Old 08-06-2009, 11:21 AM   #57
1989 34.5' Airstream 345
Silverton , Colorado
Brakes, hitch, air suspension, step retraction, fridge, AC operation off the grid...oh, yeah, will it start
Michael & Tracy
1989 345 Motorhome
CHARTER MEMBERS: FOUR CORNERS UNIT, AND PROUD OF IT!!!
We live for the moment, 'cause when you get there, it's gone...
ScrapIrony-2 is offline   Reply With Quote
Old 08-06-2009, 11:33 AM   #58
sharptalk's Avatar
scottsdale , Arizona
sharptalk is offline   Reply With Quote
Old 08-06-2009, 10:50 PM   #59
Brakes squeaking is not a good thing...I guess that noise is better than fire, but so is stopping without noise...MAKE THEM TAKE THE TIRES OFF...our 'jangly' noise was diagnosed as a loose u-joint, till the guy in Tucson found the tag-axle brake rolling around in the wheel well...1200 miles later...MAKE THEM TAKE THE TIRES OFF...
ahem...m
Michael & Tracy
1989 345 Motorhome
Old 08-07-2009, 10:45 AM   #60
sharptalk's Avatar
ahem...m
OK, OK, I had them replace all 8 tires, so they all came off.
Karen
Old 08-07-2009, 06:17 PM   #61
sharptalk's Avatar
Update today from the mechanic-
A/C is working-someone who owned this before me had too many wires and fried the cable. Installed new cable.
Generator was serviced.
Stairs are now working.
Rear brakes replaced, rotors and calipers too.
8 new tires.
Bettered the screen door latch to stay hooked.
New 50amp outlet installed at the house!
As far as the low coolant light, he said someone had replaced the airstream tank with a secondary replacement tank with no sensor. Any thought on this? It's really annoying having that light on.
Still checking on belts and hoses and the electrical to the lighters and CB.
Left to do-
Need passenger rear hydraulic leveler repaired
Hitch and tow system
Reattach one set of blinds and make sure all are tight.
Awning
Drapes ordered from airstream
New water filter for system
New sliding window seals
Nutone Blender repair and new blender needed, find the central vac system
Clean that sucker inside and out!
Karen
Old 08-07-2009, 08:33 PM   #62
SOUNDS GREAT!!! Can't wait to see this beauty!
Michael & Tracy
1989 345 Motorhome
Old 08-07-2009, 09:09 PM   #63
sharptalk's Avatar
Just got off the phone with Brad. When are you coming through Phoenix?
Old 08-08-2009, 05:24 AM   #64
raveson's Avatar
boca raton , Florida
low level light
Find the two leads (hopefully) near the tank. Once you have, either connect them to make the light go off or drill two holes in the tank at the need collant level and put through bolts with rubber washers so they don't leak and attach one lead to each. The level of the liquid will complete the circut and the the light will go off.
raveson is offline   Reply With Quote
Old 08-09-2009, 01:42 PM   #65
sharptalk's Avatar
Can anyone with an 1987 345 tell me what kind of gas mileage you are getting?
Old 08-09-2009, 02:08 PM   #66
Liberator
klattu's Avatar
1972 Argosy 24
Heart of Dixie , Alabama
Images: 834
Dolly Parton
9 to 5
Your opinion is valued, please not your opinion of someones else's opinion.
Click To See Me Wet
1989 Airstream 345 Liberator...
1972 Argosy 24'...
1954 Feathercraft Vagabond
klattu is offline   Reply With Quote
Old 08-09-2009, 02:37 PM   #67
sharptalk's Avatar
Originally Posted by klattu View Post
9 to 5
So the 10-12 that I was told is an unreasonable expectation.
Old 08-09-2009, 04:24 PM   #68
If the 7 to 9 that we get with our 310 is any indication then yes, you were probably lied too .
Old 08-09-2009, 06:24 PM   #69
sharptalk's Avatar
How loaded up are you with that? Are you towing?
Karen
Old 08-09-2009, 07:37 PM   #70
Karen
We pretty much always tow a trailer with Susan's Spitfire on it. I think the total weight of the trailer and car is probably about 3500 lbs. We also load the coach fairly well but we definitely don't over do it.
WoW $230,000 1987 345 RichardT Classic Motorhomes 14 07-21-2010 04:49 AM
Shower door. Has anyone put one on a 1987 345 or similar airstream with curtain? MacInDaBox Airstream Motorhome Forums 2 05-17-2007 12:06 PM
1987 Airstream 345 on Ebay looks good! Jim Jarzabek General Motorhome Topics 10 10-13-2004 10:31 AM
