Old 11-26-2015, 10:56 PM   #169
SebasSF's Avatar
1991 30' Airstream 30
San Francisco , California
Sorry we missed you. Dropped by around 12:45
...Click image for larger version
Name:	ImageUploadedByAirstream Forums1448603760.315395.jpg
SebasSF is offline   Reply With Quote
Old 12-02-2015, 12:21 AM   #170
Vycan's Avatar
1994 36' Classic 36 Diesel
Manhattan , Kansas
hey nice car! we were out and about exploring.
1994 36' Classic Diesel Pusher
Vycan is offline   Reply With Quote
Old 12-02-2015, 12:26 AM   #171
Vycan's Avatar
Manhattan , Kansas
forgot to update, alternator installed. saw the turbo to exhaust clamp broke, had to order a new one. kept us in san fran a day longer than expected. air compressor not building pressure on its own.
Old 12-02-2015, 05:38 AM   #172
1995 36' Classic 36
Ludington , Michigan
360 Diesel Pusher
If you pull the compressor I'd either safety wire or Locktite the mounting bolts. They seem notorious for working loose with catastrophic results from oil loss and mechanical damage.
Hate to say it, but another job that's easier to do with the CAC and Radiator assembly removed.
Kota is offline   Reply With Quote
Old 12-03-2015, 09:32 AM   #173
SebasSF's Avatar
Do you guys know the CPL and part number for the Banks Powerpack kit for our Airstream?
Old 12-03-2015, 09:39 AM   #174
1995 36' Classic 36
It's on a plate on the side of the timing case. Passenger side of the engine. Wipe it off and stick your camera down to get the numbers. Can't get your head close to it to read it.
Unless you pull the radiator/CAC assembly!
Old 12-07-2015, 07:38 PM   #175
SebasSF's Avatar
Got it...0987 and the Banks part number is 49248- on order!
Old 12-07-2015, 11:46 PM   #176
1995 36' Classic 36
360 Diesel Pusher
I've posted some suggestions in the past based on doing mine. If they didn't replace your turbo on the engine rebuild, I'd spent $180 on a new cartridge and not bother trying to beat the existing one out of the exhaust housing. Keep the assembly as a spare. Just put the new cartridge in the new banks housing and reuse the blower housing. Easy! Also much easier to pull the entire exhaust manifold assembly. 12 easy to remove bolts vs 4 hard to get at frozen bolts to pull the turbo. Several companies make a better performing sectional (no thermal expansion cracking) exhaust manifold. I'd also install a braided SS flex coupling off the turbo. That would be mimicking the new Cummins installation to reduce cracking problems.
Old 12-07-2015, 11:56 PM   #177
SebasSF's Avatar
Thanks for the tips Kota, I have read your install posts several times. I did get a new turbo and exhaust manifold as part of the rebuild, and hit everything up with PB Blaster over the weekend in hopes of loosening things up.
Old 05-29-2016, 10:02 PM   #178
Vycan's Avatar
Manhattan , Kansas
Long overdue follow up.
Kota, you were exactly right about the air compressor being the source of the oil leak. The main compressor line was rubbing against an edge and I had a 1" long gash in the line. I am amazed I had any compressed air at all. Replaced the line and replaced the compressor gasket.
On the way home from our christmas holiday it was the first time the coach stranded us. We lost our #3 injector. I have a set of injectors picked out I need to install before our trip to newfoundland. According to the detailed mx logs they are original, and we just rolled over 200k.
Currently working an electrical upgrade to have power in any condition. Magnum 3012 inverter charger (installed), remote panel (installed), battery monitor kit (installed), automatic generator start, MPPT 30A solar charge controller (emplaced), 5x 100W Solar Panels, and of course the Trojan L16 6V batteries each with 470Ahrs in series for 12V @ 470Ahrs.
After the electric is complete, the next major project are the injectors. Love the gentle sound of the ratchet click.
Old 06-14-2016, 09:11 PM   #179
Vycan's Avatar
Manhattan , Kansas
Electric install complete. Injectors ordered. Awaiting arrival for install. :-D
Old 06-25-2016, 10:20 AM   #180
Vycan's Avatar
Manhattan , Kansas
Wanted to thank Martin for making a post about ABS plastic and MEK regarding a bumper repair in a previous thread. It sparked my curiosity, took 20min to research, and found a viable solution to the issue I inherited from the PO on DD. I did a search and found a product on Amazon for joining ABS pipes that comes in black. You can easily see a difference in color, but it is much closer, and very good to see the plastic in a single piece again. Very happy with the outcome.
First picture: Closeup of the damage
Second picture: Closeup of the repair
Third picture: Expanded frame
ID:	265165   Click image for larger version
Old 06-25-2016, 11:39 AM   #181
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
Looks good Vycan, barely noticable, but I think credit the the ABS/MEK repairs should go to Brad, certainly he is the guy that worked it out!
martin300662 is online now   Reply With Quote
Old 06-25-2016, 03:44 PM   #182
And back tracking even farther I would give credit to Keyair. Steve's work on his 345 is where I first realized that you could repair the ABS parts & pieces
bkahler is online now   Reply With Quote
360 Classic Diesel - Need Thoughts! Bambi_Bandit Classic Motorhomes 14 03-15-2018 07:09 AM
Classic Diesel Pusher :: 1995 Airstream Classic 360 Diesel Pusher Kota Airstream Registry Discussions 1 10-08-2011 04:47 PM
Advice on a 95 360 diesel pusher Rosie39j Classic Motorhomes 4 05-16-2011 03:45 PM
