Old 09-08-2015, 03:56 PM   #407
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
https://www.fastenal.com/web/products/details/5101824
I installed these from Fastenal and they worked great, installation was a breeze.
mayco is offline   Reply With Quote
Old 09-08-2015, 04:52 PM   #408
1982 28' Airstream 280
Redwood City , California
That's where we all go those! I couldn't remember ;(
Installed mine a couple weeks ago. No issues front or rear.
ID:	247659   Click image for larger version
"We are free to go where we wish and to be what we are"
Richard Bach, Jonathan Livingston Seagall
dadstoy is online now   Reply With Quote
Old 09-11-2015, 07:53 PM   #409
wxbuoy's Avatar
1991 35' Airstream 350
Carriere , Mississippi
Send a message via Skype™ to wxbuoy
Dean/Mayco,
Thanks! Just ordered them. The are on sale for $3.48!! I now remember you all saying something about it, but that was back when I wasn't worried about that yet (had to get drivers chair first!) I also can't for the life of me remember where I wrote the note about it.... I need to do a list of things I need/want and source of supply.
Dave and Felicia
wxbuoy is offline   Reply With Quote
Old 09-11-2015, 08:41 PM   #410
mayco's Avatar
Yep, thats what I paid months ago. They seem like good quality little lights.
Old 09-19-2015, 01:50 PM   #411
wxbuoy's Avatar
1991 Classic 350 LE
Sitting in a different camp ground this saturday for our overnighter/fixer upper. Cleaned all the old deteriorate insulation out of the generator bay. Well as much as I could reach with hands and shop vac. I am afraid I will have to take out the generator to do it right..... Not looking forward to that!
Also replaced the old dometic refer. The coils had a leak and it was venting ammonia. Getting new coils would have been $400 and probably another $100 for the ignition board that was messing up before the leak. So I would have been 40% if the cost of a new one just for parts that I was sure I had to replace.... It would be closer to 80-90% if I had someone else do the work. Made more sense to replace since there is no intrinsic value in that style. There was no direct replacement for that exact size. We either had to go 3" bigger or 2" smaller.after looking at the space we decided to go smaller. It would have required extensive mods to the cabinet above and it would have just cleared the curve at the 24" depth. Basically square peg in round hole. Which is possible only if you can make hole big enough!
Here is what the new fridge looks like. It is a norco NX64. It came with faux wood panels (stainless steel model wasn't readily available- at least 2 weeks and shipping. It also cost $350 more! Had a local shop cut large fridge stainless steel panels to size for a total cost of $75. Saved $275 in the process. We think it looks good and matches the rest if the galley.
Name:	ImageUploadedByAirstream Forums1442688560.167071.jpg
Dave and Felicia
Old 09-19-2015, 02:20 PM   #412
Which genset do you have Dave?
I would seriously consider putting it on some slides...
Brad did it first and I copied...
Info on page 2 of my oil leak thread here...
http://www.airforums.com/forums/f448...k-64381-2.html
Old 09-19-2015, 06:15 PM   #413
wxbuoy's Avatar
Key,
Great to hear from you! I was going to go back through your thread to see how you did that. If I am gonna pull it, I am gonna put it on slides to make maint easier!!
I have the Onan Emaerald III 6500 (actually 6300 since it is propane).
How hard is it to unbolt and drop/lift outta there?
Dave and Felicia
Old 09-19-2015, 08:51 PM   #414
Dave,
I have not pulled mine all the way out so far.. I did however, pull it out far enough without disconnecting the electrical.
On mine, there is the main electrical cables(in a flex conduit), fuel line, ground strap and exhaust.
The genset itself is contained on a steel "pallet", and my MH floor is a solid sheet, so the genset slides out after removing the outer skin panel. I just disconnected what I needed, and pulled it out onto a motorcycle lift. My slides are rated at 500lb fixed and 300lb mobile(genset complete is 300lb plus), but I added a couple of bolts to lock it in place. I used some angle iron to adapt the slides to the pallet... I think the pics are better than my words.
On my setup, I added a switchable gas valve that allows me to run the genset from a gas can if I want. Not sure if you could or would want that for propane...
Old 09-20-2015, 08:06 AM   #415
Dave,
Converting your genset compartment to drawer slides is not overly difficult. It takes some time and planning and as as Steve mentioned some angle iron. I consider the drawer slides to be the single best modification I made to the 310.
Removing the generator to prepare it for drawer slides is probably the hardest part. On the 310 and 345 coaches the floor of the genset cabinet can be unbolted and he whole works lowered straight down. The floor/tray is made of about 1/8" plate steel that has cutouts for the exhaust system. To drop the tray Steve's idea of using a transmission jack is an excellent tip. I had access to a tractor with pallet forks in front so I used that to remove and then re-install.
Now I have what's called a motorcycle jack that would probably work just as well for lowering and raising back into place.
I think the one mistake I made when adding drawer slides to the 310 was to buy drawer slides that only allow the drawer to slide out 2/3. For my Argosy I bought a pair of 26" full extension slides rated at 500 lbs from McMaster Carr. Part # 6603A49.
These are longer than you would need for your drawer as I have to insert the generator from the end (i.e. narrow end sticking out) instead of from the side like most generator compartments. My Argosy compartment is not typical which complicates things greatly
Another suggestion for your installation is to use 10 gauge 3-conductor rubber SO cord from the generator to the coach electrical transfer box. You'll need two cables, one for each circuit. One last suggestion is to use heavy duty extension cord connectors between the generator and the electrical box. In other words go ahead run the SO cords between the generator and the coach making sure you make them long enough to allow for full drawer extension and then cut each cord in the middle and install plugs and sockets such as these.
Female - 7162K46
Male - 7162K41
I didn't use these on the 310 and wish I had as it would have made removing and replacing the generator so much easier for future maintenance. On the 310 it was a really tight fit trying to access the wire connections in the coach and about the same for the generator connections themselves. If I had used these plugs there is no need to touch the coach or generator wiring again. I plan on using them in my Argosy.
Old 09-20-2015, 07:12 PM   #416
wxbuoy's Avatar
Thanks Brad!
Good idea on the plug connection. I plan to replace the junction box in the generator space with a 50 plug attachment. That way I can have the generator deliver the 20/30 or use the camp ground 50 amp service to run both A/C's
I briefly looked at it this afternoon and I think mine is built a bit differently. Will look at it closer next weekend and post some pics. I really don't want to have to remove the plastic molding on the side of the coach. It is pristine and drilling out rivets is gonna screw it all up... There has got to be a better way to do it.
Dave and Felicia
Old 09-20-2015, 07:13 PM   #417
wxbuoy's Avatar
Dean,
Just saw this. My airforum's app is acting screwy lately. Your right they loo great! Thanks for the tip!
Dave and Felicia
Old 09-21-2015, 11:06 AM   #418
Originally Posted by wxbuoy View Post
Thanks Brad!
To me, anything you can do to make the generator easier to disconnect and remove is worth doing. You don't have to use the type of connectors I suggested, you could use a couple of dryer cords (find the 30 amp style) and mount two boxes with female sockets on the inside wall of the genset cabinet connected to your transfer switch. Lots of options available.
Definitely post pictures. It surprises me that Airstream ran the trim across the generator compartment.
Old 10-04-2015, 07:36 PM   #419
wxbuoy's Avatar
Well DW and I put down the floor this weekend. We put in a tiger strip bamboo floating floor. I am sure it is not to most peoples taste but we like it an it has all the different colors of the other woods (beds, cabinets, doors and bulkheads) not to mention the new chairs!... The hardest part was the first 6 pieces. We spent a lot of time figuring out where the center of the RV was so we would have even rows. And the new LED lighting is incredible! I can easily see to work at night.
Name:	IMG_0228 (Medium).JPG
Name:	IMG_0229 (Medium).JPG
Name:	IMG_0235 (Medium).JPG
Name:	IMG_0237 (Medium).JPG
Dave and Felicia
Old 10-05-2015, 12:15 AM   #420
I love the flooring! Great job!
Classic 350 streamquest Classic Motorhomes 9 12-17-2011 07:19 PM
Airstream b190 - ford econoline 350 (1991) with 460 efi - clarksville, tn eBay Watch Airstreams on eBay 0 11-20-2011 12:40 AM
Airstream Classic 350 LE Motor Home 1992 Orig Owner eBay Watch Airstreams on eBay 0 06-22-2011 09:50 PM
1st trip in my 1991 350 LE t7389sg Classic Motorhomes 9 06-04-2011 07:40 AM
1992 Airstream Classic 350 LE Orig. Owner 454 Chevrolet eBay Watch Airstreams on eBay 0 03-11-2011 06:40 PM
