Old 03-07-2016, 05:37 PM   #477
wxbuoy's Avatar
1991 35' Airstream 350
Carriere , Mississippi
Send a message via Skype™ to wxbuoy
Originally Posted by PeterH-Airstreamer View Post
Nice job, Dave.
On all of the Airstreams I have worked on over the years, Trailers and Motorhomes, the most destructive force I have seen over and over is damage due to low level vibration. Abs seems to get extremely dry and brittle over the years. The best and only remedy is to keep your tires balanced or better the entire assembly by using centramatics.
You may want to consider ordering a set from the company for your drive axle.
Just look around your coach, when you see the black alu dust and/or cracked ABS, you see damage due to vibration. Imagine all the things you can't see inside the walls.
Often the vibration damage is worse on trailers, since you are not riding in it and would address the issue immediately, if you would have known.
The 1997 trailer I am restoring right now had such severe vibration issues that most of the belly pan rivets got sheared off.
Thanks! Yup, the 2 sets of centramatics are on my wish list (drive and tag). I have a state tax refund that will be coming in a few weeks and plan on using that to get them. I couldn't agree more that vibration is what causes early failure in these beauties. Which is why I have spent the majority of the money on the complete front end, air bags and shocks. Next winter I hope to do the tag....
Dave and Felicia
wxbuoy is offline   Reply With Quote
Old 03-12-2016, 02:43 PM   #478
wxbuoy's Avatar
We had to cancel the camping trip this week-end due to all the rain here in South Mississippi.
Did a temporary fix on the lock this week. It looks a mess but the wire wraps take up the slack and wire tie ensures it wont pop off again! I need to fashion a small plate to put in the top part to take of the slack in the pull rad and hold the lower attachment in place. Didn't have any rivets small enough to attach so I will do that when I go get some. Now the door opens when th handle is pulled out to about 30 degrees. Before it had to go to 90!
Name:	IMG_0394 (Medium).JPG
In the mean time today, I took out the 1980's gold sconce in the parlor and updated the fixture for a more modern look. :
Old one:
Name:	IMG_0059 (Medium).JPG
New one:
Dave and Felicia
Old 03-12-2016, 04:30 PM   #479
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
Don't forget to save the old one.
bobmiller1 is offline   Reply With Quote
Old 03-12-2016, 05:55 PM   #480
Dave, how come I didn't see any duct tape used in your repair of the door handle... ?
Old 03-12-2016, 05:57 PM   #481
wxbuoy's Avatar
I saved it and it is free for the taking to anyone willing to pay postage!
Dave and Felicia
Old 03-12-2016, 05:58 PM   #482
wxbuoy's Avatar
How do you think I put the panel covering it back on?
Dave and Felicia
Old 03-13-2016, 07:54 AM   #483
That's better...
Old 04-10-2016, 05:24 PM   #484
wxbuoy's Avatar
New Antenna
Finally got around to pulling off the old TV antenna and replacing it. I pulled the amidships panel down to find a leak. Sure enough it was coming from the antenna crank and the hole where the coaxial comes in the skin of the RV.
I have been putting it off for quite some time, and therefore any forward progress on the inside since I need to fix that first. Finally had a day in the low 70's with a nice breeze blowing to keep things cool. So anyway, got out the moving pad and 1/4" plywood and up I went..... Did I happen to mention, I hate climbing up there?
Scrapped all the old sealant to get at the screws. Here's the old antenna where it landed in the yard.
Got most of the crap scrapped off only to realize there was another disk to remove.
Off course with air stream it is not a simple replacement.... So how to get the square peg in the round hole..... Looks like it is time for the multi tool!
Widened the hole and attached it. Used an inner layer of butyl tape on the inside rim, than sikaflex 715 n the outside rime and around the edge and all screws. Since the base plate shape was different I put in 4 pop rivets where the old holes were and covered with sikaflex as well.
Here is pic the wife took on her phone.... She was standing by to call the ambulance when I fell.
Dave and Felicia
Old 04-10-2016, 05:36 PM   #485
Originally Posted by wxbuoy View Post
...I pulled the amidships panel down to find a leak.
Hmm ..... amidships ..... sounds like a nautical term, imagine that
It's always a nice feeling to plug another leak. In your line of work I would imagine that's a pretty important deal
(landlubber at heart!)
Old 04-10-2016, 07:29 PM   #486
Central , Mississippi
I just installed the same antenna in another friends camper. It's turned out to be pretty cool with the signal meter.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 04-20-2016, 05:08 AM   #487
wxbuoy's Avatar
Well the inside signal meter had a loose wire and was cutting out 80% of the time. Called King and a replacement part is in its way.
Dave and Felicia
Old 04-20-2016, 05:16 AM   #488
wxbuoy's Avatar
Does anyone have a source if supply for the outside door handle for a 91 MoHo? The lopsided torque being applied (only bottom side engages locking mechanism) finally cracked the handle. I called Inland rv on Monday. Spoke to the girl and was told they would call right back. Experience has shown unless you know the part number or talk to Andy directly mot much hope.
Will try airstream later today or look at retrofitting if no joy by next week.
Dave and Felicia
Old 04-20-2016, 08:24 AM   #489
Dave, those door handles are not that easy to find. Keyair got the only one I had seen in in the wild. The only other possibility I can think of is that 310 diesel that was being parted out on ebay a while back. Sellers name is Runamuck12 so it might be worth contacting him to see if it's available.
Good luck!
Old 04-20-2016, 06:54 PM   #490
wxbuoy's Avatar
Good luck!
Thanks for the lead!
Dave and Felicia
Classic 350 streamquest Classic Motorhomes 9 12-17-2011 06:19 PM
Airstream b190 - ford econoline 350 (1991) with 460 efi - clarksville, tn eBay Watch Airstreams on eBay 0 11-19-2011 11:40 PM
Airstream Classic 350 LE Motor Home 1992 Orig Owner eBay Watch Airstreams on eBay 0 06-22-2011 08:50 PM
1st trip in my 1991 350 LE t7389sg Classic Motorhomes 9 06-04-2011 06:40 AM
1992 Airstream Classic 350 LE Orig. Owner 454 Chevrolet eBay Watch Airstreams on eBay 0 03-11-2011 05:40 PM
