Old 10-15-2012, 01:28 PM   #981
I will get you what you need!
I am planning to do my pass side this week, so hopefully, I can get you some solid dimensions before you get back!
I might even remake the drivers side....
I got some 16g steel that will be better, and now I look at it, that overlap onto the window is bugging me!
Old 10-15-2012, 09:36 PM   #982
That would be great!
I'm also considering using delrin instead of aluminum. I found a GM motorhome site Velvac mirror install where he used delrin and I'm thinking this might be a good alternative.
The one thing I didn't like about his install was where he used nuts on the outside. I'm assuming he did it so he wouldn't need to tap the delrin. Now that I think about it I may just stick with aluminum so I can drill and tap and use bolts from the outside.
Old 10-16-2012, 10:51 AM   #983
Huge HUGE day for me today!
So today it was ON, big time!
I broke out the BIG Guns...
My PowerProbe 3 and the Powerprobe ECT2000 Short Finder!
After reading about Fred's problems with the wiring in his Argosy MH, the fact that there is no service manual available from Airstream for my 74 Argosy MH and reading about Steve using the PP3 and ECT2000 to troubleshoot his horn problem convinced me to buy the master kit with the Power Probe 3 and the ECT2000.
The horns haven't worked on our 310 since we got it and there are so many wiring issues with the Argosy that I'm not even sure where to start convinced me that rather than chasing my tail it would be nice to have the right tool for the job.
Thanks!
Old 10-16-2012, 11:28 AM   #984
Great news indeed Brad!
The PP3 is a great tool on its own... being able to supply power or ground to a componant at the flick of a thumb is awesome... The 30' cable is a bonus...
The ECT2000 has paid for itself at least 3 times already, aside from my pierced wire on the M/H, I chased a dead short on my Mercedes... Could not figure it out... and it turned out to be a random failure of a circuit board in the power antenna....
I admit that electrical is my weak spot, and having the tools that hold your hand is critical for me!
Check out the bulb connectors in the kit... allowing you to plug the ect into a bulb socket and trace the wire back to front!
Old 10-16-2012, 12:08 PM   #985
I have a pretty good electrical back ground so I know how difficult tracing problems can be.
My goal is to create a good map of the wiring in the Argosy for ease of troubleshooting down the road. I can't even begin to imagine how much potential rodent damage I might have considering this thing has sat for years. I've uncovered a bunch of mouse nests inside so I know the potential exists.
I'm also hoping to map the 120vac wiring. As long as I don't have anything plugged into the outlets and no shore power (wait, I don't even have a shore power cord so no worries there!) I should be able to trace their routing.
Gee, more work to do
Old 10-16-2012, 12:41 PM   #986
Aluminated
1987 29' Airstream 290
El Cajon , California
Images: 14
I swear. I'll never complain about my rig again! You certainly have your work cut out for you. Just keep saying over and over again....1 wire at a time.....1 wire at a time!
ericjan2 is offline   Reply With Quote
Old 10-16-2012, 12:50 PM   #987
Wow, I own a poster child for neglected Argosy's!
My Argosy has lots of potential but it's going to take a huge amount of work to get it done. If this was just an SOB motorhome from 1974 it wouldn't be worth touching but being an Airstream, well ok an Argosy, it is definitely worth saving.
One of these days I'll start a thread showing progress, but not until there is some actual progress
Old 10-16-2012, 02:05 PM   #988
Starting with some info for you Brad!
My template here at the house says:
Distance between front and rear centers of two top holes: 58mm
Distance between front and rear centers of two bottom holes: 52mm
Distance between centers of top and bottom holes: 63mm
Distance from top two holes to bottom edge of window frame: 60mm
Distance from bottom holes to upper belt extrusion: 52mm
FYI... I had time to jump in and EDIT this...
LOL, this is passenger side....
MM are a silly European thing I know, but I still get confused with fractions...
Old 10-16-2012, 02:15 PM   #989
1982 28' Airstream 280
Redwood City , California
Distance between centers of two top holes: 58mm
Distance between centers of two bottom holes: 52mm
Steve, what is "mm" ?
"We are free to go where we wish and to be what we are"
Richard Bach, Jonathan Livingston Seagall
dadstoy is offline   Reply With Quote
Old 10-16-2012, 02:19 PM   #990
Steve just forgot the & between the mm...
Old 10-16-2012, 02:20 PM   #991
Steve, thanks for the numbers. Now I just need to figure out how to convert mm to in
That should give me something to do tonight since there isn't any football to watch.
Old 10-16-2012, 02:26 PM   #992
LOL, I had time to jump in and edit...
Convert the MM into metric inches....
Football?
You mean REAL Football, played 99% of the time with the feet... or that weird game you guys CALL football, that is played 99% of the time with the hands?
If it is the later... you will have time during the breaks... so the "Atheletes" have time for a rest...
Now if you are gonna play with the hands, and play with a funny shaped ball... try Rugby...
ROFL...
Old 10-16-2012, 03:56 PM   #993
Football?
ROFL...
Yeah, REAL Football where the players all make millions of dollars a year and have huge egos Now THAT'S Football
Old 10-16-2012, 04:01 PM   #994
LOL... yeah even when they are married to a Spice Girl....
New Airstream Interstate Owner in SE Louisiana solar-guy Member Introductions 2 12-17-2011 11:49 AM
Hope to be an Airstream owner.......... angellhill Member Introductions 4 08-21-2011 06:27 AM
1984 Airstream 345 Keyair Airstream Registry Discussions 0 08-19-2011 09:32 AM
It's going to FINALLY happen, I'll officially be an Airstream Owner! crazeevw Member Introductions 3 08-19-2011 12:06 AM
Hoping to be a Future Airstream Westfalia Owner 2005-/+ PorcupineRim Member Introductions 1 03-19-2011 11:13 PM
