Old 02-07-2013, 05:26 AM   #323
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
Originally Posted by crazeevw View Post
Peter,
I'll go buy the washers and use them instead of the 5/8 rivets. Those are used in the upper cabinets, where they are attached to the ceiling. Still, I'm heading to Fastenall tomorrow after work to see if they possibly have them!
Thanks, Derek
I checked the inventory at Home Depot yesterday and they now have a nice selection of aluminum blind rivets, some with a bigger head. Since you drilled out existing, you probably have to go back with the next bigger size for a tight fit.
1996 Airstream B190
1987 29' Sovereign Trailer
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 02-07-2013, 08:26 AM   #324
crazeevw's Avatar
1989 34.5' Airstream 345
Saint Petersburg , Florida
Peter,
Must be LOTS more Airstream's in your area of TX. Was just at HD this past weekend, and bought 3 different sized rivets, that's all they had.....
Old 02-20-2013, 08:27 AM   #325
crazeevw's Avatar
Tire quote this morning. 8R19.5 Hercules brand, $183. Plus installation. Anyone ever heard of Hercules?
Thanks, Derek
Old 02-20-2013, 05:03 PM   #326
Airstream Driver
1997 30' Excella
Images: 51
Thanks, Derek
No, but I never buy cheap tires again. Thread separation can tear your rig apart.
1996 Airstream B190
AIR #13
Old 02-20-2013, 05:16 PM   #327
Silverton , Colorado
Ya know, Derek, I put Michelins on my rig, and I will have to do so, again, like soon...yeah, it hurts at the register, but I really like the extra safety factor...
Michael & Tracy
1989 345 Motorhome
CHARTER MEMBERS: FOUR CORNERS UNIT, AND PROUD OF IT!!!
We live for the moment, 'cause when you get there, it's gone...
ScrapIrony-2 is offline   Reply With Quote
Old 02-20-2013, 06:14 PM   #328
crazeevw's Avatar
To be honest, I'm buying tires since what I have are all over 10 years old. For the most part, what I'm buying now will only hold up the Airstream off the ground for the next 7 years or so. Purchasing Michelins or Goodyear for only that purpose seems to be a waste of $. Doubt that I'll be doing much of any traveling until I retire in another 8 to 10 years. Don't see what I have at the moment lasting that long. Still, wanting something that will at least take me for an a couple of hours drive to a remote camping ground.
But, if cheap tires are going to fail.....
Thanks, Derek
Old 02-20-2013, 06:46 PM   #329
Hey Derek,
Check with Mike Leary...he's been on the road for a long time, and I seem to remember that he had a favorite
Michael & Tracy
1989 345 Motorhome
Old 02-20-2013, 09:22 PM   #330
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
Here is one guys opinion of Hercules tires.
Hercules operates wholesale warehouses in the United States, Canada, and China. The company was founded in 1952 and is headquartered in Findlay, Ohio. But, does Hercules make the right tires for you?
Is Hercules Right for You?
by Drew Gill
My day job would have to be one of the toughest on vehicles and tires (working in an open cut coal mine)in the world. A vehicle is purchased brand new and usually lasts about a year. The life of a set of tires can vary depending on the season, but many don’t last more than 10,000 miles. We’ve had many different brands and types of tires over the years and the ones my boss seems to keep going back to are Hercules. Now, I don’t exactly know why that is, he could just be getting them cheap. However, the Hercules tires seem to do fine and, if they are cheaper than most options, I can see why he does it.
Probably the most common tire killers at work are screws and nails that are left lying around, but also worth a mention are some of the sharp rocks and other debris that get uncovered or fall off vehicles. Chunks of coal or rock often fall out of dump trucks and can instantly punch a hole into a tire that can’t be repaired no matter how good the repairer thinks he is.
On the Road
On the road surface, our Hercules tires seem like a good choice, although I’ve noticed wet weather driving can be a little slippery. We generally cruise along a same section of highway each day to get to a remote area of the mine and it means driving highway speeds for around an hour each way. There is some feedback through the suspension compared to some of the tires we’ve used in the past, but I think those Hercules are a good compromise for the road and the unsealed road surfaces we have to navigate.
It’s important to be able to maintain communications at all time, whether that is via radio or phone, so road noise can be a clincher when it comes to making tire decisions. The Hercules Tires do make a bit more noise than some of the other tires we’ve had in the past, but it’s not surprising given their appearance. They have that real off-road look with a very pronounced tread.
On the Dirt
Throughout the mine, there is a lot of different surfaces and each one presents a different challenge for a vehicle. For the majority of the time, we are driving over a surface that is a combination of coal and dirt, but there are unsealed roads that are a heavy red soil and others that are rock. When the surface is wet, it can be either slushy and boggy or extremely slimey and slippery.
In the mud, the Hercules tends to cope with the slippery situations we encounter a lot better than some of the other brands of tires. Open cut coal mines rely on water trucks that disperse a steady spray of water over the roads in order to control dust. This means that many of the road surfaces are quite boggy and slippery- even in the searing heat of summer. In fact, it isn’t entirely uncommon to drive through thick mud, followed by dry sand-like dust and then over rock before finally travelling a paved section, all in a matter of a very short distance.
Hercules' Range of Tires for Light Trucks and SUVs
Terra Trac A/T
Hercules describes the Terra Trac A/T as a premium all terrain tire that performs at its best in challenging driving conditions. It has an advanced tread pattern and an aggressive sidewall to combine strength and durability, but with a smooth and quiet ride when cruising.
All Trac A/T
This is a light truck tire with on/off road capability. While being an all terrain tire it still is able to give high mileage and even wear. Its aggressive tread design ensures the tire is able to perform in all types of elements.
Terra Trac SUV
This Hercules tire is aimed at the SUV and light truck markets. The tire has been engineered with a solid center rib for enhanced steering response and sipped to maneuver in wet and dry conditions. Terra Trac gives a smooth, peaceful ride when cruising on highway or town road surfaces.
MR IV SUV
This tire is specifically designed for SUV and CUV fitments. The tire features a smooth and quiet “car-like” ride with excellent wet and dry traction. It’s a tire that can go the distance as well as perform with the best.
Terra Trac Radial Rib
This tire has a 5-rib design for smooth running performance and exceptionally long mileage. The tire’s aggressive center rib gives great all weather performance and outstanding road traction. The tire’s wide tread arc provides traction and long, even tread wear.
Terra Trac H/T
Hercules says that this tire has a strong rib design so that it can provide all-season traction with long even tread wear. It provides a smooth and quiet ride for highway cruising and the tire comes with M and S ratings.
Trail Digger M/T
This Hercules tire is designed with stone “blockers” to increase puncture resistance. The XXL scooping tread lugs give the Trail Digger maximum traction in mud, gravel, and sand. Pinned for studs.
Terra Trac A/W
This is a versatile truck tire that offers peak performance for the person that wants to go on or off road. The tire has two steel belts plus two nylon cap piles under the tread to offer puncture protection. The tire also has advanced sidewall contruction that protects against impacts. The tire's advanced tread design offers longer tread and a quiet ride while cruising on the highway.
Loads of Hercules Tires Available
Hercules Tires also make performance tires, truck tires and regular family sedan tires. Whether you're travelling through a coal mine, driving a truck load of cattle or just travelling to work in city traffic, Hercules Tires have something for every application.
Read more: Hercules Tires
They might be fine for what you are looking for.
Cheers, Dan
~ Margaret Thatcher ~
Old 02-21-2013, 05:14 AM   #331
Thanks, Derek
The Greek god?!
This is all I could find on Hercules Tires.
Old 02-21-2013, 07:15 PM   #332
Blue Eye , Missouri
I had the same problem with fresh water tank. I fixed the leak with 3m 5200 fast cure caulk. Sand the area first spread a layer of 5200 on tank then press a thin piece of aluminum over the crack. 5200 is moisture cured you will probably have to purchase it from a marine store. 5200 is a adhesive/sealer. I have used it for years in boat repair.
Steve Fennema
stfennema is offline   Reply With Quote
Old 03-19-2013, 09:31 PM   #333
crazeevw's Avatar
Not a lot going on with me and the Airstream
BUT,
Just for S**Ts and giggles, decided that the rear of my Airstream was the perfect place for a select collection of bumper stickers. Not as if I'll be using that rear-view mirror up front, to look out the back much, right?
After reading the forum update from Andy about Airstream not stocking the windshield gaskets any longer, I did order a 16oz bottle of 303 Protectant today. Let's see if I can't keep this gasket forever!
Oh, here's the collection of stickers. Last one is one I'm looking for anywhere!
ID:	181425   Click image for larger version
ID:	181427   Click image for larger version
Old 04-03-2013, 08:34 PM   #334
crazeevw's Avatar
Finally!
Back at the motorhome. Able to get inside, drilled out gosh knows how many rivets, removed phillips screws, and the upper cabinet behind drivers seat is finally down!
Trying to figure out the best way to disassemble this without any damage. Did discover that the lower section had rivets drilled out at some point. Will go through all upper cabinets next to make sure that those rivets are there. Certain that I'll need the support for my items.
Did go and splurge today. Found a 1988 Airstream Motorhome Dealer's brochure on eBay. Paid MUCH too MUCH for it, but I've always wanted one, and even though mine is a 1989, figure one year off, I may never find another...
ID:	182434   Click image for larger version
Old 04-03-2013, 10:52 PM   #335
Redwood City , California
Finally!
Hi Derek,
I've been wondering what you have been up to. Glad to see you in the mh doing some work!
http://projectupdraft.com/airstream
"We are free to go where we wish and to be what we are"
Richard Bach, Jonathan Livingston Seagall
dadstoy is offline   Reply With Quote
Old 04-07-2013, 02:44 AM   #336
wxbuoy's Avatar
1991 35' Airstream 350
Carriere , Mississippi
Send a message via Skype™ to wxbuoy
Derek,
What are you going to do with the cabinets that you need to disassemble them? Unfortunately, looking at mine they all appear to be joined with dowels and glued at the joints. You can cut yours with a very fine and redo, but not worth the effort and you may see it in the end product. If you are just looking to fix the joint try some solvent to loosen the glue a bit. clean it real well and re-glue and clamp. Than on the backside or top you can put a screw, dowel or bisket across the joint.
You are definitely making more progress than me! Please keep us posted!!
Dave and Felicia
wxbuoy is offline   Reply With Quote
1989 Airstream Classic 345LE Motorhome eBay Watch Airstreams on eBay 0 10-26-2011 10:30 PM
Classic vs Classic limited Flying Gypsies 2006 - 2010 Classic (all lengths) 13 10-15-2011 06:37 PM
2011 Classic Limited 30 :: 2011 Airstream Classic Limited Wyndridge2 Airstream Registry Discussions 0 08-19-2011 08:32 AM
1989 Airstream 345 Luxury Edition Classic Motorhome RV eBay Watch Airstreams on eBay 1 07-02-2011 07:57 AM
Classic -vs- Classic Limited 10Smiles Dollars & Cents 11 06-22-2011 08:33 PM
