Old 11-08-2018, 05:42 PM   #785
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
I get worn out just reading your projects Bob.....the Snapon truck looks great. Are you painting that yourself?
mayco is offline   Reply With Quote
Old 11-08-2018, 06:05 PM   #786
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
Yes..,,imron
bobmiller1 is online now   Reply With Quote
Old 11-14-2018, 01:19 PM   #787
bobmiller1's Avatar
Still waiting on the replacement washer/dryer from PPL, no news yet......on a positive note my new transmission passed all the grueling dyno tests I had them put it threw before they ship it to me from Florida next Tuesday. Regards, Bob Click image for larger version
Old 11-14-2018, 04:54 PM   #788
bobmiller1's Avatar
Even better news.....the hydro-max has returned.....so I can re-install it on Sunday and if all goes well with the brake system, I’ll yank the transmission and fuel tank out and get going on with this project. Regards, Bob
Old 11-14-2018, 09:37 PM   #789
Churubusco , Indiana
Yank the fuel tank? Thought you were staying gas for another year?
1983 Airstream 310 Class A Motorhome
-Rob
Magnet18 is offline   Reply With Quote
Old 11-15-2018, 07:15 PM   #790
bobmiller1's Avatar
I picked up the hydro-max, brake fluid(DOT5), P/S fluid and some other odds and ends for Sunday’s work, hoping that the brake situation is finally resolved and I can move forward with the removal of the transmission/fuel tank/driveshaft etc. Regards, BobClick image for larger version
ID:	327951Click image for larger version
Old 11-16-2018, 08:52 AM   #791
1986 34.5' Airstream 345
Alliance , Ohio
DOT 5 or DOT 5.1? Just curious if you are going to a silicone fluid.
mehes is offline   Reply With Quote
Old 11-16-2018, 05:14 PM   #792
bobmiller1's Avatar
Switched over to DOT 5 last year Lance, I noticed a difference.
Old 11-17-2018, 10:04 AM   #793
Alliance , Ohio
So my understanding is DOT 5 is silicone based and not compatible with the normal glycol based fluids. Did you completely drain and flush the old fluid from all lines and components when you made the change? I probably missed it in your posts. You usually don't do anything half way so I guess you changed the calipers, master cylinder, etc. and so on. The DOT 5 fluid has a higher temperature rating which is quite important. I had an episode of overheating the brakes and hence boiling the fluid. I can tell you it was hair raising to say the least. I made the move to DOT 4 at that time when replacing my calipers.
Old 11-17-2018, 06:43 PM   #794
bobmiller1's Avatar
Complete flush job last year....about a gallon, did not replace the calipers, just rebuilt the master cylinder last week while the Hydro-Max was out for repair. The brakes get real hot on the 370LE as they do on the work truck. I noticed less brake fade, less squeaking, I believe that the boiling point on the DOT 5 is 500 degrees. Regards, Bob
Old 11-18-2018, 11:27 PM   #795
bobmiller1's Avatar
Hydro-Max reinstalled ! Got sidetracked and had to replace the water pump in the YukonXL.....It let loose on me on the drive home Thursday night in the snow. Also put the new nokian tires (studded) on the volt this afternoon as well, we have our snow early this year ! The 370LE brakes are all bled out now all I have to do is get a low pressure return line tomorrow and I can start it up and hopefully finish the brake job.....is it ever done ??? Regards, Bob
Old 11-19-2018, 05:27 PM   #796
bobmiller1's Avatar
Some Hydro-Max install pictures.....Regards, Bob Click image for larger version
ID:	328189Click image for larger version
ID:	328190Click image for larger version
ID:	328191Click image for larger version
ID:	328192Click image for larger version
Old 11-20-2018, 06:35 PM   #797
bobmiller1's Avatar
The brakes are all bled out, started it up this morning, bled the power steering out and wala the Hydro-Max works exactly as it should with no leaks ! Road test will not be until May, 2019. The new transmission left Florida today, I should have it next week. I will be pullling the C6 out as well as the driveshafts and the gas tank. Good news from PPL...it appears my replacement washer/dryer has been sitting in Albany for a week since the 10th, so I will keep my fingers crossed and pick it up tomorrow morning. I hope to have the dashboard out completely by the end of December. Regards, Bob
Old 11-22-2018, 08:46 AM   #798
bobmiller1's Avatar
First....I would like to wish everyone a Happy Thanksgiving ! (You to Dean). I want to take a moment to thank my good friends at PPL motor homes a “job well done” statement......you have to earn that from me. Unlike the other company that sells RV parts while they’re sitting in their parents living room in their underwear......When I received my WD2100XC it was damaged. I sent them pictures and they sent out a replacement right away. I want to thank the customer service department especially Joni and Kristina and they will be receiving 100% of my business from now on. Unlike the other company you can actually speak to someone. On I side note the hot water heater that I ordered from the other company for “Shephard57” which the incorrect one was received still sits on my loading dock for them to pick up since September.
1956 Bubble Restoration Start to Finish the544man 1955 - 1957 Bubble 361 04-13-2018 07:47 PM
Costalotta Start to Finish Happycampers All Argosy Trailers 153 07-14-2016 07:19 AM
Mirror Finish v. Satin Finish????? Eaglemate Cleaning, Stripping & Polishing 18 03-23-2014 11:49 AM
Streamalina's shell off Start to Finish! Streamalina Repairing/Replacing Floor &/or Frame 9 08-21-2010 06:13 AM
370 LE won't start Nick Danger Mechanics Corner - Engines, Transmission & More... 16 02-05-2005 09:32 PM
