Old 04-17-2016, 09:45 AM   #1
1987 34.5' Airstream 345
northern IL , Illinois
34.5 Gray water tank removal
Hello I'm working on changing the all the gas lines. The ones next to the gray water tank are very hard to get at. I was thinking about taking the gray tank out but it looks like it was put in the MO from the top. Could this be. Has anyone been down this road.
Thanks Hans
Hans 34.5 is offline   Reply With Quote
Old 04-17-2016, 10:06 AM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
Why are you changing the gas lines? If the are copper they should out last the MH. If the lines are supported so as not to be subject to vibration ware or cutting why?
2004 Excursion 4x4
Old 04-17-2016, 10:15 AM   #3
I'm sorry I should have said the short rubber lines.
Old 04-21-2016, 10:38 AM   #4
Ok I jumped the gun on needing to pull the gray water tank to change the short rubber gas lines next to that gray water tank. I did find a mouse house in the P trap cover for the shower. I think that was the mouse highway into the MO. No need to pull that tank to get to the gas rubber lines you just have to arm strong the tubes around to get the clamps off.
Covert fresh water tank to a gray tank cole3444 Waste Systems, Tanks & Totes 3 03-25-2014 06:31 PM
Extra 67 tradewind blackwater tank, gray water tank poezlaw Waste Systems, Tanks & Totes 0 01-17-2011 09:19 PM
'81 Excella II Gray Water Tank Removal boo_n_sue Waste Systems, Tanks & Totes 3 08-08-2010 09:06 PM
Gray Water Diverted Into Black Water Tank Chaplain Kent Waste Systems, Tanks & Totes 5 06-14-2006 06:38 PM
Gray water tank removal AccessMaster Airstream Motorhome Forums 1 03-07-2004 10:05 AM
