to start her up sometime in April and get a few road tests in. Regards, BobClick image for larger version
ID:	335906Click image for larger version
ID:	335907Click image for larger version
ID:	335908Click image for larger version
ID:	335909Click image for larger version
ID:	335910Click image for larger version
ID:	335911Click image for larger version
ID:	335912Click image for larger version
ID:	335913Click image for larger version
ID:	335914Click image for larger version
bobmiller1 is offline   Reply With Quote
Old 03-18-2019, 11:15 AM   #898
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
How did you get that frame so clean Bob? Did it come to you in that condition or did you clean it?
mayco is offline   Reply With Quote
Old 03-18-2019, 04:53 PM   #899
bobmiller1's Avatar
Special Snap-On frame cleaner and preserver.....need you ask ????? Regards, Bob
Old 03-18-2019, 06:41 PM   #900
bobmiller1's Avatar
In case you wanted some.....Click image for larger version
ID:	336027Click image for larger version
Old 03-20-2019, 02:00 PM   #901
bobmiller1's Avatar
I promised myself that I would not order the “Grote” LED headlights until I put the grill back on, well the grill goes back on this weekend, so I will be ordering the lights ! I started to install the TPS to the carburetor only to find out that the Holley kit that I bought will not work on the motor craft Holley that’s on the 370 LE. So Saturday one of my customers is going to TIG up some new brackets for me so it will work. The new transmission shifts by computer and needs to see throttle angle, so this is not optional. Other than that we’re installing all new stainless/rubber clamps on all the new and old lines underneath. Going to start to insulate the rear floor above the fuel tank before that goes back in. I have also made progress on installing some of the electrical circuit for the new inverter. Regards, BobClick image for larger version
ID:	336145Click image for larger version
ID:	336146Click image for larger version
ID:	336147Click image for larger version
ID:	336148Click image for larger version
Old 03-20-2019, 09:26 PM   #902
1986 34.5' Airstream 345
Londonderry , New Hampshire
It looks like your existing electric choke module has some cracks in
it. You might want to check that out.
I will be interested in seeing how you mount the shift sensor.
Air345Fly is online now   Reply With Quote
Old 03-23-2019, 04:56 PM   #903
bobmiller1's Avatar
TIG work on the choke/TPS brackets all done....4 hours, well worth it. A big shout out to my customer Greg “Datsun” at Clayton’s Autobahn Repair in Albany for working with me and fabricating the brackets I needed to make this project work. This is one of the reasons I won’t retire.....because of all of my contacts through the business! I stopped earlier in the day at Albany RV (RV One) and ordered the electric pedestal base for the dinette. They recently became an Airstream dealership and what a classy place it is. Special thanks to the Airstream specialist there (Tom Collins) he was more happy to meet me, says he has heard of me through the Grapevine, I wonder if that is good or bad ??? Go figure.....Regards, BobClick image for larger version
ID:	336354Click image for larger version
ID:	336355Click image for larger version
ID:	336356Click image for larger version
ID:	336357Click image for larger version
ID:	336358Click image for larger version
ID:	336359Click image for larger version
ID:	336360Click image for larger version
ID:	336361Click image for larger version
Old 03-23-2019, 05:56 PM   #904
mayco's Avatar
That's some beautiful detailed work. Looks great
Old 03-24-2019, 06:49 AM   #905
Nice work Bob!
Ever thought about renaming this thread “From Start to Infinity!”
Old 03-24-2019, 05:18 PM   #906
bobmiller1's Avatar
I have the new carburetor brackets all primed and painted.....the grille is back on, decided to paint it....a lot of angles, so I figure 3 tape jobs to get it right, in the pictures all of the bright work is taped off.....I should have one of the new outlets finished for the new inverter later tonight and will test it out. Will start insulating the floor this week before the fuel tank goes back in. Regards, BobClick image for larger version
ID:	336430Click image for larger version
ID:	336431Click image for larger version
ID:	336432Click image for larger version
ID:	336433Click image for larger version
Old 03-24-2019, 08:05 PM   #907
mayco's Avatar
Nice work Bob!
I like it!
Old 03-24-2019, 09:27 PM   #908
What ya doing for insulation Bob????? We are watching!
Old 03-24-2019, 09:56 PM   #909
bobmiller1's Avatar
First round of the grill work came out quite pleasing ! The second round was the finishing touch, now ready for the Grote headlights (LED) ! The carb is already, just waiting to install the choke thermostat.Click image for larger version
ID:	336476Click image for larger version
ID:	336477Click image for larger version
ID:	336478Click image for larger version
ID:	336479Click image for larger version
ID:	336480Click image for larger version
ID:	336481Click image for larger version
ID:	336482Click image for larger version
ID:	336483Click image for larger version
ID:	336484Click image for larger version
Old 03-24-2019, 09:58 PM   #910
bobmiller1's Avatar
I also finished the install of the first of three inverter outlets, the one pictured is on the side of the TV stand in between the 2 barrel chairs !Click image for larger version
ID:	336486Click image for larger version
ID:	336487Click image for larger version
1956 Bubble Restoration Start to Finish the544man 1955 - 1957 Bubble 361 04-13-2018 06:47 PM
Costalotta Start to Finish Happycampers All Argosy Trailers 153 07-14-2016 06:19 AM
Mirror Finish v. Satin Finish????? Eaglemate Cleaning, Stripping & Polishing 18 03-23-2014 10:49 AM
Streamalina's shell off Start to Finish! Streamalina Repairing/Replacing Floor &/or Frame 9 08-21-2010 05:13 AM
370 LE won't start Nick Danger Mechanics Corner - Engines, Transmission & More... 16 02-05-2005 08:32 PM
