Old 10-31-2012, 07:50 PM   #1023
Thanks for that Derek!
Wow, the pass side looks way further fwd than I would have expected...
When you get a min, take a shot of your view from the drivers seat please?
And I thought I had my plate full Brad!
I guess those revolution mirrors cure the bodyside curve issue!
Old 10-31-2012, 08:18 PM   #1024
Which is why I'm going to lobby to use them on the Argosy
bkahler is online now   Reply With Quote
Old 11-01-2012, 11:02 PM   #1025
What a crappy day...
If you had a crappy day too... leave now!
Edison had advised us of a scheduled local power outage to upgrade some hardware..
Power was out at 10am.
By 2pm I was pulling my hair out, I had studied until my brain hurt...
I thought... I need some AS time...
I took the genset Facet fuel pump I had stripped, cleaned and bench tested back and refitted it.
It failed in situ.. no fuel flow.. so no onboard genset..
Whats the?
I pulled out my backup 3500w portable genset... which thwarted my attemps to start, and it turned out to be a blocked jet... stripped the carb to clean... installed a fuel filter now!
Its gonna go good now.. right?
Not.
I attempted to finish polishing the bodyside above the bathroom with my home made polish...
It was looking real good...
Then POP... the compounding buffer quit....
Will look at the bushes, or return it to HF for a replacement.
Ok, onto the next item..
I have decided to remove the mid body mouldings, so I started drilling out the rivets...
I swear I was being careful, and bang... the drill bit snapped off, the drill slipped and punched a hole in the skin...
I was mortified, but what is done is done...
Undaunted, and being a glutton for punishment...
Up on the roof I went to try to make some progress on the TV antenna replacement...
This is what I have... antenna is gone, just an ugly mastic bedded plate..
All the screws were out, but it would not come off!
After about an hour of gentle easing, it was off..
Here is what I got for the replacement..
I part assembled it and put it up on the roof for a trial fit.
Lining up the original antenna's crank hole made me realize there is a problem...
The new antenna encrouches on the forward vent..
Now what!
Old 11-02-2012, 06:05 AM   #1026
Gunter
gunner's Avatar
2000 35' Land Yacht XL w/2 slides
Greenville , Ohio
To solve this problem on mine; I increased the height of the standoff that the antenna rests on when it is in the down position. I riveted the extension onto the existing one, it allows the vent to be opened when the antenna is in the down position.
Gunter
2000 Land Yacht XL 355
gunner is offline   Reply With Quote
Old 11-02-2012, 06:24 AM   #1027
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
Now what!
Have some Bluebell Icecream !!
There is this commercial...old farmer gets kicked by the horse, tractor runs over him and the barn burns down. All singed and beaten up he sits at the dinner table enjoying blue bell icecream, when his wife asked "How was your day?" "Turned out good, turned out good" he replies...
The hole you drilled was supposed to have an olympic rivet anyways. they just forgot to put it there.
This my thought and experience with the 70/80 generators: Boat anchors, at least that is what an Onan rep told me, when I tried to get some NLA parts. It seems and I have proven it myself many times, they always quit when you need them most.
That is the reason why a new generator has always been on the top of my list when i restore one of these puppies. I know and hear you, its a lot of money, but if you live in the south, its part of doing business, the dash A/C doesn't cut it.
Just my thoughts and I hope you have a great day !
1990 29' Excella Trailer
1996 Airstream B190
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 11-02-2012, 01:48 PM   #1028
Gunner...
Thanks for that!
I was looking at that little M shaped receiver/standoff, and wondered if I could use it!
Did you have the same original setup and use the same/similar replacement?
I am worried about the coax... They come up rearward of the antenna hole, and it looks like the new one was designed to be forward. I dont want to start pulling the inner skins to rework that!
I also have a pair of small 12v cables emerging up top.. What were they for?
Thanks for the support Peter... I am ok today... just seemed like I was getting the rough end of the pineapple yesterday!
On a good note...
I fixed the fantastic fan lift mechanism!
Based on info I got in the vent section, here is the fix...
I removed the inner raise handle, and then the 4 screws holding the trim panel, and let it hang down.
Instantly, I could see the roll pin was pushed off to the side...
I removed the assembly..
Lift mechanism with pin out of place!
It seemed a little loose, so I tweeked the roll pin open a little with a flat screwdriver, to make it a tighter fit.
Put it in position on the arm and pinched the pin back thru with pliers.
And put it back in position.
Fixed!
just missing a couple of screws...
Feeling good that now I can lock it down!
Old 11-02-2012, 02:05 PM   #1029
Also found replacement lenses for my melted interior lights...
Look for "Progressive Dynamics Dome light"
They were $3.95 per pair off Ebay.
Slightly different, but its good..
Old 11-07-2012, 09:39 PM   #1030
We have rain coming in, so grabbing time to get some of these things pushed forward.
Antenna time..
Opened up the roof hole to allow the base to seat down..
Need some feedback on my options here...
Mount it straight on and make a stand off to keep it off the vent, as you suggested Gunner..
Or twist it slightly off to curbside like this...
Also would like some opinions on how to connect the coax that emerges from the roof at the rear, to the antenna connection at the front?
I test mounted it and checked the raise function...
Old 11-07-2012, 09:53 PM   #1031
As I said i would, began removing the bodyside trims... upper first.
Cannot believe how much junk there was trapped behind it!!
Cleaned off the dirt, and removed the sealant, and began to polish...
Finished the upper bodyside over the bathroom and gave the whole area a go over.
Then started on the front roof.
Old 11-07-2012, 10:47 PM   #1032
streamquest's Avatar
1936 20' Clipper
1947 22' Liner
Curtis Wright
1989 37' Airstream 370
marshfield , Massachusetts
Key,
Great decision. Other than having to accept the misalignment of the rivets that you'll have to install to fill the off centered holes left behind by the removal of the moulding fasteners, you'll never regret getting rid of that trim. Polishing is easier, and in my opinion the whole coach just looks so much cleaner without it. Sometimes I wonder why it was ever installed in the first place, but I figure it was a decision made by the same design team that applied the faux wood stripe.
I can understand faux wood in the context of the early 60's on station wagons, but I can't imagine what anyone was thinking in the 80's when they were applying it to an aircraft inspired motorhome?? I'm pretty sure the Astronauts weren't using it on their Airstream.
Charly
streamquest is offline   Reply With Quote
Old 11-08-2012, 06:22 AM   #1033
Airstream Driver
1997 30' Excella
Images: 51
Steve,
As always I admire your incredible energy and drive to perfection, but I feel like without the trim, you are loosing some of the classic features that make these coaches so unique. Plus you are adding countless rivet holes to a very uneven line of buck rivets. A polished trim with a new insert would imho look awesome, but I like to preserve the original look as much as I can.
1996 Airstream B190
AIR #13
Old 11-08-2012, 07:27 AM   #1034
Always appreciate the input guys!
Actually, aside from my mishap, the rivets look pretty straight.
The are a few reasons I am choosing this course of action.
If you look at what I started with, the finish was already toast, and the paint was horrible. my attempts to remove this paint from the trim and get it looking even half decent was time consuming, with variable results. I also have severeral pieces damaged on the curbside.
I realized long ago that originallity was not an option, and I also disliked the faux wood..
This 345 is odd, in the fact it has no dinette and as a result no windows across from the galley. This further adds to its visual length. I want is to look strong and tall, and any horizontal lines or features draw your eye along, giving the impression of lowering it and lengthening it. I also think it will look cleaner and as you state, Charly, the repolish will be simpler.
You would not believe what was trapped behind that trim... it was a thick poultice of black gunk. Horrible... I wondered why everytime it rains(like right now!) I had black lines below the trim.
The lowest trim, the wide one at the rocker line is staying.
As for my energy Peter... I have my days!
I just try to do my best on everything I touch. Its been a rough week and not felt well with some visual disturbances from my eye issue, so it was nice to have a few hours to get some things done.
This rain was forecast, and I know there is more coming.
Gotta get that front roof cleaned up so I can get the lights back on and all the joints sealed before winter.
Old 11-08-2012, 10:35 PM   #1035
240ClassicMH's Avatar
Pitt Meadows , British Columbia
Many thanks for posting all of the great pictures on removing trim - I've been toying with taking this same project on over the winter and now that I have decided to go polished I think I'm leaning towards removing the trim also. My 24' looks so similar to a classic trailer from the rear going down the road that I think removing the trim will bring it that much closer to the trailer look. My exterior is pretty clean and with minimal blemishes I think it could turn out great.
Looking forward to more photos.
1983 Airstream 240 Classic Motorhome
Pitt Meadows, BC Canada
240ClassicMH is offline   Reply With Quote
Old 11-08-2012, 11:39 PM   #1036
Thanks 240!
Hey, if you have not seen it, look at my thread in the polishing section... and check out MaryContrary's post and RIPPED 310 gallery upload pictures sans trim...
http://www.airforums.com/forums/f441...ome-81748.html
New Airstream Interstate Owner in SE Louisiana solar-guy Member Introductions 2 12-17-2011 11:49 AM
Hope to be an Airstream owner.......... angellhill Member Introductions 4 08-21-2011 06:27 AM
1984 Airstream 345 Keyair Airstream Registry Discussions 0 08-19-2011 09:32 AM
It's going to FINALLY happen, I'll officially be an Airstream Owner! crazeevw Member Introductions 3 08-19-2011 12:06 AM
Hoping to be a Future Airstream Westfalia Owner 2005-/+ PorcupineRim Member Introductions 1 03-19-2011 11:13 PM
