Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Classic Motorhomes
Old 02-25-2012, 08:59 AM   #1
Alumnati
1986 34.5' Airstream 345
Fredericksburg , Texas
22 inch shower door
Has anyone found a shower door to fit the factory 22 inch opening? We don't want the accordion style door or a shower curtain. We haven't yet found one that will fit but think that some cleaver Airstream owner has solved this issue.
vonprum is offline   Reply With Quote
Old 02-25-2012, 10:59 AM   #2
Bob Thompson's Avatar
Corpus Christi , Texas
Images: 67
I had one of the accordian folders which never worked right. My solution was to go to the local glass shop and purchase the aluminum I needed for the door jambs and sill as well as the aluminum to make the door itself. I then ordered 1/2" polycarbonate Twinwall. It is very light and tough. The solution:
http://www.airforums.com/photos/showimage.php?i=17803&c=500&userid=3264
http://www.airforums.com/attachments/gallery/files/3/2/6/4/img_0419.jpg
http://www.airforums.com/attachments/gallery/files/3/2/6/4/img_0418.jpg
http://www.airforums.com/attachments/gallery/files/3/2/6/4/img_0417.jpg
So Long!
Bob Thompson is offline   Reply With Quote
Old 02-25-2012, 02:49 PM   #3
Brighton , sussex
Your best bet would be to try a bathroom shop. You should ask if they have a supplier that makes shower doors for domestic bathrooms. They should have a custom size option that could fit if you measure the opening or drive it down there.
Or you could ask a glass company to make a frameless door which is just connected to the frame with chrome, gold whatever metal 'lock at 90 degrees' hinges. You will need door seals. You can then have frosted, coloured or patterned glass. I think a bronze/frosted glass would be on keeping. The glass MUST be toughened or tempered.
I design bathrooms for a living and sell this sort of thing
Good luck
Loving Life, Chicks, Cars and Mummas Grits baby
montreal is offline   Reply With Quote
Old 02-25-2012, 03:48 PM   #4
1967 17' Caravel
Pocatello , Idaho
Wow, Bob! Very professional! I will keep these photos as a reference for building such a shower door in our 34' Ltd. Thanks a bunch!
Vivian
Landshark is offline   Reply With Quote
Old 02-25-2012, 04:00 PM   #5
Images: 67
If I remember correctly, if a shop does it, the door has to swing out according to a safety code. An out swinging door has special problems of keeping the water and spray from escaping around the jambs and sill. Since I did my own, I was able to allow it to swing inward and the jambs and sill block the exit of spray water. Also, the styles to make the door itself were set up for a total thickness of glass and rubber gasket equaling 1/2". The Twinwall is 1/2" thick so it just barely fit in the styles without a gasket so the Twinwall was bedded in silicone sealant on all sides. The latching of the door to the jamb is by way of a magnetic strip on the jamb and one on the door so the two pull the door closed once the magnetics strips get close to each other.
So Long!
Old 02-25-2012, 06:16 PM   #6
crazeevw's Avatar
1989 34.5' Airstream 345
Saint Petersburg , Florida
Bob, our problem on 345 is that door opening is out to middle of the rig, our sit-down area is in back of shower, not to the side, do an inward swing door really isn't possible. Saw Raveson's 345 at last weekend's Airstream Rally, he has the outward swing. Forgot to ask about water run-off when opening door, lol.
Thanks for some great ideas, Derek
Old 02-26-2012, 07:08 AM   #7
raveson's Avatar
1989 25' Excella
Hobe Sound , Florida
Always put down a bath matt infront of the door, but have not had any trouble with water in the carpet. The matt get wetter from us coming out then runoff from the door.
raveson is offline   Reply With Quote
Old 02-04-2018, 08:26 AM   #8
1988 25' Excella
Newburgh , New York
We found your accordion shower curtain interesting. How did you mount the flat shower door to the wall?
rmscottrds is offline   Reply With Quote
Old 02-06-2018, 10:03 AM   #9
jkwoodrow
1987 34.5' Airstream 345
Springfield , Ohio
I had the same issue with my 345. I ended up using a quality fabric shower curtain which I had a small stainless steel chain hemmed into the bottom for weight. It has worked perfectly and is more convienient than a solid door especially when you bump it turning around in the shower.
John Woodrow is offline   Reply With Quote
Hey to 2010-2012 Airstream Sport 22' owners ZZSPIRAL Our Community 27 12-17-2014 11:41 AM
1965 Airstream Safari 22 Restored eBay Watch Airstreams on eBay 1 09-10-2012 07:54 PM
Entrance door question Ridgerunner3 Doors & Locks 8 02-24-2012 02:42 PM
2007 Airstream Interstate 22' Front Lounge Mercedes Benz Diesel Engine Class B eBay Watch Airstreams on eBay 0 02-24-2012 12:10 PM
Exterior AC Plug Door MaxAB Exterior Storage Compartments & Access Doors 4 02-24-2012 12:23 AM
