Old 05-28-2014, 11:20 PM   #43
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
360 Diesel Pusher
I know air brake systems pretty well, airing tires up won't make a hill of beans difference in compressor wear and tear, and plumbing into the air system won't hurt anything either so long as a leak isn't plumbed in, and the tank is properly tapped I am comfortable enough with these claims to state them as unequivocal fact.
It is not uncommon for an engine driven air compressor to last a million miles or more... I KNOW this is true.
These compressors won't make loads of air volume, especially at engine idle speed, bet it will quite effectively air up tires, not really quick, but faster than the the stupid air pumps at gas stations that you dump quarters into.
IMO, a means of airing tires without having to find one of these stupid machines is a bonus and a good expenditure of resources.
(By the way I will admit a bit of personal disdain for the little 12 volt compressors that plug into a cigarette lighter, yea it is good to have one if that is all you have..... But an engine mounted air compressor is just better.. . )
Old 05-28-2014, 11:38 PM   #44
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
I would put a valve in front of the hose and reel, and only turn it on when airing tires though.
Old 05-29-2014, 06:39 AM   #45
Air Dog's Avatar
1995 36' Classic 36
Boulder , Colorado
I haven't found a 12 volt compressor that is worth a damn. That Dewalt is 120 volts AC. 200 psi and does a fine job.
Air Dog is offline   Reply With Quote
Old 05-29-2014, 04:12 PM   #46
1995 36' Classic 36
Ludington , Michigan
AS I mentioned earlier, this is not a large air system. It has a small split tank that operates 2 air over hydraulic master cylinders. Operating pressure is 115 and it wont kick in until 90. You will have to play some games to bleed down the system to get the pressure back up between tires. Unlike big tractors that have systems designed for trailer brakes. Most Ive seen have an airhose with a gladhand copuler. Those systems work a higher pressures of up to 200 psi.
Kota is offline   Reply With Quote
Old 05-29-2014, 04:16 PM   #47
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
I have never seen a truck air system that worked at 200 psi.
The pressures you mentioned above are typical, on at 90 off at 125.
I imagine that the pump used on these motorhomes was identical to the pump used on era smaller trucks and school buses.
Old 06-02-2014, 05:59 PM   #48
Vycan's Avatar
1994 36' Classic 36 Diesel
Manhattan , Kansas
Decided to add this to the cabinetry. Simple brass bottle opener, and a rare earth magnet to catch the cap. Total cost: $16.00.
ID:	213363   Click image for larger version
Name:	Closeup of bottle opener.jpg
1994 36' Classic Diesel Pusher
Vycan is offline   Reply With Quote
Old 06-02-2014, 08:48 PM   #49
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
This 12 volt compressor I bought is a brute. Designed by a very reputable off road outfitter in Aussieland, it can power air tools, easily run an air wrench and with the two 5 gallons aluminum air tanks I have mounted on the back of my 310 will easily blow up air toys (not those kind of air toys ).
Pricey, but has a brushless fan, washable filters and at almost 20 lbs, is a heavy duty piece of kit. The only thing plastic on this brute is the electrical connections and the air filter covers.
ARB On-Board High Performance 12 Volt Twin Air Compressor (CKMTA12)
Can be bought on sale at other places.
I also have an air line hose reel in my storage compartment with a shut off and adjustable air pressure. I love blowing up my tires no matter where I am as I have been told that the 19.5"s can lose their beads quite easily due to under inflation.
Cheers
Tony
Old 06-03-2014, 07:09 AM   #50
Air Dog's Avatar
1995 36' Classic 36
Boulder , Colorado
360 Diesel Pusher
Cheers
Tony
A bit pricy at $500. I used to build rock crawlers and other off road vehicles. We often ran tire pressures as low as 5 psi. Airing up at the end on the day for the trip home was a requirement. In the early days of running the sand dunes we had these check valves devices that screwed into a spark plug hole. They sucked in air and discharged it through a hose. They worked pretty well but probably pumped some fuel/air into the tire. Doubt if they were good for much over 40 psi.
Over the years several solutions were investigated including converting A/C pumps and installing truck air compressors. The 12 volt cigarette lighter pumps were always a slow option that were junk and didn't last long under the demands put on them.
CO2 tanks and high pressure nitrogen were popular. ARB differential lockers became the rage. They use air pressure to lock the clutches and thus a need for a continuos air supply. The ARB compressors work well but at nearly 60 amps they put a pretty good load require on the electrical system and are generally hard wired.
I've actually found very little need to adjust air pressure on the new Goodyears. I am looking at a set of those fill/balance manifolds for the rears.
Still think this a good option with lots of other uses. Watch for Father's Day sales!
http://t.homedepot.com/p/DEWALT-2-5-...word=DWFP55130
Old 06-03-2014, 08:39 AM   #51
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Where would you plan on storing the dewalt while on the road?
mayco is offline   Reply With Quote
Old 06-03-2014, 10:40 AM   #52
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
I installed one of these VIAIR Corporation - 450C-IG Compressor (P/N 45050, 45058) to operate my air suspension system. It is a brute and works very well. Because of the limited storage in the older classic mohos I bought one of these as a back-up. Porter-Cable 6-Gal. 150 psi Oil-Free Pancake Compressor-C2002 at The Home Depot I removed the tank and built a manifold that has both regulated and unregulated air couplers. It fits nicely in my small compartments and has no problem airing up tires.
Cheers, Dan
~ Margaret Thatcher ~
Old 06-03-2014, 11:20 AM   #53
mayco's Avatar
Wow smartstream, what a great idea to remove the tank! I have that porter cable compressor and have been trying to figure out a way to have it on board. Im so new to this. I couldnt come up with any solution for storage. Thats really interesting. Sounds like a future project for me. If you have a pic, would love to see how you set it up. So, did you hard wire it to your 120v or just leave the chord attached in case you need to power it from an outside source for some reason?
Old 06-03-2014, 01:50 PM   #54
Here are a few pics.
ID:	213411 Click image for larger version
As you can see I added a nipple and T on the left side so I could have an unregulated air source and a short nipple and another coupler on the right side providing two regulated air sources but probably more to balance the manifold and add a mounting point. I did have to take the plastic housing apart to access all the fasteners to get the tank off.
I do have a small medical oxygen tank that I can connect to the unregulated air coupler for a reserve tank but it works so well without it that I don't even carry the tank anymore.
I put this together about four years ago and use it quite often simply because it is so light and portable.
Cheers, Dan
Old 06-03-2014, 02:25 PM   #55
mayco's Avatar
That is so cool. What a good idea. So, without a tank, when plugged into the regulated side and filling a tire for instance, you can set the regulator on what ever tire pressure you desire and it will shut down when it reaches that pressure. Then on the unregulated side it will just continue to run. Correct?
Old 06-03-2014, 03:15 PM   #56
Air Dog's Avatar
1995 36' Classic 36
Boulder , Colorado
That Porter Cable is on sale at HD right now for $99. Great idea.
I've got a bunch of room up in the front compartment on mine. Especially after relocating the coach batteries to the engine compartment. I've got my compressor, shop vac, wash bucket and tools up there.
360 Classic Diesel - Need Thoughts! Bambi_Bandit Classic Motorhomes 14 03-15-2018 07:09 AM
Classic Diesel Pusher :: 1995 Airstream Classic 360 Diesel Pusher Kota Airstream Registry Discussions 1 10-08-2011 04:47 PM
Advice on a 95 360 diesel pusher Rosie39j Classic Motorhomes 4 05-16-2011 03:45 PM
