Old 08-23-2019, 07:20 PM   #1
1988 29' Airstream 290
San Francisco , California
1988 290 LE: 8.1L + Allison Swap
Thought you guys would get a kick out of this. Stage 1 of my 8.1L swap in my motorhome. Big thanks go to Moodified13 for not just showing it was possible but for providing lots of guidance along the way
First step was was getting the beat-ass old 454 and TH400 out of the rig - a bit of a tricky task when you only have inches of vertical clearance and no way to get a standard engine lift in there.
Referring the historical documents left by Moodified, we built some forklift extenders bolted up to the exhaust manifold studs. We then lifted and pulled the engine/tranny out through the front.
Few things I would do differently the second time - but it worked well enough.
ID:	350296   Click image for larger version
ID:	350298   Click image for larger version
MarshallSF is offline   Reply With Quote
Old 08-23-2019, 07:24 PM   #2
8.1+ Allison -Continued
More pics of the engine + tranny removal
ID:	350300   Click image for larger version
ID:	350302   Click image for larger version
Old 08-23-2019, 07:37 PM   #3
8.1 + Allison Swap
We were feeling pretty scrappy and resourceful with our bolt-on lifting forks + tractor setup. Until we tried to lift for the first time. Nada. Turns out the lifting capacity drops off quickly as you move out from the bucket attachment point. Luckily we had my engine hoist and were able to scrap together the non-OSHA approved jerry rig shown here.
Old 08-24-2019, 04:33 AM   #4
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Innovate, adapt, overcome.
Stay tuned for the next chapter shoe horns and grease on the tight spots plus a bigger lifter.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 08-24-2019, 08:45 AM   #5
1987 34.5' Airstream 345
Menomonee Falls , Wisconsin
Hey,
Your going to put an 8.1 cummins in there? Is there room for that? Is it a 8.1B model or just an 8.1. The b model is a full blow diesel, rebuildable with sleeved cylinders like a big OTR truck engine. I had one of those in my FL70 FedEx truck.very good engine. I got 10-13 mpg , and I weighed empty, I think about 12 K. I'd be interested in your progress. Would you take a ton of pictures. I may go diesal for something like that. They got tons of power. You wouldn't t be slowing down on hills, that's for sure. DJ
davejay is offline   Reply With Quote
Old 08-24-2019, 03:52 PM   #6
cmadmaxman's Avatar
1982 31' Airstream 310
Columbia , Tennessee
Images: 37
I think it's the 8.1 GM big block gasser. Replacing the 454, 7.4.
Chris & Brenda, Members of the Christian Motorcyclists Association
AIR Member 12654
1982 310 MoHo
Many Years ago, 1972 Argosy 24' trailer
Our Toad, 96 Saturn SW2 (266,000 and still going )
cmadmaxman is offline   Reply With Quote
Old 08-24-2019, 03:53 PM   #7
cmadmaxman's Avatar
Images: 37
Hopefully he will be putting the allison 1000 in with it!?
AIR Member 12654
1982 310 MoHo
Old 08-24-2019, 04:14 PM   #8
8.1l + Allison
Yep - putting in an 8.1L vortec gas engine plus the Allison 1000. Uses the same motor mounts as the 454 but looks like itll still be a tight fit
Old 08-24-2019, 05:28 PM   #9
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Originally Posted by davejay View Post
Hey,
Yeah, don't think so... You'd seriously have to rethink the doghouse, front suspension and your sanity.
Cheers
Sidekick Tony
Its a recession when your neighbor loses his job; its a depression when you lose your own. "Harry S Truman"
Old 08-24-2019, 09:30 PM   #10
cmadmaxman's Avatar
Images: 37
They say the exhaust manifolds are the same bolt pattern between the two? Just curious.
AIR Member 12654
1982 310 MoHo
Old 08-24-2019, 10:32 PM   #11
Paradise , Texas
The vortec 8100 is externally identical to the 454. The Allison is a monster compared to the th400.
Overall, a much better setup than a metered fuelmleak and no overdrive!
Crackerman is offline   Reply With Quote
Old 08-25-2019, 01:49 AM   #12
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
Did you manage to hunt down a 6-speed Allison or going with a 5-speed?
martin300662 is online now   Reply With Quote
Old 08-25-2019, 08:17 AM   #13
bibbs's Avatar
1977 Argosy Minuet 6.0 Metre
1973 21' Globetrotter
1975 26' Argosy 26
Vista , California
I am watching this, I am interested in the control electronics part of the job. What are you using?
bibbs is offline   Reply With Quote
Old 08-26-2019, 09:34 AM   #14
I started with a complete donor assembly (8.1L + Allison + accel pedal + all harnesses, computers, sensors, etc) so everything already worked together. From there I added a new Howell harness and had the ECM reprogramed for the new application.
Default 8.1 vortec and Allison Swap into 1984 Airstream 310 Moodified13 Classic Motorhomes 59 10-08-2018 11:56 AM
1988 Airstream 290 LE MarshallSF Classic Motorhomes 19 06-24-2014 06:03 PM
Shakedown Cruise - 1100 Miles in a 1988 290 LE MarshallSF Classic Motorhomes 2 03-07-2014 12:26 AM
Picking up my new 1988 Airstream 290 in a week MarshallSF Classic Motorhomes 10 03-07-2014 12:16 AM
1988 Airstream 290 Class A Motorhome - Incredibly nice condition! eBay Watch Airstreams on eBay 0 10-22-2013 07:40 PM
