Old 04-04-2013, 10:14 PM   #1247
1964 24' Tradewind
Howell , Michigan
We are getting an 85 345 next week. Inside we have a dinette where you have closets. Our first motor home. Also 454. It's in good shape for an 84. Good luck. Maybe see you at a Rally.
tommyt is offline   Reply With Quote
Old 04-10-2013, 10:25 PM   #1248
Well, welcome and congrats Tommy!
Thanks to Brad, I found a replacement exterior handle... mine was MIA!
I am pretty sure its the right one...
The lock is a Schlage... but not sure if it is the correct one because the back of the lock cylinder does not have the square peg..
Opinions please?
I blew the whole assembly apart...
The clearcoat was bad... and also I dislike the way it looks and feels... all square/sharp edges.
An hour with a file/sander...
I still have some more fettling to do, but feels better and more tactile...
Old 04-11-2013, 04:33 AM   #1249
Steve, I'm pretty sure that is the correct handle for the Classic motorhome. It's not really a square peg that sticks out of the lock, it's more like a flat piece of steel that is twisted with a round flat plate on the end that goes into the lock. I'll see if I can find a picture of what it looks like.
I'm not sure if that peg is a standard lockset item or if Airstream custom made it. I'll do some research and let you know.
Old 04-11-2013, 06:18 AM   #1250
Oops, my description of the peg was slightly off
It actually is a square peg although the end that connects to the lock cylinder is flattened with a round disc at the end. I tried taking some pictures this morning before heading to work but the camera didn't focus any better than my eyes do this early in the day
ID:	182981Click image for larger version
I'll get some pictures this evening and if I get a chance tomorrow I'll run by the local lock smith and see if he has one available or can provide a source.
I'll let you know...
Almost forgot, do you have the parts that are located inside the wall?
Old 04-11-2013, 02:14 PM   #1251
Thanks Brad,
I found this interesting PDF...
http://professional.schlage.com/pdfs...ntrol_2007.pdf
Old 04-11-2013, 06:49 PM   #1252
1964 24' Tradewind
Howell , Michigan
We are in the process of buying one now. It' has a couple dents but in fair shape on the outside. Inside is in good condition looks all original. Were your dinette is we have a chair and dinette is across from the sink. Also looking to get a tow vehicle. Reading your post helps me a lot. Thanks and good luck with Yours. tommyt
Old 04-11-2013, 07:49 PM   #1253
Thanks Brad,
I didn't see the peg in the PDF file.
Here are some pictures of what you're looking for.
ID:	183017Click image for larger version
ID:	183018Click image for larger version
ID:	183019Click image for larger version
I've got to run into town tomorrow so I'll check with the local locksmith to see if he recognizes it and if he knows where to locate one.
Old 04-12-2013, 08:19 AM   #1254
STstudios
STstudios's Avatar
1986 34.5' Airstream 345
Wixom , Michigan
Hey Steve,
The handle looks right. I will grab some shot on my '86 345 and post them.
Sam
STstudios is offline   Reply With Quote
Old 04-12-2013, 08:24 AM   #1255
Steve,
I dropped by the locksmith this morning and got some interesting information. The piece in question is called a "tail" and Schlage doesn't make one like the ones used on our motorhomes. What appears to have taken place is Airstream bought the Schlage locks with the standard tail piece and then modified the tail piece to suit their application. The locksmith gave me a couple of tail pieces to play with.
ID:	183055Click image for larger version
It's pretty obvious that all Airstream did is cut the tail piece to a suitable length, welded on an extension piece made out of 3/16" key stock (I need to verify that dimension).
So the bottom line is you won't be able to go to a lock smith and buy the tail piece that you need. However it should be easy to fabricate one. The best choice for welding would be TIG but gas welding might get it done as well.
I can generate sketch with accurate dimensions for you if you would like.
Old 04-12-2013, 07:07 PM   #1256
STstudios
STstudios's Avatar
Wixom , Michigan
Handle Pics from '86 345
Here's a few pics from my '86 345. Let me know if you need any other reference pics.
Sam
ID:	183101   Click image for larger version
ID:	183103   Click image for larger version
Old 04-13-2013, 12:24 PM   #1257
Thanks for the info and pics.
I seem to recall that the tailpiece is still available from Airstream, so I will verify that with Inland RV/Andy. If I can order the OEM parts thats gotta be the easy way!
I stopped into Home Depot and looked at locks, but they dont carry the cylinders... I will try to find a local locksmith and find out if its a standard piece.
Old 04-13-2013, 09:25 PM   #1258
Time to scare Ya'll...
I already said that my exterior handle was missing...
Torn off in a mishap somewhere in its past...
Here is what that area looks like..
Tried the handle up to the area...
It was time to brave and see what was underneath...
I drilled out the plate rivets...
Its not pretty, so those who are of a sensitive nature... look away now...
I bent the skin back to see what I have...
Looks like the deadlock solenoid is missing, but the wires are there for it and the doorbell..
Small mercies!
Old 04-13-2013, 09:41 PM   #1259
I think I will put the plate back on for now!
Brad had kindly sent me the correct mounts, so it was time to loose the old ones.
So, now I was in the mood!
And I brought tools, and I was prepared to use them!
Grinder, Sawzall, and chisels.
Going....
Going...
GONE!
Now to clean up the remnants.
End result..
Old 04-13-2013, 09:51 PM   #1260
Started on the drivers side mount...
But had to quit as my Sawzall Battery was toast, and I had used up the 3 cutting wheels I brought...
This was as far as I got.
So moved on the a job I got stuck on previously...
The rear fairing.
I had glued it together before, but could not remove it as the rivets were tricky to dril, si I groud off the heads with a flap wheel.
New Airstream Interstate Owner in SE Louisiana solar-guy Member Introductions 2 12-17-2011 11:49 AM
Hope to be an Airstream owner.......... angellhill Member Introductions 4 08-21-2011 06:27 AM
1984 Airstream 345 Keyair Airstream Registry Discussions 0 08-19-2011 09:32 AM
It's going to FINALLY happen, I'll officially be an Airstream Owner! crazeevw Member Introductions 3 08-19-2011 12:06 AM
Hoping to be a Future Airstream Westfalia Owner 2005-/+ PorcupineRim Member Introductions 1 03-19-2011 11:13 PM
