Old 06-24-2012, 11:17 AM   #925
crazeevw's Avatar
1989 34.5' Airstream 345
Saint Petersburg , Florida
Step area
Steve,
Mine is same as yours. Plastic step area stops at entry door frame. Seems like a huge design flaw. Wondering if something like what's used on car door frames would stop the water from seeping below plastic step, causing rust.
Too much fricking rain here for me to go back out for anything! We've had over 3 inches so far today! I'm done, time to 'veg' in front of tv till 'Debbie' is over!
Thanks, Derek
Old 06-25-2012, 09:53 PM   #926
Ok, Thanks Derek.
Need to figure out how to make it better....
Can someone ID the name of this A&E Awning Leg Lock?
Mine is broken... the casting has a piece missing and as a result the pivot will not release the pin and the leg will not release to telescope...
Pic... you can see the casting is broken..
Need to get a replacement but no idea if its available..
Old 06-25-2012, 09:59 PM   #927
Ok, Ok...
Its called a lift handle...
Maybe this one is the right one?
A&E Awning Lift Handle 830644 | eBay
Old 06-26-2012, 06:20 PM   #928
Got 2 coats of paint on the Vent top, and the other one is ready.
Old 07-03-2012, 07:03 PM   #929
How to get on the Roof...
Oh, also its SHINY!
Old 07-03-2012, 07:10 PM   #930
Also put the Vents back on....
After replacing the seals...
Old 07-16-2012, 09:03 PM   #931
Its that time of year again..
Girlfriend INSISTED that I accompany her on her Business trip to Hawaii again this year..
Big Island..
Hope to never have to see this on the road in the Airstream...
And...
An Addition for the motorhome dash..
Old 07-17-2012, 11:09 AM   #932
SteSpot's Avatar
1982 24' Airstream 240
Ventura , California
Looks cool
Or maybe hot....have fun and be safe, paula
Paula & Ed
WBCCI # 8252 Air#13593
1982 24'Motorhome (82Ste P)
SteSpot is offline   Reply With Quote
Old 07-18-2012, 11:02 AM   #933
We are back Paula!
Did a little bench work that night...
Drivers side wheel-well shield needed some TLC before I replace it...
2 broken off mounting bolts were drilled and Ez-outed...
Stripped, degreased, sanded, derusted...
Primed..
Old 07-24-2012, 08:21 AM   #934
Drivers side inner fender/engine shield ready to go back on...
Old 07-25-2012, 04:47 PM   #935
crazeevw's Avatar
Steve,
Is this the cover for the Brake Master Cylinder/Hydroboost?
Thanks, Derek
Old 07-25-2012, 05:33 PM   #936
Yes, it is...
I had 2 broken off bolts and one of the welded on nuts was loose. All fixed now.
Old 07-27-2012, 07:46 PM   #937
Badge Time...
The letters and badges are back on...
Old 07-27-2012, 09:36 PM   #938
streamquest's Avatar
1936 20' Clipper
1947 22' Liner
Curtis Wright
1989 37' Airstream 370
marshfield , Massachusetts
Steve,
Looks terrific!! You have done wonders with that coach, and the "polishers" among us can appreciate the effort that went into it. Congratulations on a great job!
Charly
streamquest is offline   Reply With Quote
New Airstream Interstate Owner in SE Louisiana solar-guy Member Introductions 2 12-17-2011 10:49 AM
Hope to be an Airstream owner.......... angellhill Member Introductions 4 08-21-2011 05:27 AM
1984 Airstream 345 Keyair Airstream Registry Discussions 0 08-19-2011 08:32 AM
It's going to FINALLY happen, I'll officially be an Airstream Owner! crazeevw Member Introductions 3 08-18-2011 11:06 PM
Hoping to be a Future Airstream Westfalia Owner 2005-/+ PorcupineRim Member Introductions 1 03-19-2011 10:13 PM
