Old 02-07-2019, 09:59 AM   #869
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
The new fuel pump is ready to be installed, I duplicated the optional factory rubber mounting system for quieter operation. The clearance is really close on the mounting bracket, so some filing is necessary, Regards, Bob
bobmiller1 is offline   Reply With Quote
Old 02-07-2019, 10:00 AM   #870
bobmiller1's Avatar
ID:	333083Click image for larger version
ID:	333084Click image for larger version
Old 02-10-2019, 06:14 PM   #871
bobmiller1's Avatar
I finished up the install of the new rear transmission cross member as well as installing 4 new Exide batteries, now that the engine start battery is up front, that allowed me to have all 3 batteries in the box for the house batteries. I’m sure that will make it possible for using more stuff while dry camping. Regards, BobClick image for larger version
ID:	333329Click image for larger version
ID:	333330Click image for larger version
ID:	333331Click image for larger version
ID:	333332Click image for larger version
ID:	333333Click image for larger version
ID:	333334Click image for larger version
ID:	333335Click image for larger version
ID:	333336Click image for larger version
ID:	333337Click image for larger version
Old 02-10-2019, 10:39 PM   #872
bobmiller1's Avatar
I finished the new wiring harness on the left side for the new fuel pump and the cooling fan on the auxiliary engine oil cooler. Click image for larger version
ID:	333382Click image for larger version
Old 02-12-2019, 01:57 PM   #873
bobmiller1's Avatar
Like I can’t leave well enough alone....I found the perfect 4000 watt inverter that will fit into the compartment next to the batteries.....I’ll have to pull down the new kitchen wall to install an inverter only outlet and the remote switch panel to turn it on and off. Since I now have 3 group 31 batteries now I’ll be able to set the coffee maker up at night and have my coffee in the morning. Some state campgrounds don’t allow generator usage before 8 AM and I am up at 6. My Coleman drip coffee maker is my back up but it won’t keep the coffee hot after it’s brewed.....Regards, Bob
Old 02-12-2019, 06:32 PM   #874
West Chester , Ohio
I love how coffee is your justification for this part of your project. Bob is a man with his priorities in order. I have a 3k watt inverter going in for the same reason☕️.
I’m intrigued about your 2-speed rear diff...how involved is this modification?
Kvsterling is offline   Reply With Quote
Old 02-12-2019, 06:35 PM   #875
bobmiller1's Avatar
Simple on the 370LE, because of the Spicer housing that Gillig used, its a bolt in job. The hardest part is to re-build the hubs so that they mate with the spindles on the new housing......basically a bearing and race swap so that I can still use the 6 hole polished Alcoa Rims, Regards, Bob
Old 02-13-2019, 08:32 AM   #876
1986 34.5' Airstream 345
Londonderry , New Hampshire
That raises an interesting question: is there a dual speed axle that
will fit my 345 with the standard 454 engine? It would be great
if there were a bolt in gear set for the Dana axle. Does such a
thing exist?
Air345Fly is online now   Reply With Quote
Old 02-13-2019, 03:01 PM   #877
bobmiller1's Avatar
You probably have the same Dana 80 that I have in my 89 325LE. I believe that there were 2 speed tears made for them but I am sure that they are all gone. You might find one in a country bone yard but sure to be used and abused. I lucked out because the Gillis chassis is completely different from the Chevy P32 chassis. What git me thinking about it is that the newer dodge heavy duty pick-up trucks use a Dana 110 rear end housing which is square not round. Regards, Bob
1956 Bubble Restoration Start to Finish the544man 1955 - 1957 Bubble 361 04-13-2018 07:47 PM
Costalotta Start to Finish Happycampers All Argosy Trailers 153 07-14-2016 07:19 AM
Mirror Finish v. Satin Finish????? Eaglemate Cleaning, Stripping & Polishing 18 03-23-2014 11:49 AM
Streamalina's shell off Start to Finish! Streamalina Repairing/Replacing Floor &/or Frame 9 08-21-2010 06:13 AM
370 LE won't start Nick Danger Mechanics Corner - Engines, Transmission & More... 16 02-05-2005 09:32 PM
