06-22-2010, 08:44 AM
1988 34.5' Airstream 345
Indianapolis
, Indiana
1988 345 Classic Dash Air Con
Has anyone converted their dash AC. Just got a quote for $1800-$3000??? Does anyone have a better solution. I would like to have that dash air working but not for 3K!
06-22-2010, 09:08 AM
1989 37' Airstream 370
Louisville
, Kentucky
I just replaced the hoses to get the right fittings and because one was damaged new drier and charged the unit. That was 6 years ago still works fine on 134A total cost @ $200.00. If you want to make a trip to Louisville I can do it for you.
06-22-2010, 10:23 AM
Indianapolis
, Indiana
Ac unit
I've been told my compressor is bad as well which is what started the entire process. Something about having to convert to Puran or some newer type of refrigerant.
06-22-2010, 01:46 PM
1967 26' Overlander
Huntsville
Depends on what might need replacement
Occasionally, a compressor will go bad and pump trash through the system which can not be reliably cleaned out. Should that be the case, the repair cost could be high as certain high-dollar items will have to be replaced.
But a new compressor is only $200 - $300, and a re-manufactured one about half that. Add new freon, oil, receiver/dryer, and an hour or so of the man's time should make the job cost less than $500.
Ask the man what he intends to do in return for $1800 - $3000.
Tom
06-22-2010, 05:22 PM
Indianapolis
, Indiana
AC replacement
Tom, he says they can't repair old units due to the freon. Are they not allowed to utilize the older freon any longer. That big price is for all new, compressor, new If custom bent refer lines and charging the system with the new eco friendly puran refrigerant. Basically an entire new system. If I could just get it fixed that would be great!
06-22-2010, 05:34 PM
Wise Elder
2010 30' Classic
South of the river
Keep looking. There are places that will repair and recharge with R-12. Legally they can do it if an upgrade to R-134a isn't practicable.
There are also many attitudes and approaches about conversion with many shops now evacuating and charging with R-134a and ester oil without replacing any parts except for the fill ports and the filter-dryer. In practice you can get a few years out of this approach in most cases.
Nonetheless auto A/C work is expensive. It's time consuming for the shop, and they tend to find more problems as they fix stuff. I just spent over $1000 on A/C on my tow vehicle, replaced the condenser, well the compressor was shot too, replaced that with used to save money, used compressor leaked, replaced again under warranty, used compressor leaked, replaced with new compressor. Some labor and parts charges credited due to the warranty but still an expensive repair.
06-22-2010, 06:08 PM
Foothill Ranch
Nellie,
Not done this on my 345 yet, but its in the works...
I have done this on my 1987 Suburban with the same motor... My 1984 Mercedes Diesel and my 1973 Chevy Pickup.
If the compressor is toast then replace it, also you should have the system flushed and the O rings should be changed too.
I used a r12 replacement called ES12... Its enviro safe, compatable with all oils and O rings and works better than the R134 that they push on you. Its cheap too... I bought enough to do 4 cars, for $100 shipped...
Find a better shop... I know they need to make a living, but $3k???
Come on!
I assume you are a lady, and shops mess with ya. Take a big burley guy with ya to get a quote!
06-22-2010, 07:10 PM
Wise Elder
2010 30' Classic
South of the river
ES12 is a mixture of propane and butane plus additives. It's just as flammable as propane and overall just as dangerous in every way. I would never put it in any car, and I would encourage you to safely remove it from your cars and trucks and dispose of it as soon as possible.
06-22-2010, 07:31 PM
Foothill Ranch
Whilst I respect your right to your opinion, I researched it very carefully, and in fact its less flammable than R134a that is in all cars with A/C produced after the mid 90's, and many were retrofitted from earlier.
Also, because its far more efficient than R12 or R134, you have less of it too!
Take it out for my own safety?
I am not worried about 8 ozs of a refridgerant when I have up to 80 gallons of gas, and 125lb of Propane strapped to my belly!
If it was MORE dangerous than R134, they would never have approved it for its intended use....
http://autorefrigerants.com/Envirotechnical.htm
06-22-2010, 08:02 PM
Wise Elder
2010 30' Classic
South of the river
Try this. Fill one balloon with R-134a. Fill one balloon with ES12. Light each one with a match, then tell me which one is more flammable. Wear safety glasses and stay in an open area, at least for the ES12 balloon.
R134a is not flammable at standard pressures as would be the case with a leak, or in a balloon. ES12 is flammable, and will burn vigorously. An 8 ounce charge, leaking into the passenger compartment and becoming ignited, would be enough to turn the car into a fireball.
The marketing materials for ES12 skirt the issue by focusing on the auto ignition point, which is a red herring, and by referring to the contents as "Alkenes" which most people don't recognize as the generic name for methane, ethane, propane, butane, etc.
Flammable refrigerants are prohibited in many states and also, for motor vehicles, at the federal level:
Legal Status of HC-12a Ž, DURACOOL 12a Ž, and OZ-12 Ž | Alternatives / SNAP | US EPA
The difference is that the 125 pounds of propane are in an ASME tank with 1/4" thick steel walls, that has some sort of maximum flow limitation, and is connected to a distribution system engineered for fire safety -- copper lines and hoses specifically designed and manufactured for propane -- which operates at less than 1 PSI. Further, only the gas is present in the distribution lines.
In your air conditioning system, liquid propane circulates through the evaporator in the passenger compartment. In the event of damage, the entire charge could be released in a matter of seconds.
Similarly, the gasoline is contained in a fuel system with safeguards intended to contain the fuel in the event of a collision. The fuel lines do not enter the coach.
06-22-2010, 11:29 PM
Foothill Ranch
Jammer,
Clearly I am not as well informed or versed with this as you and I bow to your greater knowledge.
However, whilst your statement about fuel lines entering the passenger compartment is true, the chances of a rupture of any A/C lines WITHIN the passenger compartment is equally rare and indeed unlikely.
Accidents occur, fires occur, people are hurt and worse every day. These are all facts that in my profession we worked to prevent.
I saw the results of a simple accident that sheared the regulator off an approved1/4" thick and certified Propane Tank... Nobody died, and nobody was hurt, but it was close.
I have been in simple accidents where there was fuel fires that ran out of control.
As I said in my opening statement, we are able to make personal choices.
I respect your opinion, and that you dont agree with mine.
I wear a seatbelt, I drive defensively, and I am comfortable with my choice to put 12oz of Es12a in my older vehicles.
Vive USA!
06-23-2010, 11:21 AM
Wise Elder
2010 30' Classic
South of the river
Keyair,
If it is your choice to run propane refrigerant in your cars, well, that's your choice.
My concern is that your efforts to encourage other forum members to use it, and comments like:
I researched it very carefully, and in fact [ES12 is] less flammable than R134a that is in all cars with A/C produced after the mid 90's, and many were retrofitted from earlier.
may mislead forum readers into believing that ES12 and other propane refrigerant products are as safe as R134a. They're not.
The utility of propane and butane refrigerants has been understood for decades, and R11, R12, and R22 were originally adopted as a refrigerants because the flammability of propane and butane were widely thought to make them unacceptably dangerous for air conditioning and refrigeration outside an industrial environment. R134a has been the refrigerant of choice for automotive use because, while having a thermodynamic efficiency lower than that of R12, it is nonflammable, nontoxic, and not ozone depleting.
From your prior posts I gather that you installed ES12 without understanding the risks. Now that you know the risks, if you choose to keep it in your cars, yes, that's your choice to make.
It is my hope that others on the forum, reading this thread, will understand the danger before installing such products. There are a number of propane refrigerant products on the market. In my area some shops were quietly selling a propane product called "Red Cap 12" for a while, for example. Since the sales and installation of these products is of doubtful legality and open to considerable product liability risk, the brand names come and go.
Another fact to consider is that propane refrigerants pose a risk to future service technicians who may end up working on the vehicles where they are installed. The safety procedures for working with flammable gases are not ordinarily used when working on automotive refrigeration systems, so, for example, someone might be working on such a system in an enclosed service bay adjacent to one where a cutting torch is in use.
06-23-2010, 11:46 AM
1968 24' Tradewind
Oxford,
, Mississippi
$3000 bucks is a rip off. I have converted 3 different vehicles from R-12 to R134a. They all work well. Each system is a little different, some have expansion valves, some have orifice tubes. Sometimes they must be changed during the changeover but they are cheap. If it were mine, I'd remove the old parts,flush the system with A/C flushing fluid. Install the new parts and hook it up to a vacum pump for about an hour and recharge it with R134a. Rule of thumb on 134 is that a system takes about 75% less than r-12 by weight. Even with a new compressor ( don't bother with a rebuilt one, the difference in the cost is money well spent), receiver/dryer, expansion valve, belts, and refrigerant and you are looking at less than $500. Add 2 or 3 hours labor @ $75/hr and you are still way under $1000.
06-23-2010, 12:11 PM
Wise Elder
2010 30' Classic
South of the river
06-23-2010, 01:01 PM
Foothill Ranch
FYI, Jammer.
I have the stickers clearly stating that the system is filled with ES12 on all my cars that have it.
As I have pointed out, I use it, and have had good results, and its legal to use, and many thousands of people buy and use it every day. Why would I not bring it to the attention of forum members?
You have pointed out the pitfalls, given your opinion and I have been respectful.
I find the link you posted interesting and disturbing at the same time, yet the title speaks volumes, as the first recorded incident. I am sure its not the only one nor the last one, but come on!
Engine fires are common, in fact I had a belt shred on one of my ES12 fitted trucks a month ago, causing the belt to chop off the main generator belt, welding the loose end to the bracket and causing a lot of smoke and a small fire. Did the truck explode because I have ES12.... no.
Your comment about welding in the same bay as a Tech working on an ES12 filled system is also interesting... What kind of moron welds ANYTHING in a shop where there is other people working on engines... say much more commonly the other guy is changing a fuel filter... Gasoline is heavier than air too, and there is far more of it floating around in most shops...
You clearly have a bee in you bonnet about ES12, and I kinda see why, but lets be realistic about the risks.
You can post again, and I am sure you want the last word, but respectfully, I am done with the discussion.
All I wanted to do was to pass on my good experiences with a product, as I have a right to do.
06-23-2010, 02:07 PM
Wise Elder
2010 30' Classic
South of the river
I disagree that ES12 is legal to use. I quote from the EPA web site:
May hydrocarbon refrigerants be used to replace CFC-12, commonly referred to as "FreonŽ ," in cars?
No. It is illegal to use hydrocarbon refrigerants like HC-12aŽ and DURACOOL 12aŽ as substitutes for CFC-12 in automobile or truck air conditioning under any circumstances.
[....snip....]
[In addition to the federal regulations,] EPA is aware that the following states prohibit the use of flammable refrigerants in automobile air conditioners: Arkansas, Arizona, Connecticut, Florida, Idaho, Iowa, Indiana, Kansas, Louisiana, Maryland, Nebraska, North Dakota, Oklahoma, Texas, Utah, Virginia, Washington, Wisconsin, and the District of Columbia.
If your point is that there is a lack of effective enforcement, I would agree, though due to the state laws this is starting to change.
Bear in mind that the article I posted is dated 2004, shortly after these products started to be popular due to the price spike for R-12 (New cars made in 1994 and later used R-134a, and production of R-12 stopped at the end of 1996. Prices peaked several years later and then came down as the amount of refrigerant being recovered from scrapped pre-1994 cars and other sources exceeded the demand; also, the cost of switching to R-134a declined as service techs became more comfortable and started replacing fewer parts).
There is, as far as I know, no tracking and reporting of fires or explosions involving propane refrigerants, so we have no idea how widespread such events are. I will note, however, that a casual google search shows that such accidents are common in Australia, where the use of propane refrigerants is more widespread particularly in industrial settings. Many of these have resulted in fatalities.
I would be surprised to learn that these stickers clearly identify the hazard. You, yourself, were under the impression that this is a non-flammable product, and have seen the stickers as well as whatever else Envirosafe includes with the package. How would a service technician know the risks?
The problem is one of awareness. I know quite a few people who weld in a shared service bay where adjacent technicians are performing air conditioning work. Technicians understand the hazards of gasoline. They do not expect a refrigerant leak to pose comparable hazards. ES12 does not contain a universally recognizable odorant and so the gas can accumulate without warning signs. With gasoline, leaks are visible, and you can smell them.
I have a bee in my bonnet about ES12 and similar products being distributed without a clear acknowledgment of the risks. It's a mixture of propane and butane. Propane and butane ignite readily and will burn or explode. Ignition sources are constantly present in car interiors (brushes on the blower motor, for example), and if this stuff leaks out of the evaporator, it may ignite or even explode. Smart people, like you, are using the product without understanding that, because the true nature of the product is being glossed over.
I believe that the environmental hazards posed by R-12 have been exaggerated. The damage to the ozone layer, and its recovery, is mainly a story about bromine compounds, methyl bromide chief among them. The effect of CFCs, while significant, was small by comparison, and not enough to justify the regulatory hysteria. Getting the R-12 (well, propellant-12, but chemically it's the same stuff) out of hair spray cans probably would have been sufficient by itself to meet the environmental goals.
Nonetheless, R-134a is readily available now. Conversions are cost effective, performance is sufficient in all but a few applications, and the product is safer than the propane/butane mixture, and nearly as safe as the R-12 it replaces. Further, the price of R-12 has now fallen to the point where it costs about the same as R-134a, providing a viable alternative for those few systems that do need its slightly better thermodynamic performance.
06-23-2010, 05:18 PM
1967 26' Overlander
Huntsville
I hope we did not run her off
I have personally enjoyed the discussion about the alternative refrigerant available. It was enlightening, and I thought both players did a great job stating his/her views on the subject matter. A round of kudos to all.
nellie1960: Please keep this thread updated as to the course of action you decide to take to restore cool air.
Tom
06-24-2010, 06:10 AM
Indianapolis
, Indiana
Ac
Wow, I love this forum! While probably more confused than when I started it had given me many options. If I had my way I would buy a new compressor and dryer and find someone to charge it with that dreadful R12 that critics are so concerned about. Does anyone have a replacement part number or source for new compressor for my chariot. It is a 1988 but I my chassis is a 1987 P30 with the 454 Chevy V8. The truck shop working on my unit just replaced all the vital under carrige air bags with a slick install on the front air adjustable shocks. Drives so much nicer! Still would love to have that dash air working when driving. Been so hot here.
11-13-2010, 08:17 PM
Kenneth
1987 34.5' Airstream 345
Waxahachie
Hope I'm not to late. When I revived my dash air, I put a new compressor, new hoses, and new expansion valve on, then I charged it with R12. If you look hard enough you can still find it for around 18.00 per can. Did the entire project for less than 500.00. Don't forget to flush out the condensor and evaparator coils..
07-30-2014, 12:28 PM
1988 34' Limited
Phoenix
Get all the info you can because I just went through this and it cost around 4K because everything had to be retro fitted.
