02-27-2012, 10:32 AM
#101
Foothill Ranch
Well its a steering damper... normally its mounted across the chassis under the engine cross member.
The supersteer is a win.
They are $300 bucks a piece, and are a huge upgrade, as they have roller bearings instead of the stock sloppy plain bearing units.
SuperSteer Bell Crank for Chevy P30/32 Motorhome Chassis
Looseness, or play in the steering wheel can often be attributed to the bell crank (or "idler"), which supports the steering linkage. Original equipment designs utilize common sleeve bushings, which often wear out prematurely and cannot be adjusted for side play. By contrast, SuperSteer bell cranks utilize tapered roller bearings, which are far better at carrying load and can be adjusted to achieve precise movement.
SuperSteer Bell Crank P3032
02-27-2012, 09:08 PM
#102
Alumnati
1986 34.5' Airstream 345
Fredericksburg
I coincidentally replaced the steering damper on our 345 yesterday. The old one was totally shot and our coach only has 51,000 on the clock. After reading this thread I immediately ordered the Supersteer bell crank. Our coach handled like a pogo stick. This should do the trick.
03-04-2012, 07:51 PM
#103
Athens GA
1995 28' Excella
1989 34' Excella
1986 31' Sovereign
1987 34.5' Airstream 345
Athens
, Georgia
I have them on mine. As I have been tell y'all my Moho drives great with those. I recommend getting for yours if you don't already have. They make all the difference in the world. I was able to pass big rigs on the highway without blowing off the road after I installed mine.
Athens GA
03-11-2012, 05:39 PM
#104
Foothill Ranch
Your M/H...
In 1989, the base price/MSRP was....
$118,762
03-31-2012, 08:05 PM
#105
1989 34.5' Airstream 345
Saint Petersburg
anyone have any ideas where to locate replacement tail-light lenses? Just started looking this evening, but so far not much luck. As well, what about the turn signal lenses for the front of moho? Of course, I'm looking for best price, doubt that I could afford anything directly from Airstream. Gotta be a supplier out there somewhere
Thanks, Derek
03-31-2012, 08:47 PM
#106
Foothill Ranch
04-01-2012, 09:02 AM
#108
Saint Petersburg
Look what finally came!
Just out front of my home, sweeping the last bit of leaves (leaves don't come down in the fall here in Florida) and discovered that I had a package hidden. Wow, this is going to be so cool! Now DadsToy and I can actually be 'twins' with our iPad steering wheel holders!
04-01-2012, 01:02 PM
#109
_
, _
Your going to love it!
May a Firefly land upon your shoulder
and bring you good luck, good fortune, and abundance.
04-02-2012, 11:43 AM
#110
65th Anniversary CLIPPER
1996 36' Clipper Bus
Tub City
, British Columbia
No one fell for it Crazee, because you plagiarized the photo! Nice try though. I thought for a moment I was going to have to bail you our also.
Dave
04-02-2012, 11:48 AM
#111
_
, _
Dave
Derek, it's true, Airstreamer's don't have a sense of humor...sad.
04-02-2012, 11:50 AM
#112
_
, _
Originally Posted by dadstoy
Derek, it's true, Airstreamer's don't have a seance of humor...sad.
I bet it is the heavy exposure to all that aluminum. It's starting to affect me too!
04-02-2012, 11:55 AM
#113
_
, _
Nope, that's not it either, that would be lead exposure that affects the old brain.
04-02-2012, 02:25 PM
#114
Tub City
, British Columbia
Are you buying that paint from China again?
Dave
04-02-2012, 03:05 PM
#115
Foothill Ranch
Huh?
04-02-2012, 05:33 PM
#116
_
, _
Dave
Yes, that and just about every part I have put on the MH recently!
04-02-2012, 05:39 PM
#117
Tub City
, British Columbia
Why don't you lads get together and send one of those 345 diesel pushers over to China and ask them to make copies! They are real good at that and can do it in a short time frame.
They even copied the new Ford P/U.
Chinese carmaker blatantly copies Ford F-150
Dave
04-07-2012, 03:12 PM
#118
Saint Petersburg
Ok, here's a new question. Since $ are tight, no camping in foreseeable future, I'm considering removing all of the interior, including the interior skin so I can remove Fiberglas insulation and replace it with something with a higher R-rated value. Has anyone ever stripped interior of their Classic Motorhome? If so, any hints or suggestions?
Thanks, Derek
04-07-2012, 03:40 PM
#119
2000 31' Land Yacht
Central
Ok, here's a new question. Since $ are tight, no camping in foreseeable future, I'm considering removing all of the interior, including the interior skin so I can remove Fiberglas insulation Thanks, Derek
Old saying if it ain't broke don't fix might apply, if dollars are short.
04-07-2012, 03:56 PM
#120
Saint Petersburg
Removing interior is all me. Home Depot credit card for rest, lol. Plans are to full-time in motorhome in 9 years. Now is good a time as any. Plus, have garage to store all of interior now....
Thanks, Derek
