Old 03-12-2017, 10:04 PM   #241
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
I had to spend 8 hours with the rear bedroom dresser cabinet making everything fit....putting the front furnace in the rear bedroom in the dresser is definitely possible but it requires a lot of patience and nothing will fit the way it came apart so a complete redesign was necessary. Enough said....moving along to the refrigerator cabinet I finished the new floor install and mapped out the refrigerator baffle that Lance has recommended. I fired up both furnaces and they are good to go. This Saturday we will be re-installing the radiator and Sunday I will tackle the re-install of the wiring harness.....I think I am slowly losing my mind.....Regards, Bob
bobmiller1 is offline   Reply With Quote
Old 03-12-2017, 10:11 PM   #242
bobmiller1's Avatar
ID:	281352Click image for larger version
ID:	281353Click image for larger version
ID:	281354Click image for larger version
ID:	281355Click image for larger version
ID:	281356Click image for larger version
ID:	281357Click image for larger version
ID:	281358Click image for larger version
Old 03-13-2017, 04:37 AM   #243
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Well I guess if the girls want to borrow $20, you're easy to find!
mayco is offline   Reply With Quote
Old 03-13-2017, 05:01 AM   #244
1986 34.5' Airstream 345
Alliance , Ohio
"...I think I am slowly losing my mind...." It might not be as slow as you think. I hope you don't lose it completely before you finish the shower. I say this for selfish reasons. I'm interested in the door install. Stay sane my friend!
mehes is offline   Reply With Quote
Old 03-19-2017, 06:56 AM   #245
bobmiller1's Avatar
Just about done digging out the 31" of snow we got Tuesday....the second day I took off in 28 years because of snow...last time off it was 41". The radiator is back in, along with the AC compressor, condenser, oil cooler, and trans cooler, the hydraullic leveling control board is also mounted. The wiring harness will be next Saturdays mission, today I need a break from the Bear work so I am going to play with the cabinets and visit my buddy who is making the new shower seat assembly. I plan on re-installing the Kool-O- Matic fan today with the new rubber isolaters. Regards, Bob
Old 03-19-2017, 06:59 AM   #246
bobmiller1's Avatar
ID:	281659Click image for larger version
ID:	281660Click image for larger version
Old 03-20-2017, 06:29 AM   #247
bobmiller1's Avatar
I worked on fabricating the new radiator hoses Sunday, finished the re-install of the cabinets and drawers under the kitchen sink, dreamed about driving the 370LE down the road again....Regards,Bob
Old 03-20-2017, 06:33 AM   #248
bobmiller1's Avatar
ID:	281756Click image for larger version
ID:	281757Click image for larger version
ID:	281758Click image for larger version
ID:	281759Click image for larger version
ID:	281760Click image for larger version
ID:	281761Click image for larger version
Old 03-21-2017, 11:58 AM   #249
Vycan's Avatar
1994 36' Classic 36 Diesel
Colorado Springs , Colorado
Looking great Bob!
1994 36' Classic Diesel Pusher
Vycan is offline   Reply With Quote
Old 03-25-2017, 02:31 PM   #250
streamquest's Avatar
1936 20' Clipper
1947 22' Liner
Curtis Wright
1989 37' Airstream 370
marshfield , Massachusetts
Bob,
It's great to see all the progress. Getting the radiator back into place has got to be a huge step forward, and seeing the cabinets go back together makes things look almost livable.
So in terms of the title of your thread, where do you think you are along the path between "start and finish"? Hard to believe it's almost April!!
Charly
streamquest is offline   Reply With Quote
Old 03-25-2017, 03:12 PM   #251
bobmiller1's Avatar
Ah yeah Charly,,,was going to call you today....need to know where something goes and you're the only one I know with a 370LE. Wiring harness back in 95%...It was a battle as well as the radiator...finally got the stain figured out for the cabinets...I now own about 12 sample cans of stain. Kool-O-Matic back in and operational.....we will be working Saturdays and Sundays now on the 370LE because I am running out of time...the shower pan can really screw me if it is not done on time because the refrigerator and dinette cannot go back in until the shower is done. Everything else is moving along, more later, Regards,Bob
Old 03-25-2017, 03:16 PM   #252
bobmiller1's Avatar
ID:	282062Click image for larger version
ID:	282063Click image for larger version
ID:	282064Click image for larger version
ID:	282065Click image for larger version
ID:	282066Click image for larger version
ID:	282067Click image for larger version
Old 03-27-2017, 06:15 PM   #253
bobmiller1's Avatar
Wiring now 98% complete...just figuring out the OE A/C wiring as it was all disconnected/missing when I got it. Kitchen closet all back to original now and the refer cabinet almost all insulated. The roof is marked off for sanding, priming, and painting this weekend, will blow out the factory drain tubes and install the refurbished Kool-O-Matic and the new 15,000 Penguin AC units. Satellite pre-wire all done.Click image for larger version
ID:	282197Click image for larger version
ID:	282198Click image for larger version
ID:	282199Click image for larger version
ID:	282200Click image for larger version
ID:	282201Click image for larger version
ID:	282202Click image for larger version
ID:	282203Click image for larger version
ID:	282204Click image for larger version
ID:	282205Click image for larger version
Old 03-29-2017, 05:49 PM   #254
bobmiller1's Avatar
Thanks to my professional friends at Metal Supermarket in Albany, NY...Ann and Frank, they completed the refrigerator baffle and two replacement panels that I need to cover the 2 furnace exhaust outlets so I can keep going on the project in one day ! Great service!Click image for larger version
ID:	282350Click image for larger version
ID:	282351Click image for larger version
ID:	282352Click image for larger version
Old 03-30-2017, 07:38 PM   #255
Vycan's Avatar
Great going Bob!
Old 04-02-2017, 06:05 AM   #256
bobmiller1's Avatar
The roof project is well under way, all of the clear coat has now been removed, and the first stage of the etching primer is going on, all of the holes where the previous satellite cabling and main unit mounts have been filled with Lapp and stainless screws. I will be transferring the satellite system from the 325LE to the 370LE in a month or so. Still playing around trying to figure out the best fan belt to use with the AC compressor. Should also be done fabricating the upper radiator hose temp sensor today. I should be able to finish about half the roof today and want to get some more done on the refrigerator hole today as well. Regards, Bob
Old 04-02-2017, 06:10 AM   #257
bobmiller1's Avatar
ID:	282552Click image for larger version
ID:	282553Click image for larger version
ID:	282554Click image for larger version
ID:	282555Click image for larger version
ID:	282556Click image for larger version
ID:	282557Click image for larger version
ID:	282558Click image for larger version
Old 04-02-2017, 06:46 AM   #258
mayco's Avatar
Looks like a coooooool little early Bronco in front of the 396? You dog!
Old 04-02-2017, 02:14 PM   #259
bobmiller1's Avatar
Yup
Old 04-03-2017, 08:03 AM   #260
bobmiller1's Avatar
I have finished about 50% of the roof....need more material ! The refrigerator baffle is now installed, I was able to add 1" of insulation to the dinette side, 2" to the shower side and 3" on top. With the addition of the baffle and all the new insulation it will be interesting to see how the refrigerator now performs, and also the addition of the 2 fans in the roof vent should greatly improve operation, Regards, Bob
Mirror Finish v. Satin Finish????? Eaglemate Cleaning, Stripping & Polishing 26 09-14-2021 05:26 PM
1956 Bubble Restoration Start to Finish the544man 1955 - 1957 Bubble 361 04-13-2018 06:47 PM
Costalotta Start to Finish Happycampers All Argosy Trailers 153 07-14-2016 06:19 AM
Streamalina's shell off Start to Finish! Streamalina Repairing/Replacing Floor &/or Frame 9 08-21-2010 05:13 AM
370 LE won't start Nick Danger Mechanics Corner - Engines, Transmission & More... 16 02-05-2005 08:32 PM
