Old 06-14-2012, 10:37 PM   #197
Originally Posted by dadstoy View Post
Oh my, check out that dent where the ladder is mounted!
Yeah, Dean I spotted that too...
I cannot imagine mounting such a small foot on the soft Aluminum skin!
Does anyone else have to wait forever for the larger pic to load?
Derek, I would not get up on the roof without a couple of carpet protected planks....
I will be making some soon so I can get up there and remove the old TV antenna and replace it with the new one and reseal.
Old 06-21-2012, 10:46 PM   #198
crazeevw's Avatar
1989 34.5' Airstream 345
Saint Petersburg , Florida
questions....
Ok,
I've got a replacement capacitor for the rear A/C. Fan runs, but compressor won't kick in at all. Any hints, suggestions as to how to replace the capacitor? Know that I need insulated tools, and for good measure maybe even rubber gloves, especially with the voltage these things can accumulate.
Another question, my A/C covers are painted black. Anyone ever tried to find an aluminum colored spray paint? If you have, which brand and color # was it? Figure if I'm going to pull cover off to replace capacitor, may as well change the color.
Thanks, Derek
Old 06-21-2012, 11:13 PM   #199
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 57
Handle those covers with care as they crack easily when they get old.
Dave
Originally Posted by crazeevw View Post
Ok,
Thanks, Derek
Old 06-22-2012, 04:52 AM   #200
crazeevw's Avatar
Hi Dave,
Beginning to think I'll be replacing both A/C's soon anyhow, but will be sure to wear kid gloves while handling the existing covers. Thanks for the advice, Derek
Old 06-22-2012, 09:08 AM   #201
As I am sure your Dad will tell you, the ac covers are plastic so will need good cleaning and an adhesion promoter primer. I like Bulldog.
Old 06-22-2012, 11:32 AM   #202
Waipio Rim's Avatar
1984 31' Airstream310
Honokaa , Hawaii
The panel with the capacitors attached is in the left rear of the a/c unit once you get the cover off. Careful with the nuts holding the covers on, mine were rusted and I probably could have finessed them all off, but got in a hurry and broke a couple of studs.
Waipio Rim is offline   Reply With Quote
Old 06-22-2012, 09:36 PM   #203
crazeevw's Avatar
Just got some great advice from Lewster concerning replacing the capacitor.
"There is a large jolt contained in a fully charged capacitor......and they really bite when they hit you!!
I assume you have a volt meter. After removing the shroud, locating the capacitors AND TURNING OFF THE CIRCUIT BREAKERS FOR THE ROOF AIRS, put your meter to 'AC VOLTS' in the 100+ volt range. Then use the probes to touch each pair of post of the capacitors until they are drained (the meter load will drain the voltage from the caps). Hit all of the posts (two at a time) until they are all nominal."
So, if any of you are about to do this, I'd say follow these simple steps. I know I sure am, after working construction, and WAY too many encounters with 110V live wiring, I'm all about avoiding any 'jolts'
Now I've gotta see if Keyair won't post pix of how he managed to get up on roof of his Classic......
Old 06-22-2012, 09:56 PM   #204
I have one of those folding ladders I keep at the AS.
Unfurled it into straight mode and put it against the curbside awning cover.
From there I just climbed up and picked my foot placement carefully.
If you do it in sunlight, be careful as the darned roof was hot!
I am making a couple of planks that I will cover with old carpet to protect the roof for next time, when I get up to fix stuff. I think its safer for me and the roof!
Old 06-23-2012, 12:19 PM   #205
crazeevw's Avatar
Rivets?
Concerning Rivets on Classic motorhomes. For some reason, the rivet on the lower rear curbside awning bracket has decided to give up the ghost. Understand that there are several rivets used in Airstreams. Anyone have an idea what I need, and if I HAVE to go to Airstream to purchase?
Thanks, Derek
ID:	161628   Click image for larger version
Old 06-23-2012, 12:24 PM   #206
crazeevw's Avatar
and if you look closely at the photo, you'll see I'm home for lunch, postal truck in reflection, as well as pup, lol
Old 06-23-2012, 12:51 PM   #207
Whilst you need to determine the head size and depth you need, there is some good reading info here...
Bulb Tite Rivets | Blind Rivets & Olympic Bulb Tite Rivets from Bolt Products - Bolt Products, Inc.
Old 06-23-2012, 09:18 PM   #208
crazeevw's Avatar
Thanks Steve, will read ALL of this tomorrow, as it is, me and pup are heading out to Airstream to sleep whilst the rain drops on the aluminum, as well as CHECK for leaks, lol
Thanks, Derek
Old 06-23-2012, 09:47 PM   #209
1982 28' Airstream 280
Redwood City , California
Derek, did you get any attachments with your counter mixer you bought?
"We are free to go where we wish and to be what we are"
Richard Bach, Jonathan Livingston Seagall
dadstoy is offline   Reply With Quote
Old 06-24-2012, 04:09 AM   #210
crazeevw's Avatar
Hi Dean,
Got all sorts of attachments and just realized that I did just win the Melamine mixing bowl on eBay this week. Will post pix of attachments when the sun rises.
Thanks, Derek
1989 Airstream Classic 345LE Motorhome eBay Watch Airstreams on eBay 0 10-26-2011 11:30 PM
Classic vs Classic limited Flying Gypsies 2006 - 2010 Classic (all lengths) 13 10-15-2011 07:37 PM
2011 Classic Limited 30 :: 2011 Airstream Classic Limited Wyndridge2 Airstream Registry Discussions 0 08-19-2011 09:32 AM
1989 Airstream 345 Luxury Edition Classic Motorhome RV eBay Watch Airstreams on eBay 1 07-02-2011 08:57 AM
Classic -vs- Classic Limited 10Smiles Dollars & Cents 11 06-22-2011 09:33 PM
