Old 12-05-2012, 06:11 PM   #1079
Well, I passed my Exam...
Just need to find a job now!
Little bench project...
Docking lights, and nacelle..
The light output and spread was next to useless...
This was an earlier attempt with a LED bulb..
On the front..
Notice that the front one is held with 6 screws... and the rear only with 4...
I assume its because the front is inside the wheelarch and maybe subject to more air pressure?
I took some measurements to start with..
Then, I removed the whole thing..
I need to polish where it is mounted anyway...
The lamp cans were rusted... and the lenses were melted..
Nobody has these anymore it seems...
Plan B is evolving..
The Nacelles are our favorite ABS... brittle, cracked and ugly..
Backside.
Cracks
Old 12-05-2012, 06:32 PM   #1080
So, here is the plan...
Fix up the front one if possible, and take a mould off it.
If its too ugly I will make a pattern and take a mould off that.
Make 2 new ones from Fiberglass for the the curbside, and then make 2 to put the same lights on the streetside... The streetside positions will be the same, and will illuminate the holding tank drain area and the front will cover the Propane tank and genset area!
Also Derek has his name on 2 as well!
The new parts will have smaller lamp holes to fit the New and improved Plan B lamps..
Waterproof, solid aluminum housed projecter lens 10W LED floods from Ebay...
They cast an amazing wide flat circular pool of light that will illuminste the ground pretty well I hope!
The units come apart and look like this inside..
This is kinda how they will look when in place.
The stock bracket will be removed.
I am planning to cut the hole smaller in the new nacelles, and use the lens locking ring to sandwich the mounting...
Old 12-05-2012, 09:54 PM   #1081
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 55
Congrats on the exam pass.
Would something like this work? Use a polished aluminium patch for backing.
Innovative Lighting Docking Hull Back Up Lights Chrome Model 580 0200 7 | eBay
Dave
Old 12-05-2012, 10:10 PM   #1082
Those look REALLY sweet Dave!
The price is sweet too...
We got our little floodlamps for $12 each... inc shipping.
Old 12-05-2012, 10:31 PM   #1083
masseyfarm's Avatar
Images: 55
Yes, but you are going to spend a lot of camping time trying to reproduce that recessed mount. You could use these while you are working on the original mount without changing anything on the body. Then there would be no rush to get the mold etc. done and you could continue to go camping.
Dave
Old 12-06-2012, 12:32 AM   #1084
Dave... I wish!
We are a long way from camping yet...
Its been a crummy year. No job, so no money, so no smog, so no moving the beast.
Now my study is done, my exam is passed..
I am one step closer to earning a living!
There are 2 major jobs ahead of the big push on the MH.
Interior retrim on one car, and a transmission R&R on the Suburban.
Just trying to always have something done every week.
We had a lot of rain this last week, and I was over to check today...
Everything was dry, aside from the battery tray, which had about 1/2" of water in the bottom, as I had not latched it correctly, leaving a gap..
And yes, I had not drilled a drain hole... I have now!
I wanted to get up on the roof, but it was wet... I decided it can wait!
Old 12-06-2012, 04:16 PM   #1085
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Dave
I found these as well. They are for a boat but should do the trick for those of us that don't have them.
LED Side Mount Docking Lights by Seadog Sale | eBay
Old 12-07-2012, 09:11 AM   #1086
You will still have plenty of work to do with those lights... the area they mount to is curved.. my best guess would be an 18" radius, but I will check. The lamp backs look flat to me.
Old 12-08-2012, 10:36 PM   #1087
STstudios
STstudios's Avatar
1986 34.5' Airstream 345
Wixom , Michigan
Love going through all your posts Steve. Thanks for all the tips and suggestions. Hopefully, I'll be able to contribute like you have!
Sam
STstudios is offline   Reply With Quote
Old 12-08-2012, 10:45 PM   #1088
masseyfarm's Avatar
Images: 55
These lens should be the same lens and are available on ebay.
Lens Replacement 4" Round Clear Plastic 3 Screws for Kenworth Freightliner Pete | eBay
The pots should also be still available from the truck dealers.
Dave
[QUOTE=Keyair;1234796]Docking lights, and nacelle..
Old 12-09-2012, 06:11 PM   #1089
Glad my ramblings have been of use to someone STstudios!
Thanks for that Dave... They maybe the right ones... I just know that the Porch or scare lamp is different...
It does not change the fact that they are next to usesless and consume too much power!
Old 12-10-2012, 12:33 AM   #1090
Astrodokk's Avatar
1992 30' Airstream 30
Santa Rosa , Northern California wine country
Way to go passing your exam Steve!
Could you tell me how you removed the interior light covers? I tried one of mine and it was so tight I thought it was attached differently than just snap in and I might break it so I stopped. I've broken a similar one at home under the kitchen cabinets so it scared me. What's the secret...just elbow grease, a firm squeeze, and courage?
1992 Airstream 300LE, rear queen, Banks Power!
Astrodokk is offline   Reply With Quote
Old 12-10-2012, 08:18 PM   #1091
Thanks!
The trick to removing the light lenses is heat...
Put the lights on for a bit, to heat and soften them..
They are still pretty tight tho!
Old 12-10-2012, 08:22 PM   #1092
Wanna try to start piecing the rear fairing back together...
Broken bumper will be welded and smoothed while its off...
And off it came today..
Anyone know what the dangly/stringy stuff under the rear end is called????
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
New Airstream Interstate Owner in SE Louisiana solar-guy Member Introductions 2 12-17-2011 11:49 AM
Hope to be an Airstream owner.......... angellhill Member Introductions 4 08-21-2011 06:27 AM
1984 Airstream 345 Keyair Airstream Registry Discussions 0 08-19-2011 09:32 AM
It's going to FINALLY happen, I'll officially be an Airstream Owner! crazeevw Member Introductions 3 08-19-2011 12:06 AM
Hoping to be a Future Airstream Westfalia Owner 2005-/+ PorcupineRim Member Introductions 1 03-19-2011 11:13 PM
