Old 02-07-2013, 02:04 AM   #1191
crazeevw's Avatar
1989 34.5' Airstream 345
Saint Petersburg , Florida
Steve,
Did you use a hammer drill to get the bumper retaining screws removed?
Old 02-07-2013, 11:55 PM   #1192
Originally Posted by crazeevw View Post
Steve,
Only the front has those recessed cross head screws, and I could not shift them at storage, so I removed the bumper with the brackets.
Old 02-08-2013, 01:15 AM   #1193
mattpalmeris's Avatar
nanaimo , British Columbia
Originally Posted by shepherd57 View Post
If your welding doesn't work out I have bumper that should fit
Any chance you have the bumperettes off the rear bumper?
mattpalmeris is offline   Reply With Quote
Old 02-10-2013, 04:52 PM   #1194
Thanks Brad...
This is the spoolgun I have..
I don't think that gun will fit my welder. I have an older Hobart 200 amp mig welder. I guess I need to get serious and find a spool gun for it!
Lots of work done... but I am realizing that it might never be right... It was a pig to line up because it was tweaked twice...
Trying to work out how to ship a 80" Bumper is a pain... but maybe the best option, thanks John!
Steve,
I should be seeing John sometime in the next 2 to 4 months. It might be cheaper shipping for me to pick it up John and then ship it from Kentucky. I don't know how customs is going to deal with a bunch of motorhome parts crossing the border but it might be worth looking into.
Old 02-10-2013, 09:54 PM   #1195
Yup, John and I have a plan in principal!
Today I removed the headlamp surrounds for refinishing...
Drilled out the multiple
Ready for some elbow grease on the bench!
Old 02-10-2013, 09:59 PM   #1196
Steering wheel replacement!
Old...
Like for like!
I am so STOKED!
Done!
Might get some SS button head screws later...
Old 02-11-2013, 12:38 AM   #1197
Leaks...
Pulling my HVAC cover for WXboy...
Front floor is wet... and rotten...
As is the HVAC cover corner...
Spent a couple of hours raking out sealant at the top of windshield, and then pumped Tempro into the gap...
Lets see if that works!
Oh,,, also a good heads up...
Put a smal screwdriver into the lower edge of the windhield centerbar lockstrip...
Look at this!
Gusher... it was full of water under there!
This was all in there...
Old 02-11-2013, 06:20 AM   #1198
wxbuoy's Avatar
1991 35' Airstream 350
Carriere , Mississippi
Send a message via Skype™ to wxbuoy
Look at this!
Thanks! They seem identical..... So i have no idea what the hold up us.
Dave and Felicia
wxbuoy is offline   Reply With Quote
Old 02-14-2013, 11:21 PM   #1199
Pass side Headlamp casting done...
Old 02-15-2013, 12:08 AM   #1200
crazeevw's Avatar
can't wait to see the before and after pix of your grill Steve!
Old 02-24-2013, 09:30 PM   #1201
Well, after finding a wet carpet on the pass side while investigating WXBouy's issue with the HVAC cover, I resealed the top of the windshield.
I raked out the old hard sealant and used made a wide flat nozzle on the Tempro tube by wrapping it with scotch tape. By working along with a plastic scraper ahead to open the gasket, and following the scraper closely injecting the new sealant. I left it alone to find its own level.
We had a real downpour Tuesday last week, and after inspection, I found the pass side floor to be dry!
Win!
Today, I worked on the front "Hood" door...
I started removing the badge letters...
All but 2 were easy...but check this out...
Really Airstream????
Took me about an hour to get these last 3 badge nuts off!
That done, I set Citrastrip loose on the black paint...
Started to polish...
Lots of road rash and dings...
But after 2 passes, it looks better.
Old 02-26-2013, 09:46 PM   #1202
Front End Letters
Letter refurbishment...
Old 02-26-2013, 09:56 PM   #1203
Then it was that pesky over door light...
It been bugging me...
I finally just went for it...
Grabbed a scrap of aluminum..
Bent it around a socket, sawed it, tin snipped it, and then polished it to make what I had in mind..
A reflector... The 1156 bulb is just for the pics... I have an LED that will save amps...
Then I made a diffuser from a scrap bit of flourecent lamp cover..
Test...
Old 02-27-2013, 12:16 AM   #1204
STstudios
STstudios's Avatar
1986 34.5' Airstream 345
Wixom , Michigan
Wow - great job Steve!
STstudios is offline   Reply With Quote
New Airstream Interstate Owner in SE Louisiana solar-guy Member Introductions 2 12-17-2011 11:49 AM
Hope to be an Airstream owner.......... angellhill Member Introductions 4 08-21-2011 06:27 AM
1984 Airstream 345 Keyair Airstream Registry Discussions 0 08-19-2011 09:32 AM
It's going to FINALLY happen, I'll officially be an Airstream Owner! crazeevw Member Introductions 3 08-19-2011 12:06 AM
Hoping to be a Future Airstream Westfalia Owner 2005-/+ PorcupineRim Member Introductions 1 03-19-2011 11:13 PM
