Old 08-08-2012, 10:56 PM   #239
crazeevw's Avatar
1989 34.5' Airstream 345
Saint Petersburg , Florida
Ok, out in the moho last few evenings. Thinking there's a possibility of camping over Labor Day weekend. Turned on the fridge a couple of nights ago, now I have hardly any coach battery! I've got the fridge that 'automatically' selects from 120V or gas. Could the circuit board be fried? Or am I looking at something more?
Thanks, Derek
Old 08-09-2012, 12:56 AM   #240
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 57
What brand of fridge?
The panel should tell you what its running on, ac or gas. Are you plugged into power? Can you not select what you want it to rum on?
If you are on 12V with gas, it should run longer than a couple days before draining the battery=ies?
Dave
Thanks, Derek
Old 08-09-2012, 08:10 AM   #241
raveson's Avatar
boca raton , Florida
derek
Is your frig orig as is mine? I had problems with the main board controlling the frig 7 years ago. Mine would not run on gas only. A problem making me run the gen to keep cold on the run. OEM boards are pricey making you wonder if you should replace the whole unit. I found a place in OR called Gator boards.If you want the number or cannot find them on the web, I'll find the receipt to get you the number. I think if the frig gets cold and stays cold, a fix will work. If the battery still goes dead when plugged in to shore current, I think you are still dealling with the power problems.
Richard
raveson is offline   Reply With Quote
Old 08-09-2012, 08:26 AM   #242
t7389sg's Avatar
1991 35' Airstream 350
Laurel , Maryland
It’s not likely that the refrigerator control board could be drawing enough currant to drain a good, charged battery. If it was there would be a lot of heat coming of the board as those circuits draw very little power. If the fridge is a 3 way and can run on gas, 120v, and 12 volt, that could draw down your house battery. I suspect it might be something else on board drawing down the house battery or the battery is starting to fail. Steve
t7389sg is offline   Reply With Quote
Old 08-09-2012, 02:59 PM   #243
crazeevw's Avatar
Dometic RM2652
Ok,
This I know for certain. This fridge is a replacement by PO. When he purchased rig 3 years ago, original fridge was removed and a 120V college size was installed.
Anyhow, when I turn on the fridge, using only the 'Power' button, it almost seems as if fridge is constantly trying to see if it can go to gas operation. This all while moho is hooked up to electrical. Next day, I've got hardly any coach battery left, even with the LED replacements I've done.
Has anyone replaced the circuit boards in these things? Could it be something simple like the board behind the power switch?
Thanks for any and all help and suggestions, Derek
ID:	165306   Click image for larger version
Old 08-09-2012, 03:02 PM   #244
crazeevw's Avatar
oh, fridge is only 120V and gas operation only. Maybe one day I'll get a 3-way fridge.....maybe something like this, since there's about 4 to 5" off to the right of the fridge next to the dinette......a little bit of carpentry.....
Old 08-09-2012, 06:13 PM   #245
t7389sg's Avatar
Laurel , Maryland
If your refer has a light inside, I wonder if it goes out when you close the door?
Old 08-09-2012, 08:38 PM   #246
crazeevw's Avatar
Was out in the moho this evening. Had fridge turned off completely. Had both freezer and fridge doors open when I powered it up. Fridge light came on when I powered up the fridge. Went off when I turned off fridge, so guess that's not my problem.
I've been inside with the old florescent lights going, and it seemed like they dimmed, then went bright for about the same amount of time as being dim.
This makes me believe circuit board is 'hunting' for LP gas, instead of using the 120V which is already there.
Guess I'm just gonna pull the board and see if I can find a replacement.
One question, the control panel on top of the fridge has some sort of circuit board, is there another circuit board somewhere else (back of fridge)??
Thanks, Derek
Old 08-09-2012, 09:21 PM   #247
t7389sg's Avatar
Laurel , Maryland
Here is a link to the troubleshoot manual. http://gasrefrigeration.net/dom_tech...121_2852SM.PDF looks like the power module in the bottom half has fuses you could check. If the fridge does not Sense a/c current IT goes to gas and tries to light every 45seconds. I guess that could drain a battery.
Old 08-12-2012, 06:43 PM   #248
crazeevw's Avatar
Uh-Oh.....
Ok,
So I finally decided that I had to get Airstream out on the road, just to feel like I don't have a Aluminum yard ornament.
So, here I am driving along, went to use turn signal to make a turn, and no signal. Looked at Voltmeter, and it's buried below 10 volts! Guess I'm gonna have to replace the Alternator.
Have long ago decided from others experiences that AutoZone and Advance are NOT the place to be buying parts for the Airstream.
Was about to head to NAPA and a mechanic friend strongly suggested that I pull alternator and take to a local rebuild shop. He mentioned that even with NAPA I could end up with a POS. His experience has been with local rebuild shop is that same guy who tears apart your alternator is the same guy who rebuilds it. All at or close to same price that the low-cost parts stores offer.
Any thoughts or suggestions?
Thanks, Derek
Old 08-12-2012, 07:02 PM   #249
OK...
Firstly be aware that the gauge maybe wrong or malfuntioning... same goes for the wiring to it!.
Break out your Multimeter..
Test the coach battery, if its less than 12.5v, recharge it.
After that, start and run the motor, and test the battery when its running... you should be getting 13.0v or more... If not, you need to go thru every connection from the Alternator to the battery including the grounding....
Start there and report back...
Old 08-12-2012, 07:47 PM   #250
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
Derek,
The easiest way to get started with the voltage check is at the Battery isolator in the front engine compartment.
With engine off, the center post (alternator connection) should read ~zero volt and the other 2 posts should read coach and engine battery voltage.
Then with the engine running you should get alternator voltage on the center post and appr the same voltage on both battery posts. Any variances indicate problems with some of the components.
Good luck!
1996 Airstream B190
1997 30' Excella Wide Body Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 08-12-2012, 07:59 PM   #251
1982 28' Airstream 280
Redwood City , California
Hey Derek, sounds strange that your battery would have discharged so much in your drive today due to a non working alternator that the turn signals wouldn't work. Do all the appropriate testing before replacing the alternator. Also test your battery isolator to see if it is working...see the link below. The Chevy Motorhome chassis service manual has a great section on testing outputs. Look to see if the sense wire connector is still connected to the alternator. Mine is very loose even on my new alternator. I zip tied the wire to the alternator bracket so the connector wouldn't come off.
If you find that you do need to replace the alternator, consider going with a high amp alternator. I replaced mine last year with a 200 amp alternator and a 220 amp battery isolator. I have multiple receipts from my dad where he replaced the alternator. I've driven cars for 10 years and I never had to change the alternator so I wondered why the MH was going through them. After doing some research and hearing that this was a common problem on MH's, I found out what one of the common reasons was for this. The stock alternators may only put out between 65 and 105 amps. If the amp draw on the alternator is greater then this, the alternator will soon burn out. Today it's easy to put a large amp load on the alternator by charging engine and coach batteries and running all the electronics that we do today.
I agree, don't buy from the Autozones and I'm not that fond of Napa either. I went around to some auto electic shops around here to see if they could rebuild mine as a higher amp alternator...they stared at me like I was a Martian asking them to rewire my space ship! I found a company in Florida that builds high output alternators and I bought one from him...I went elsewhere for the new isolator since I could get it for less. Only issue is the high amp alternators are that they are very pricey but you certainly won't be burning them out. I've put 3000 miles on the new one in the last 1.5 yrs and all is working great.
http://www.ase-supply.com/v/vspfiles...dables/sp1.pdf
"We are free to go where we wish and to be what we are"
Richard Bach, Jonathan Livingston Seagall
dadstoy is offline   Reply With Quote
Old 08-12-2012, 08:06 PM   #252
Look at section 7 of the chevy MH manual...
1989 Airstream Classic 345LE Motorhome eBay Watch Airstreams on eBay 0 10-26-2011 11:30 PM
Classic vs Classic limited Flying Gypsies 2006 - 2010 Classic (all lengths) 13 10-15-2011 07:37 PM
2011 Classic Limited 30 :: 2011 Airstream Classic Limited Wyndridge2 Airstream Registry Discussions 0 08-19-2011 09:32 AM
1989 Airstream 345 Luxury Edition Classic Motorhome RV eBay Watch Airstreams on eBay 1 07-02-2011 08:57 AM
Classic -vs- Classic Limited 10Smiles Dollars & Cents 11 06-22-2011 09:33 PM
