Old 12-19-2012, 09:08 PM   #1107
Benchwork update...
One Overrider sanded out, with DA down to 120grit.
Then hit it with the bench buffer.
The larger bumper extrusion was also sanded out with the DA and a couple of dings appeared...
A little "massaging" with the hammer and they are history..
Old 12-20-2012, 12:42 PM   #1108
Can someone confirm what rooftop AC units I have?
The ID tag on the units say.... 6755 iI think..
So that is 6700 series 15000 units?
Old 12-20-2012, 02:59 PM   #1109
I would almost bet they are 13,500 units.
Old 12-20-2012, 09:56 PM   #1110
crazeevw's Avatar
1989 34.5' Airstream 345
Saint Petersburg , Florida
Steve,
My guess is 13500 units as well. For some reason, I have 13500 units with heat strips. From what I've read about the heat pumps now available, my replacements will have heat strips as well. Keep reading about the new even 'lower' profile units that Lewster has written about. Sure hope some extra $ makes an appearance soon, lol
Thanks for the updates on your Airstream, Derek
Old 12-21-2012, 11:48 PM   #1111
I put in a call to Coleman today..
Seems it should be a 13500 unit.
I got the part number for the inner shroud from them..
They say 6769-5051 and I can order it from Camping World.. lets see!
Old 12-27-2012, 06:05 PM   #1112
Steve, ran into an interesting problem today while mounting the Velvac mirrors on the 310. What I found is the aluminum mounting plate (under the skin) that the mirror bases bolt too is only 4" wide. Our 310 is an 1984 same as yours so I'm betting your mounting plate is also only 4" wide as well. The real problem is the Velvac 2020 & 2025 style mirror base that you are using has mounting holes that are 4-3/16" center to center on the bottom and 3-5/8" center to center at the top. That means that the bottom holes will not screw into any of the mounting plate. The original mirror base is centered on the 4" plate.
I am using Velvac Revolution mirrors on the 310 and they mount differently, see attached picture.
The overall external base of the Revolution mirrors is larger than the 2020s however they have a separate mounting plate that hides underneath the external base. They are a wedge fit and tightened down with one screw at the bottom.
The hole I drilled in the top left corner just outside the outline of the original mirror base did not hit any substantial metal. It just skimmed the edge of the mounting plate under the skin.
Also shown in the picture above is the aluminum adapter plate that I fabricated to provide the needed tilt for the mirror to correct the tilt. I used 3/4" thick aluminum plate and used a 1/2" tilt like you ended up doing. With the 3/4" plate that allowed for a 1/4" edge at the bottom. If I had to do it over again I would use 1" or 1-1/4" thick aluminum plate and then mount the adapter plate using the original Airstream mounting holes. I would then drill and tap the adapter plate such that the new mirror base mounted directly to the adapter plate. (hope that made sense!)
Tomorrow I'll post pictures of the mounted mirrors. I still have to mount the drivers side as it got too dark by the time I was done with the passenger side.
Old 12-27-2012, 06:38 PM   #1113
Great info Brad!
I actually had found a thread with a reference to the elusive OEM mirror mounting plate, and remembered a comment about it being only just wide enough to accomodate the original.
This is why I elected to use the original mirror mounting holes, and fabricate my "puck" to suit.
Looking fwd to see how yours looks!
Old 12-28-2012, 09:39 AM   #1114
Finished up mounting the drivers side mirror this morning. I think I will need to slightly adjust both of the tapered mirror mounts. I'm not able to draw the mirror assembly down as far as I would like to get properly. It's more of a cosmetic issue than anything else but I'd like to get it right.
Here is what was under the original drivers side mirror mount. Not pretty
The hole on the bottom right was actually a rivet put in place to plug a miss drilled hole on the original mount. One thing to note is the left side skin & mirror were replaced when the previous owner side swiped a tree. So the lousy job of mounting the original mirror was done by some shop in Southern California.
And the new mount in place ready to set the mirror.
And with the mirrors in place.
ID:	175351Click image for larger version
ID:	175352Click image for larger version
Old 12-28-2012, 10:26 AM   #1115
wxbuoy's Avatar
1991 35' Airstream 350
Carriere , Mississippi
Send a message via Skype™ to wxbuoy
Now I have mirror envy!
Dave and Felicia
wxbuoy is offline   Reply With Quote
Old 12-28-2012, 12:34 PM   #1116
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
I have to say I get a kick out of you guys with the "mega mirrors." I don't mean that in any derogatory way, I don't want to offend, it's just that several months ago a gentleman pulling his Airstream trailer in Florida got a ticket for not having mirrors extended far enough to see behind his trailer. There was quite a discussion with many posts as to whether there is a necessity of knowing what is happening behind you. It would be interesting to somehow combine the two threads to see the efforts you guys are going through for big mirrors next to the arguments the other guys posted for not needing mirrors.
I guess maybe I'm just in a funny mood this morning.
Cheers, Dan
~ Margaret Thatcher ~
Old 12-28-2012, 12:51 PM   #1117
LOL, thanks for the input Dan, it is always welcome!
Maybe we do need a Mirror Thread to collate all this info of mirror upgrades!
I wish there was an easier way to see around without those big appendages sticking out... I am still thinking about painting the a bright metallic silver to lessen the visual impact of the black housings!
For me, there is no way I could drive without them now... the difference in view from the old mirrors is amazing.
Personally, I have no doubt that being able to see down the side of the MH is key in everyday driving. The combo of rearview camera, rearview interior mirror(yes, I have one and it has a reasonable view), and the improved sideview mirrors allow me to pull out, or merge with confidence.
Old 12-28-2012, 02:29 PM   #1118
Never heard of that happening before. The main reason for the "mega mirrors" is because I found a really good deal price wise on ebay for the 18" Velvac's and figured bigger is better, right?! If I had to do it over again I would buy their 14" tall mirrors instead of the 18" tall ones. I'll post pictures, probably tomorrow, showing the partially blocked view of the passenger mirror. If I would have known that would happen at the time I bought the mirrors I would have opted for shorter ones.
I'm one of those who really likes to know what traffic is doing all around me. I hate being surprised by some idiot because I couldn't see them for some reason.
Are you sure it's not "mega mirror envy" like wxbouy
Old 12-28-2012, 02:33 PM   #1119
...Maybe we do need a Mirror Thread to collate all this info of mirror upgrades!
That's not a bad idea. Mirrors are something that everyone that owns one of these rigs is going to have to deal at some point in time if for no other reason that a broken mirror.
I now know of three different internal frame arrangements for mounting mirrors on the Argosy/310/345 motorhomes. I never would have guessed that would be the case.
Old 12-28-2012, 02:53 PM   #1120
Go for it Brad!
Couple of updates....
Hre is a quick shot of that passenger side engine closeoff panel for you Brad...
I confirm it is flat, with no visible flanges... just screwed on... well mostly on ours...
Rear...
Front..
I also think I found the cause of my elusive kerbside closet leak...
As always, our MH has had some intereting repairs...
This is a pic I took sitting on the roof, looking back at the rear awning mounting foot...
Note the holes in the sealant on the foot and on the rivited flange, a long crack in the sealer...
This is right above the bedroom closet and floorsafe..
Also managed to decifer my Coleman Rooftop AC...
They are 6759A707 units and whilst I have not confirmed it, I believe you guys called it says they are 13,500's.
At least with this info I am a step ahead!
Need to get back to the Genset issue soon... I want to diagnose this Open Neutral issue, and want to see if the onboard genset does it too.
I took this shot of the Kohler 7CM21RV ID plate..
Looks like the Spec plate says 1403-A...
New Airstream Interstate Owner in SE Louisiana solar-guy Member Introductions 2 12-17-2011 11:49 AM
Hope to be an Airstream owner.......... angellhill Member Introductions 4 08-21-2011 06:27 AM
1984 Airstream 345 Keyair Airstream Registry Discussions 0 08-19-2011 09:32 AM
It's going to FINALLY happen, I'll officially be an Airstream Owner! crazeevw Member Introductions 3 08-19-2011 12:06 AM
Hoping to be a Future Airstream Westfalia Owner 2005-/+ PorcupineRim Member Introductions 1 03-19-2011 11:13 PM
