Old 09-13-2016, 03:04 PM   #29
streamquest's Avatar
1936 20' Clipper
1947 22' Liner
Curtis Wright
1989 37' Airstream 370
marshfield , Massachusetts
Originally Posted by mayco View Post
Just what brand coffee do you drink?
I think the question should be.... What does he ADD to his coffee!
Bob, I'll get back to you with those numbers.
streamquest is offline   Reply With Quote
Old 09-13-2016, 06:12 PM   #30
2007 22' International CCD
Much better question...
Old 09-13-2016, 08:58 PM   #31
1936 20' Clipper
1947 22' Liner
Curtis Wright
370 closet
Bob,
The closet door measures 60" from top to bottom. The distance from the floor up to the low edge of the closet opening is 16". The platform (or bottom) of the closet is 6" lower than that edge, or 10" above the main floor. Mine seems to be in an original unmolested state. Could it have been a central vacuum? Hard to understand why the door is cut.
Did you find anything under that closet bottom? Just wondering why it's raised at all.
Old 09-14-2016, 05:59 AM   #32
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
I'm thinking ice maker.....does your closet have a 110 volt outlet mounted in the right rear corner ? The shelf above the closet floor was even with the butchering of the closet door leaving a 2" gap across the the bottom of the door. My guess is that was used for ventilation. Is your aux. heater still working in between the stove/oven and the furnace, and does your hot water heater still have the engine heater hoses going to it ? Making progress on the A/C system, but I think I am going to make a drive to Boston soon .....to many unanswered questions....I need about three hours looking at yours to answer what I need to know LMAO !!!! This one is really killing me.
bobmiller1 is offline   Reply With Quote
Old 09-14-2016, 10:06 PM   #33
1936 20' Clipper
1947 22' Liner
Curtis Wright
Hi Bob,
I do not have a receptacle in my closet as you show, but yours doesn't look like factory work. Or actually, maybe it does look like factory work.
Do you still have a 110v receptacle in the galley liquor cabinet (just forward of the closet) with the tambour door? I am thinking that the PO may have tapped power from there since it is essentially already "inside" the closet (covered by that plastic box).
Not sure of the status of my "aux" heater, or of how it is activated. I played with it briefly last year, but I haven't seen it produce any heat. The rear salon heating unit tries to fire up a pilot, but doesn't get any further. Gotta love that dash heater though. With the motor warmed up, it will heat the whole coach!!
The water heater still has the engine heater hoses running to it, and the aluminum tank gets hot to the touch after running the engine, but I haven't yet seen any hot water make it to a faucet. I am not under the impression that the hot water heater actually heats water.
It would probably make more sense for me to take a drive out to you. I'll try to put a couple of days together during the next couple of weeks. I could use a short road trip. Will keep you posted.
Old 09-15-2016, 02:51 PM   #34
bobmiller1's Avatar
That is exactly where they took the power from....don't need the outlet in the closet so it will be removed. Your aux heater has a two speed fan controlled by the aux heater switch (toggle) on the upper dashboard. Temperature is regulated by a cable marked heat by the heater itself. The cable runs to a heater control valve which is probably rusted open or closed. By a new plastic one and you will be good to go. If you can think about Columbus Day weekend, Cooperstown, NY (Hartwick Highlands camp ground) if you can make it, great. Traditionally my last outing for the year, great spot. We will get there Friday night and leave Monday mid day. If you can make it call them and pass my name tell them you would like one of the "F" sites if available. More later.....Regards, Bob
Old 09-15-2016, 04:28 PM   #35
bobmiller1's Avatar
I found myself in this junkyard this morning going through a 1989 ambulance.....found all of the brackets and AC compressor that I need along with the crank pulley. Also huge bees nest that I will deal with later with a flame thrower ( ahh....brings back memories) I promise pictures on this one if I'm not running away) All air bags in....shocks are in their way, brake pads, new wipers, two TV's.....and some other things.....it's never done. So listen, I have invited Charly to Cooperstown for the Columbus Day weekend.....if anyone wants to come let me know, we'll be there from Friday night through Monday. I am trying to get the 370LE back together, but if I can't I will be there in the 325LE. Regards, Bob
Old 09-15-2016, 07:17 PM   #36
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Now we know what Bob's spiking his coffee with.....napalm.
Remember Bob, bees (at least the honey guys) are fast becoming endangered in NA.
Cheers
Tony
ďItís a recession when your neighbor loses his job; itís a depression when you lose your own.Ē "Harry S Truman"
Isuzusweet is online now   Reply With Quote
Old 09-15-2016, 07:27 PM   #37
bobmiller1's Avatar
Well....there will be less to worry about when I'm done....plus I don't think there is any honey in this old ambulance.
Old 09-17-2016, 03:13 PM   #38
Vycan's Avatar
1994 36' Classic 36 Diesel
Manhattan , Kansas
Thanks for the invite. Going to be stuck at work without enough time to make the trip from KS.
1994 36' Classic Diesel Pusher
Vycan is offline   Reply With Quote
Old 09-18-2016, 05:24 AM   #39
bobmiller1's Avatar
Yesterday was a full press day on the 370LE. It's rare when I tell my guys that we're going to put a full day in on the Airstream instead of the work that we usually do. They know how much my Airstreaming thing means to me, so I get the extra effort from them. The one thing that I will always remember is that if you take care of your men they will take care of you. Never mess with their money or food and you're good to go. We finished up with the power 40' water reel, mounting, installing the inline check valve, rubber grommets for the holes, etc. The power cord reel (50 amp) is very heavy and working with the 6/4 wire is not easy by any means. We mapped out the electrical system to a blueprint so we know exactly where the 20/30 amp generator legs feed into the two transfer switches, the original 30 amp shoreline connection etc. Will be replacing the original 30 amp circuit breaker panel with a 50 amp, 2 leg panel....might also scrub the two original 30 amp transfer switches for a 50 amp, but being that the generator has two circuits one 20 amp and the other 30 amp, might just leave them alone. All disc brake calipers are off now as well as all the original shocks. All new front and rear air suspension bags are in......a very time consuming job, but well worth it. We also replaced the inner tube spring for the 21' L/S window awning. Not a difficult job except for removing the broken end piece from inside the tube which was stuck about 24" inside. Had we been able to tip the motor home up on end and shake, it would have been easier. I should have the remaining 4 wheels polished this week....Cooperstown is drawing close and I really would like to take the 370LE there. Regards, Bob
Old 09-18-2016, 05:26 AM   #40
bobmiller1's Avatar
Name:	ImageUploadedByAirstream Forums1474197951.084363.jpg
ID:	271856Click image for larger version
Name:	ImageUploadedByAirstream Forums1474197964.745308.jpg
ID:	271857Click image for larger version
Name:	ImageUploadedByAirstream Forums1474197977.644936.jpg
Old 09-18-2016, 03:46 PM   #41
bobmiller1's Avatar
I was going to the shop to relax today and you know what happens......6 hours later got a few more things done....shop and tools still a mess. I finished up the water connection from the new reel to the inside of the motor home under the bed, also hooked up the garden hose connection in the utility compartment. I finished repairing the black tank flush out....Charly, you will like these pictures of the wall cavity between the bathroom and the bedroom. I also finished installing the 45" septic hose holder which replaced the original 20" holder in the utility compartment. Did I mention re-newing the back up camera.....I did that to.
Old 09-18-2016, 03:51 PM   #42
bobmiller1's Avatar
Name:	ImageUploadedByAirstream Forums1474235269.525715.jpg
ID:	271936Click image for larger version
Name:	ImageUploadedByAirstream Forums1474235289.678365.jpg
ID:	271937Click image for larger version
Name:	ImageUploadedByAirstream Forums1474235304.197684.jpg
ID:	271939Click image for larger version
Name:	ImageUploadedByAirstream Forums1474235319.963383.jpg
ID:	271940Click image for larger version
Name:	ImageUploadedByAirstream Forums1474235335.409306.jpg
ID:	271941Click image for larger version
Name:	ImageUploadedByAirstream Forums1474235350.731022.jpg
ID:	271942Click image for larger version
Name:	ImageUploadedByAirstream Forums1474235367.908030.jpg
ID:	271943Click image for larger version
Name:	ImageUploadedByAirstream Forums1474235386.296260.jpg
ID:	271944Click image for larger version
Name:	ImageUploadedByAirstream Forums1474235402.860512.jpg
ID:	271945Click image for larger version
Name:	ImageUploadedByAirstream Forums1474235416.043866.jpg
ID:	271946Click image for larger version
Name:	ImageUploadedByAirstream Forums1474235427.962483.jpg
1956 Bubble Restoration Start to Finish the544man 1955 - 1957 Bubble 361 04-13-2018 06:47 PM
Costalotta Start to Finish Happycampers All Argosy Trailers 153 07-14-2016 06:19 AM
Mirror Finish v. Satin Finish????? Eaglemate Cleaning, Stripping & Polishing 18 03-23-2014 10:49 AM
Streamalina's shell off Start to Finish! Streamalina Repairing/Replacing Floor &/or Frame 9 08-21-2010 05:13 AM
370 LE won't start Nick Danger Mechanics Corner - Engines, Transmission & More... 16 02-05-2005 08:32 PM
