Old 06-10-2018, 08:38 PM   #1
1987 34.5' Airstream 345
Menomonee Falls , Wisconsin
325 front furnace thermostat
hey,
Remember when I said the instructions for my new suburban furnace stated the need for a thermostat that had an off mode? I went to the hardware store and got a 12 volt themostat . Well that off mode cuts power to the them. Mine is set to as low as it gets, which is 50 degrees. And it turns off. But, once the temp. Gets below 50 it cycles and want to kick on heat. I got the propane off, so the fan just cycles. So, I'll have to get a themostat that has an off position. I so wish the mfgers would say why you need what they require. It would help keep the aggravation factor low... DJ
davejay is offline   Reply With Quote
Old 06-10-2018, 10:21 PM   #2
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Just trying to solve your town/cities name on Wheel of Fortune would be aggravating........you'd go through half the alphabet before getting a letter.
Cheers
Sidekick Tony
Old 06-11-2018, 01:26 AM   #3
WayneG's Avatar
1984 27' Airstream 270
Scotia , New York
Amazon has these for $14 (Plus $151 with EXPERT installation)
I just replaced my original thermostat that had a ON OFF switch at the bottom.
The new one does not have a OFF switch but declares it is OFF all the way to the left.
If you get desperate you could always put a switch in series with the wires, but that could get ugly.
Suburban 161154 Wall Thermostat - Heat Only - White
Do not take life too seriously.
You will never get out of it alive.
WayneG is offline   Reply With Quote
325 front furnace davejay Classic Motorhomes 4 03-17-2018 08:38 PM
325 front furnace davejay Classic Motorhomes 2 02-15-2018 07:29 PM
Front tires for 1986 325 DarininOhio Classic Motorhomes 8 04-28-2017 05:58 PM
1985 AS Motorhome 325 Front Grill busted!!!! Kepandia Classic Motorhomes 5 05-01-2015 05:48 PM
325 Front Windshield Pomfritz Windows & Screens 4 08-03-2010 04:13 PM
