Old 03-04-2015, 06:28 AM   #141
Vycan's Avatar
1994 36' Classic 36 Diesel
Manhattan , Kansas
Kota,
The exhaust break is amazing, I rarely have to use the brakes if I am driving as you should in a diesel. Just the last 20 or so feet.
I have a total of seven batteries. Two engine batteries at the rear, and five house batteries located up front.
I like the setup you have, if you would share the design and concept you used I will look into duplicating. I plan to do four solar flex panels on top, so I have to figure out the best placement for everything. Soon everything will be completed :-D
1994 36' Classic Diesel Pusher
Vycan is offline   Reply With Quote
Old 05-01-2015, 06:17 PM   #142
Vycan's Avatar
Manhattan , Kansas
It's always something...
Fuel Leak:
Fixed the weeping lines on the injector side of the engine, then I had weeping lines on the pump side thought I eliminated all fuel leaks, but there is something in the vicinity of the fuel shutoff solenoid.
Oil Leak:
Developed an oil leak that cost me a quart of oil every 100 miles or so. The lower securing nut of the power steering pump was missing, so I replaced it, and that seemed to fix it.
Generator:
The generator we spent a bit of money on will not remote start. The generator will start using the start switch on the actual generator, but it will not send power to the coach. I have tried the circuit breakers and checked the power switching box. Circuit breakers do nothing regardless of position. Power switching box looks new inside, with no signs of scorching, or bubbling at fusible links. No idea where to start, but will research.
Old 05-02-2015, 12:25 AM   #143
SebasSF's Avatar
1991 30' Airstream 30
San Francisco , California
Electrical fun. Turn on the gen, make sure the breakers on it are turned on, then test the output from the gen and work tour way out.
SebasSF is offline   Reply With Quote
Old 05-02-2015, 03:28 AM   #144
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Yep, find your first junction closest to the genny and work your way out like Sebas said.
mayco is offline   Reply With Quote
Old 05-02-2015, 06:25 AM   #145
1995 36' Classic 36
Ludington , Michigan
I finally had an electrical problem that wasn't due to a bad ground, bad crimp on connector, or a loose connection. My turn signal flasher failed on the way home from the springs.
BTW, the emerg flasher and turn signal flasher are interchangeable in a pinch.
Kota is offline   Reply With Quote
Old 05-02-2015, 10:23 AM   #146
SebasSF's Avatar
An electrical question for you...where is the converter/charger located? No inverter on these right?
Old 05-02-2015, 11:48 AM   #147
1995 36' Classic 36
Behind the panel in front of the passengers feet. There are some screws embedded in the carpeting. A magnet is handy to find them.
Old 05-02-2015, 11:49 AM   #148
1995 36' Classic 36
No built in inverter in mine. PO had a cig lighter plug in one. About 300 watts.
Old 05-05-2015, 01:15 AM   #149
1995 36' Classic 36
Any luck on the generator?
Old 05-10-2015, 07:59 AM   #150
Vycan's Avatar
Manhattan , Kansas
I have not had the chance to dig into it yet, but it is on my list of things to do. I have a business trip for a few months beginning next weekend. We'll see if I get to it, however I did manage to get a service manual for the onan 6500 Grand Marquis, so that's something.
Old 05-10-2015, 08:49 AM   #151
1995 36' Classic 36
Tracked down the oil leak on my 94 that caused the mess in the radiator. One of the bolts was missing on the bottom of the compressor. I believe you had the same issue.
I did learn a few things on the 94. There is an installation manual for the Granning Air Ride. It references jacking up the vehicle and removing the leaf springs, reusing the front spring mounts and bolts, installing the bags, leveling valves... Almost looks like it was a dealer installed option. I'll send you a copy if you would like.
Old 05-10-2015, 02:01 PM   #152
Vycan's Avatar
Manhattan , Kansas
Yes please! I assume it also has all the part numbers? Next time we get together, if you bring the 94 I would like to ride in it to see if it would be an upgrade I would want to undertake.
Old 05-10-2015, 02:04 PM   #153
1995 36' Classic 36
I'm on the road storm chasing. Or being chased by the storms!
Name:	ImageUploadedByAirstream Forums1431288224.406723.jpg
I'll scan them when I get home and email you.
Old 05-10-2015, 11:22 PM   #154
Vycan's Avatar
Manhattan , Kansas
Thanks! Had a moment to work on the generator today. Previously I replaced the control board because the original was burnt out, so thought that was all it was. This was before I got the service manual. Took all the remote switches apart and cleaned them, there was a lot of carbon build up on them. Also saw the ground in the junction box had a lot of scaling and galvanization built up on it, so took it apart cleaned it and reconnected it.
Result:
1. Can start the generator at the unit.
2. Can stop the generator at the unit.
3. Can Stop the generator at both remote switches.
4. Generator powers the coach.
5. Cannot Start the the generator with either remote switch. (anyone know where the generator remote switch cables are routed? I can see it go into a hole above the unit, but I think it might go in between the skins.)
I am thinking it might be some of the wiring that goes around the aft end of the unit inside open area aft of the engine compartment above the hatch area.
360 Classic Diesel - Need Thoughts! Bambi_Bandit Classic Motorhomes 14 03-15-2018 07:09 AM
Classic Diesel Pusher :: 1995 Airstream Classic 360 Diesel Pusher Kota Airstream Registry Discussions 1 10-08-2011 04:47 PM
Advice on a 95 360 diesel pusher Rosie39j Classic Motorhomes 4 05-16-2011 03:45 PM
