Old 05-09-2016, 09:31 PM   #1
RBonney's Avatar
1983 27' Excella
1990 34.5' Airstream 345
Spring Lake , Michigan
1990 335 couch removal
Hello I want to remove my couch and I'm looking for any tips etc. I can't seem to figure out how to remove the drawer under the cough. Any input would be great. thanks
RBonney is offline   Reply With Quote
Old 05-10-2016, 10:16 AM   #2
RBonney's Avatar
1983 27' Excella
Typo it's a 345 LE
Old 05-10-2016, 10:45 AM   #3
1987 34.5' Airstream 345
northern IL , Illinois
Does it have a slider under or on the side of the drawer. My 87 34.5 has just doors under the couch. Some of the sliders like in the kitchen has a small lever on the track you move to pull the drawer out of the track.
Hans 34.5 is offline   Reply With Quote
Old 05-10-2016, 12:49 PM   #4
RBonney's Avatar
1983 27' Excella
It's a slide drawer full length of couch
Old 05-11-2016, 11:59 AM   #5
Boom Sounds's Avatar
1991 25' Airstream 250
Oxford , Oxfordshire
Are there two bolts buried at back/sides of settee. Pull fabric back and you can see them. Undo them and ones underneath and the back and seat of settee can be removed to give access, at least that is how it works on my 1991 250 le.
Boom Sounds is offline   Reply With Quote
Old 05-12-2016, 05:07 AM   #6
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
The slides are screwed into the sides of the wide drawer, remove the screws (4) per side and slide the drawer away from the couch on the floor. Access can then be made to the aux. heater and doorbell....it's still a tight fit and be careful, the underside of the couch framework is very sharp. Regards, Bob
bobmiller1 is offline   Reply With Quote
Couch Replacement - 1990 250 Sonia Classic Motorhomes 15 10-14-2011 10:23 AM
To couch or not to couch? Safari Tim Upholstery, Blinds, Walls & Interior Finishes 47 03-25-2009 02:51 PM
couch removal scf31 Upholstery, Blinds, Walls & Interior Finishes 4 06-12-2005 10:54 AM
Cabinet And Couch Removal? arodriguez60 Repairing/Replacing Floor &/or Frame 4 03-30-2005 01:06 PM
