Old 08-21-2014, 08:47 PM   #99
Vycan's Avatar
1994 36' Classic 36 Diesel
Manhattan , Kansas
already have the mechanic sworn to retain old parts, and walk me through the process. so far impressed by their customer service, but their deadline is tomorrow. will see if they can meet it, and deliver on their promises.
1994 36' Classic Diesel Pusher
Vycan is offline   Reply With Quote
Old 08-26-2014, 07:34 AM   #100
Air Dog's Avatar
1995 36' Classic 36
Boulder , Colorado
Any news on the generator?
Air Dog is offline   Reply With Quote
Old 08-28-2014, 09:33 PM   #101
Vycan's Avatar
Manhattan , Kansas
did the work at cummins power south and could not be happier. the final price was 20% below the quote. the generator is running like a champ. it was oil build up in the propane lines and regulator from ears of no cleaning. the oil will bake in the lines at the heat exchange making a film, and will regulator diaphragms lose effectiveness from this same build up. the mechanic recommended servicing the generator every 150hrs with cleaner. so, all parts changed : regulator, heat exchanger, carburetor, throttle linkage retaining clip, and she's running like new. the tech who worked on it is named mike foley, and he said most places will not even service lp generators, because they are such a PITA.
Old 08-28-2014, 09:37 PM   #102
Vycan's Avatar
Manhattan , Kansas
to clarify, the oil comes from cheap propane fill locations who do not purge their tanks often according to the gents at cummins power south. also plug for cummins. joined the cummins power club for $20 annually, and saved me an additional 10% off parts and labor.
Old 08-29-2014, 06:39 AM   #103
Air Dog's Avatar
1995 36' Classic 36
Boulder , Colorado
360 Diesel Pusher
Sounds like a winter project for me. Mine has about 500 hours on it now and it runs great. Just made an appointment to get my transmission serviced. New filters and Allison synthetic. Ouch!
Just converted the inside to LED lighting. Pretty happy with the products from M4 LED Products.
Old 09-01-2014, 08:13 PM   #104
Vycan's Avatar
Manhattan , Kansas
First picture was a pit stop in Houston TX (00894)
Next picture was the view from an excellent Italian Restaurant next to NASA, I believe it was called Villa Capri (00915)
Next picture was the pier in Destin, Florida to access the Eglin AFB private beach there (00937)
Next picture was why our day at the beach was cut short (00936)
Next picture was the generator pulled for maintenance. They are actually very easy to work on if you have a 2 ton jack and a bolted on plate, or a transmission jack. Live and learn (00944)
Next picture is the front hub with centramatic balancer in plain view. This was when I decided to replace the front wheels of the moho after seeing an odd wear pattern on the front tires. Immediately scheduled an alignment shortly after and all is well again (00954)
The next picture is of us in front of Skyline Chili off of I-69 just northeast of Indianapolis. (00959)
The next picture is us pulling out of our family's driveway in Ohio on the next leg of our Journey (00958)
Based on all the stops, places stayed, and what we did during our vacation I did a price comparison from everything we spent.
Overall cost of the trip was $4,113.73 and 57.9 hours on the road.
Break down of costs:
1. $1,611.01 of unscheduled services and preventative maintenance. Specifically two front tires ($426.88 @ Byron Tire in Byron, GA), servicing the generator ($1,033.57 @ Cummins Power South in Ocala, FL), and aligning the front end ($150.56 @ Truck Service INC Noblesville, IN).
2. $1,403.95 to travel 4,018 miles towing a 2,500lbs SW2 for 11.07827 average MPG
3. $289.97 for 100.7455 gallons of propane at an average of $2.88/gal. Lesson learned to travel south during Fall, Winter, or Spring to avoid need for AC use at night. Houston was horrible with the humidity.
4. $786.30 for overnight stays, miscellaneous, grocery, restaurant, gas for the toad, and tolls.
If I had flown the route with my family it would have cost us $7,394.22 and taken a total of 63 hours of time. This time includes flight time, packing luggage from each point, arriving two hours early for security, and one hour on the back end for baggage claim and linkup with party picking us up, as well as transit time from locations of stay to the nearest airport.
Overall savings of $3,646.49 from costs incurred including the improving and upkeep of the motor home, and 5.1 hours less in transit. Then there is also the priceless aspect of knowing your accommodations everywhere you go. :-D
For the first vacation I have taken in two years. This was a steal. The thing I love about the Airstream, is vacations can now happen anytime I have three to four days off at a time, and that happens on average of once a month.
ID:	220539   Click image for larger version
ID:	220541   Click image for larger version
ID:	220543   Click image for larger version
ID:	220545   Click image for larger version
Old 09-02-2014, 07:58 AM   #105
Air Dog's Avatar
1995 36' Classic 36
Boulder , Colorado
Looks like an adventure! We plan our trips in the spring and fall to avoid the heat. In the summer we run up in the mountains. So far the only problem we've had on the road was a leaky radiator hose. Something I should have caught as soon as I bought it as all the hoses and the serp belt were rotten. Let me know if you ever take a trip out this way.
Old 09-02-2014, 11:25 PM   #106
Vycan's Avatar
Manhattan , Kansas
would love to, make the recommendation for campground and sites, and i can do any federal holiday weekend. willing to drive 6-8hrs.
Old 09-14-2014, 09:57 PM   #107
Air Dog's Avatar
1995 36' Classic 36
Boulder , Colorado
Service advisory
I've been going through my 360 one system at a time. I was going to flush the brake system and noticed that the boots on the caliper pistons were all deteriorated. The pistons, inner seals, pads, and rotors are all like new. The cracked boots will allow dirt and water to corrode and possibly freeze the pistons and caliper bores.
They were actually very easy to work on compared to most brakes I've worked on. I had to buy rebuild kits and replaced the pads since I had them apart. Parts were about $500 from Spartan for all 4 wheels. New calipers are about $800 each. Definitely worth the PM for avoided costs and safety.
Lost your EM. I can send you some pictures and part numbers.
Dave....
Old 10-30-2014, 10:57 PM   #108
Vycan's Avatar
Manhattan , Kansas
Latest development is purely aesthetic. We plan to do nose art on our 94, but by nose art we mean, the large aluminum blank space between the bedroom and kitchen/dinning area windows on both sides. The first attachment was the inspiration, the second is what we plan to put on the RV. We will also have large block letters of the coach's name "Diesel Donna" One word on top of the other, in a bold/italicized font. The 'diesel' will be a smaller font to cause a stepped look, and have the character sitting on the step. The step will be towards the front of the coach on the corresponding side so the character is facing forward.
Example:
DIESEL
DONNA
Any thoughts?
ID:	225422   Click image for larger version
Old 10-31-2014, 05:03 AM   #109
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Very cool, I love nose art.
mayco is online now   Reply With Quote
Old 11-15-2014, 08:10 PM   #110
Vycan's Avatar
Manhattan , Kansas
Latest Update:
1. Changed the nose art slightly. The missus and I agreed her right hand was a bit too provocative, so we had the artist re-position it.
2. Purchased a Banks Power Pack for the Cummins! Excited for spring to do the install.
Old 11-23-2014, 04:59 AM   #111
wxbuoy's Avatar
1991 35' Airstream 350
Carriere , Mississippi
Send a message via Skype™ to wxbuoy
Originally Posted by Vycan View Post
Latest Update:
Please post pics/ running commentary of the install! I am thinking about going that way myself.
Dave and Felicia
wxbuoy is offline   Reply With Quote
Old 11-23-2014, 10:22 AM   #112
Vycan's Avatar
Manhattan , Kansas
Updated art from the artist
360 Classic Diesel - Need Thoughts! Bambi_Bandit Classic Motorhomes 14 03-15-2018 07:09 AM
Classic Diesel Pusher :: 1995 Airstream Classic 360 Diesel Pusher Kota Airstream Registry Discussions 1 10-08-2011 04:47 PM
Advice on a 95 360 diesel pusher Rosie39j Classic Motorhomes 4 05-16-2011 03:45 PM
