Old 11-30-2011, 09:08 AM   #659
1987 34.5' Airstream 345
Milton , Florida
Have a great time...the Panhandle will have low 40's at night and low 70's in the daytime by the weekend, but Orlando will be warmer much. Perfect for Disney...
navyspook is offline   Reply With Quote
Old 11-30-2011, 10:39 AM   #660
Tried the 13 SMD 1156 LED Bulbs I just got in the Galley Overhead Light fixture...
Its bright, but I feel the original bulb is brighter..
LED...
Incandecent...
Next, I tried the single LED T10 bulbs in the bodyside marker lamps...
What I noticed is that whilst it is difficult to see from the pictures, the LED is brighter, and whiter light, but is slightly directional.
When you view the LED direct side on, its maybe twice as bright, but at 45deg it seems dimmer than the original Incandecent.
I think you can see in the pictures I took at about 45deg.
Incandecent...
LED...
I am going to go with the LED's as the lower power consumption of the LED is worth it.
Oh, and finished the last of the rear upper marker lamp castings, and its ready for refitting fitting/sealing.
Before..
After..
Old 11-30-2011, 05:17 PM   #661
Athens GA
Myrtle lynn's Avatar
1995 28' Excella
1989 34' Excella
1986 31' Sovereign
Athens , Georgia
Stop for a break... Feed dogs. Moho driving like a dream.
Athens GA
Myrtle lynn is offline   Reply With Quote
Old 12-04-2011, 12:58 PM   #662
Athens GA
1995 28' Excella
1989 34' Excella
1986 31' Sovereign
Athens , Georgia
Help!!
I was able to limp off exit. My 87 Moho with 454 was driving fine. Cruising along at 65 and and was like it just went into neutral. Low gears work fine. I stopped put in park then back in drive only sifted to 2nd gear I think. Checked fluid level and Is right on. Is trans shot? Ideas?
Athens GA
Old 12-04-2011, 01:07 PM   #663
Any unusual noises?
Old 12-04-2011, 01:10 PM   #664
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
Last time I had that feeling was when one of the disk brakes was not releasing. Stopped let it cool and worked fine, when I got home replaced the brake calipers and brakes. With Ir thermometer easy to diagnose just shoot the wheel, if it is hot like over 200 you have a dragging brake.
Old 12-04-2011, 02:58 PM   #665
Athens GA
1995 28' Excella
1989 34' Excella
1986 31' Sovereign
Athens , Georgia
Originally Posted by Keyair
Any unusual noises?
Having it towed. Had new brakes all the way around. Hoses. Calipers and all. No noise. Just acted as though I put in put it in neutral.
Athens GA
Old 12-04-2011, 03:45 PM   #666
Athens GA
1995 28' Excella
1989 34' Excella
1986 31' Sovereign
Athens , Georgia
Any unusual noises?
No noise.
Athens GA
Old 12-04-2011, 05:52 PM   #667
streamquest's Avatar
1936 20' Clipper
1947 22' Liner
Curtis Wright
1989 37' Airstream 370
marshfield , Massachusetts
Myrtle,
That is a serious bummer, guess I should have picked you up in the jet after all. But rented Ferraris can't be trusted either.
Really though, the bitch of it is that you have done so much, so right, and the thing still bites you in the ass. Sorry to hear. But I suppose these torrid love affairs are never without drama. Keep motoring!!
Charly.
streamquest is offline   Reply With Quote
Old 12-04-2011, 06:01 PM   #668
crazeevw's Avatar
1989 34.5' Airstream 345
Saint Petersburg , Florida
Originally Posted by Myrtle lynn View Post
Help!!
Myrtle,
Keep us posted on your diagnoses of the Classic. Almost sounds as if tranny just burped and quit on you. Strange. Does tranny fluid have any odd smells to it?
Thanks, Derek
Old 12-04-2011, 11:17 PM   #669
Not much in the way of progress this week on my Airstream, beyond the arrival of some LED bulbs..
With my Parents visiting, I have been spending time with them, and when they have been entertaining themselves I have been fixing the GF's Range Rover.
It was not starting when hot.. an investigation revealed no fuel pressure, but as soon as it cooled, pressure came back, and it ran fine.
Turned out to be a bad fuel pump.. as far as I see now.
Its an "In Tank Pump", but part of the whole assembly, with pump/Sender/return.
The word is that the Land Rover part is $800...
Drained and dropped the tank... pig of a job!
I found a TRE pump that was identical, and $85..
Some careful disasembly, and we have fuel pressure, and its running fine!
An Autopsy on the old pump shows one of the 2 brushes was not connected to the armature..
The word is that 100k miles is about right, and we have 125k on her.
For all you anti British Electrical Naysayers... the Original pump has a large "Made in Mexico" stamp on it!
Now I have the front suspension out to find where and why the Drivers side Suspension Airbag is leaking down overnight...
This can only be good training for the Airstream... Right???
Old 12-05-2011, 06:08 AM   #670
Athens GA
1995 28' Excella
1989 34' Excella
1986 31' Sovereign
Athens , Georgia
Originally Posted by streamquest
Myrtle,
Charly.
Call my crazy! Still love her. They shouldn't bite the hands that feed her. She is old and doesn't know any better. It was a safe place to break down had my jeep. All will be fine. :-)
Athens GA
Old 12-05-2011, 06:10 AM   #671
Athens GA
1995 28' Excella
1989 34' Excella
1986 31' Sovereign
Athens , Georgia
Originally Posted by crazeevw
Myrtle,
Thanks, Derek
I flushed the fluid about 4k miles ago. Fluid look clean.
Athens GA
Old 12-05-2011, 06:16 AM   #672
Athens GA
1995 28' Excella
1989 34' Excella
1986 31' Sovereign
Athens , Georgia
No noise.
Come to think of it. Past few trips I was getting a humming noise at 60+ mph It would hum in and out. In and out. In and out. It always concerned me. First thing I noticed heading to FL was it wasn't doing it. I bet with the pressure of pulling the jeep made it not hum. I changed out differential fluid twice thinking it was that. I then felt it was the trans. must have been.
Athens GA
New Airstream Interstate Owner in SE Louisiana solar-guy Member Introductions 2 12-17-2011 10:49 AM
Hope to be an Airstream owner.......... angellhill Member Introductions 4 08-21-2011 05:27 AM
1984 Airstream 345 Keyair Airstream Registry Discussions 0 08-19-2011 08:32 AM
It's going to FINALLY happen, I'll officially be an Airstream Owner! crazeevw Member Introductions 3 08-18-2011 11:06 PM
Hoping to be a Future Airstream Westfalia Owner 2005-/+ PorcupineRim Member Introductions 1 03-19-2011 10:13 PM
