Old 09-02-2016, 04:14 PM   #15
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
Left rear water cabinet almost done.....front end up in the air....starting to strip down the air bags, shocks, etc. This weekend's plans to Lake Lucern got cancelled last minute (I really hate that) so I have 3 solid days to work on the 370 LE.Click image for larger version
Name:	ImageUploadedByAirstream Forums1472854391.163441.jpg
ID:	270600Click image for larger version
Name:	ImageUploadedByAirstream Forums1472854412.495450.jpg
ID:	270601Click image for larger version
Name:	ImageUploadedByAirstream Forums1472854425.563259.jpg
ID:	270602Click image for larger version
Name:	ImageUploadedByAirstream Forums1472854437.463182.jpg
ID:	270603Click image for larger version
Name:	ImageUploadedByAirstream Forums1472854450.281096.jpg
ID:	270604Click image for larger version
Name:	ImageUploadedByAirstream Forums1472854464.780406.jpg
bobmiller1 is offline   Reply With Quote
Old 09-02-2016, 11:56 PM   #16
rmuller's Avatar
Madison , Ohio
Looks nice, what did you use to paint the water cabinet, mine has considerable surface rust that I would like to slow down.
rmuller is offline   Reply With Quote
Old 09-03-2016, 05:55 PM   #17
bobmiller1's Avatar
I can tell you this...all the suspension parts on the 370LE are larger than the 325LE, and heavier. New microwave came yesterday as well as all the new light ballasts and lense covers. I got the front, rear, and tag axle shocks off today as well as the rear air bags. Since I am home for the holiday weekend I will get plenty of time in on the Airstream as well as finishing up some staining projects that I started in June LOL.Click image for larger version
Name:	ImageUploadedByAirstream Forums1472946772.504932.jpg
ID:	270719Click image for larger version
Name:	ImageUploadedByAirstream Forums1472946787.454806.jpg
ID:	270720Click image for larger version
Name:	ImageUploadedByAirstream Forums1472946799.770491.jpg
ID:	270721Click image for larger version
Name:	ImageUploadedByAirstream Forums1472946812.941521.jpg
ID:	270722Click image for larger version
Name:	ImageUploadedByAirstream Forums1472946824.002639.jpg
ID:	270723Click image for larger version
Name:	ImageUploadedByAirstream Forums1472946837.052225.jpg
ID:	270724Click image for larger version
Name:	ImageUploadedByAirstream Forums1472946851.536982.jpg
ID:	270726Click image for larger version
Name:	ImageUploadedByAirstream Forums1472946864.970497.jpg
ID:	270727Click image for larger version
Name:	ImageUploadedByAirstream Forums1472946876.489204.jpg
ID:	270728Click image for larger version
Name:	ImageUploadedByAirstream Forums1472946888.640933.jpg
ID:	270732Click image for larger version
Name:	ImageUploadedByAirstream Forums1472946903.252521.jpg
Old 09-04-2016, 05:49 PM   #18
bobmiller1's Avatar
Removed the left front air bag today...not an easy job to say the least. Finished up the install of the new 50 amp power reel and the 40 foot power water reel. No visible markings on the front air bag so I am going to have to take it to a buddy to see if he can match it up.Click image for larger version
Name:	ImageUploadedByAirstream Forums1473032808.636494.jpg
ID:	270816Click image for larger version
Name:	ImageUploadedByAirstream Forums1473032823.170173.jpg
ID:	270817Click image for larger version
Name:	ImageUploadedByAirstream Forums1473032835.384037.jpg
ID:	270818Click image for larger version
Name:	ImageUploadedByAirstream Forums1473032852.200351.jpg
ID:	270819Click image for larger version
Name:	ImageUploadedByAirstream Forums1473032870.768239.jpg
ID:	270820Click image for larger version
Name:	ImageUploadedByAirstream Forums1473032886.163965.jpg
ID:	270821Click image for larger version
Name:	ImageUploadedByAirstream Forums1473032941.131164.jpg
Old 09-04-2016, 09:00 PM   #19
Vycan's Avatar
1994 36' Classic 36 Diesel
Manhattan , Kansas
Nice work bob!
1994 36' Classic Diesel Pusher
Vycan is offline   Reply With Quote
Old 09-04-2016, 10:36 PM   #20
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
Bob this will help you identify you air spring. http://www.sdtrucksprings.com/identi...ir-ride-spring
They will also have the springs you need.
Cheers, Dan
~ Margaret Thatcher ~
Old 09-05-2016, 10:50 PM   #21
bobmiller1's Avatar
Today....Labor Day, Oh Yeah, lots of labor. Got most of the second coat of stain on the deck, had a nice chat with Charly on the phone...he sent me some pictures to start indentifying the AC compressor on the 370LE. I finished the install of the new microwave/convection oven and replaced all if the bad ballasts and lenses for the light fixtures. Going to try to finish up the front and rear air bags, shocks and brakes next.Click image for larger version
Name:	ImageUploadedByAirstream Forums1473137262.525150.jpg
ID:	270947Click image for larger version
Name:	ImageUploadedByAirstream Forums1473137274.890613.jpg
ID:	270948Click image for larger version
Name:	ImageUploadedByAirstream Forums1473137289.476297.jpg
ID:	270949Click image for larger version
Name:	ImageUploadedByAirstream Forums1473137304.574745.jpg
ID:	270950Click image for larger version
Name:	ImageUploadedByAirstream Forums1473137326.510045.jpg
ID:	270951Click image for larger version
Name:	ImageUploadedByAirstream Forums1473137340.126267.jpg
ID:	270952Also found a NIB Signal Stat 3600 which I replaced. The original was all corroded and did not work.Click image for larger version
Name:	ImageUploadedByAirstream Forums1473137434.153171.jpg
ID:	270953Click image for larger version
Name:	ImageUploadedByAirstream Forums1473137445.571305.jpg
Old 09-06-2016, 04:50 AM   #22
1986 34.5' Airstream 345
Alliance , Ohio
Say Bob, you better slow down or you will run out of things to do this winter. Lookin' Good!
mehes is offline   Reply With Quote
Old 09-08-2016, 05:52 AM   #23
Vycan's Avatar
Manhattan , Kansas
Looks pretty! How do you like the layout with the dinette instead of the L-shaped lounge with table?
Old 09-08-2016, 06:14 AM   #24
bobmiller1's Avatar
The L shaped dinette in my opinion was a loser, 3 people at best, 4 would be a tight fit. I said if they made a 370LE with a dinette booth I would buy one and "BANG" there it was for sale.....I hate when that happens......
Old 09-11-2016, 06:38 PM   #25
bobmiller1's Avatar
Put a solid 9 hours in on the 370LE today. One of my buddies (customer) came out and did the custom install on the Alpine 8" radio/navigation unit, the same one that we installed in the 325LE and the 396XL. He's been doing these installs for 25 years and he's been a great customer for the same amount of time. I finished mapping out the electrical install for the 50 amp conversion. I received the new 45" sewer hose holder which will be installed in the same location, the 370LE has more than enough room to accept that length. Installed the new screen door latch assembly and removed the medicine cabinet. Charly, you'll be happy to know that the black tank flush out is relatively easy to service through that cabinet opening. I had to remove the outer black tank flush door (same as the fresh water fill door) to remove the broken hose. Charly, I need another measurement (height measurement) of the closet door opposite the refrigerator, see in the picture. Someone modified the door by removing the lower 2-3" for reason I don't know, installed a 110 volt outlet in the closet and a wood platform about 6" above the carpeted floor. Next Saturday brings huge work to the 370LE, we will be stripping down the tag axle, replacing front and rear axle disc brake pads, front and rear air bags, all shocks, transmission flush, new filter and gasket, oil and filter change, trying to diagnose hard brake pedal and a few other things. I felt a little guilty today because I never sent the antenna that John wants, I had two extra...one is still his and I used the other for the 370LE today.
Old 09-11-2016, 07:39 PM   #26
bobmiller1's Avatar
Name:	ImageUploadedByAirstream Forums1473644219.942949.jpg
ID:	271528Click image for larger version
Name:	ImageUploadedByAirstream Forums1473644239.176284.jpg
ID:	271529Click image for larger version
Name:	ImageUploadedByAirstream Forums1473644255.280091.jpg
ID:	271530Click image for larger version
Name:	ImageUploadedByAirstream Forums1473644274.075181.jpg
ID:	271531Click image for larger version
Name:	ImageUploadedByAirstream Forums1473644287.528567.jpg
ID:	271532Click image for larger version
Name:	ImageUploadedByAirstream Forums1473644319.042338.jpg
ID:	271533Click image for larger version
Name:	ImageUploadedByAirstream Forums1473644359.194213.jpg
ID:	271534Click image for larger version
Name:	ImageUploadedByAirstream Forums1473644376.594221.jpg
Old 09-13-2016, 04:13 AM   #27
OttawaValleyGuy's Avatar
1991 35' Airstream 350
Barry's Bay , Ontario
Well Mr. Miller you truly are a unique person.
I have been following your posts on your 370 restoration.
Awesome, informative, accurate, and inspiring.
Thank you
OttawaValleyGuy is offline   Reply With Quote
Old 09-13-2016, 05:13 AM   #28
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Just what brand coffee do you drink?
mayco is offline   Reply With Quote
1956 Bubble Restoration Start to Finish the544man 1955 - 1957 Bubble 361 04-13-2018 06:47 PM
Costalotta Start to Finish Happycampers All Argosy Trailers 153 07-14-2016 06:19 AM
Mirror Finish v. Satin Finish????? Eaglemate Cleaning, Stripping & Polishing 18 03-23-2014 10:49 AM
Streamalina's shell off Start to Finish! Streamalina Repairing/Replacing Floor &/or Frame 9 08-21-2010 05:13 AM
370 LE won't start Nick Danger Mechanics Corner - Engines, Transmission & More... 16 02-05-2005 08:32 PM
